iceracer Samba Member
Joined: February 28, 2006 Posts: 949 Location: Milwaukee, Wisconsin
Posted: Sat Apr 24, 2010 3:12 pm Post subject: Syncro Front Axles |
I am replacing one axle and want to know if the axle lengths are the same. Anyone??? I compared right to left spares I have and they appear to be the same length. thanks. _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
tencentlife Samba Member
Posted: Sat Apr 24, 2010 3:41 pm Post subject: |
Both sides are the same. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Sat Apr 24, 2010 3:42 pm Post subject: |
Far as I know they are all the same front&back. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Sat Apr 24, 2010 5:47 pm Post subject: |
same same. AT rears are the only axles that are different length side to side. |
Posted: Sat Apr 24, 2010 6:23 pm Post subject: |
Thanks everyone, I thought so. _________________ 86 Syncro Wolfsburg edition
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Sat Apr 24, 2010 10:26 pm Post subject: |
Alaric.H wrote: |
Wait... I knew the rear axles were the same side to side, but the front axles are interchangeable with the rear? Really? Or am I misunderstanding you?
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
Posted: Sun Apr 25, 2010 5:06 am Post subject: |
I do not see why not. Of course not on mine I put the 930cv on the back.
Plus I put the 944s on the front inners. |
Posted: Sun Apr 25, 2010 7:31 am Post subject: |
Pretty sure front and rear are different, but both are the same side to side.. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
axeman Samba Member
Joined: December 11, 2009 Posts: 162 Location: east kent, uk
Posted: Sun Apr 25, 2010 12:42 pm Post subject: |
the rear drive shafts on a 14inch syncro are the same as 2wd ones, however the front are 14inch syncro only, all the cv joints are the same as 2wd ones with the execption to the front outer, again 14inch only. the shafts can be installed on eather side of the van, dont forget that the bolts on the front inner (to the diff) are longer about 4mm that all the rest, and there should be a metle spacer (which is normaly missing) between this cv joint and the diff about 3mm from memory.
i have a copleate spaire in the van and i could take a photo if it showing the spacer if it would help.
neil _________________ 1957, 1200cc 30hp, big window, delux beetle, swedish modle, now living in france
1991 holdsworth villa 3, 2.1, uk van, now sold
1991 syncro doka uk van was 2.1 now B230, out with the b230 and in with a 1.8 20v, and 4 doors
1987 syncro westy was 1.6 jx now ej22 |
insyncro Banned
Posted: Sun Apr 25, 2010 12:52 pm Post subject: |
Alaric.H wrote: |
No,
The front and rear are NOT the same lenght.
There is a spacer on the differential side of each in front.
The fronts do not have the same splines and attachment at the front outer vs. the front inner CV joints.
Yes, 2wd manual and Syncro rears are interchangable.
dylan |
