Cheap DIY grey water tank
Page: 1, 2, 3  Next
presslab
presslab is offline
PostPosted: Mon May 03, 2010 1:35 pm    Post subject: Cheap DIY grey water tank Reply with quote
I wanted a grey water tank but eurocampers has been out of stock forever, so I decided to make my own.
For the tank I used 6" PVC sewer pipe with two end caps. The sewer pipe is light weight and perfect for the job. I drilled and threaded the end caps - on the rear side a 3/4" NPT at the bottom. On the front 3/4" NPT and a 1/8" NPT on the top. The rear is the drain, using some 3/4" pipe and fittings, with a garden hose ball valve. The front has a 1/4" vinyl vent hose that goes up above the gas tank and terminates inside the front fender.
I redid the drain for the sink because the stock one drained slowly even with the vent. This is because of the small hose size and that there are now two traps. I found some fittings to go from the stock strainer basket to a 3/4" vinyl hose. The hose then goes through the hole in the floor, around the frame member, and up to the tank. This creates a trap so you don't get any smells.
The tank is just under 5 gallons capacity which works well for me. I have a filter on the faucet, and I drink the water, so not all 10 gallons will go into the grey water tank. On my recent road trip I put the fresh water tank into the red indicator ( < 2.5 gal I believe) and the grey water tank was not full.
It doesn't hang very low, it's above the propane tanks by probably 3/4".
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
rockfish
rockfish is offline
PostPosted: Mon May 03, 2010 2:00 pm    Post subject: Reply with quote
Nice work!
I use a filter on the end of the hose when I'm filling my water tank - that way the tank stays relatively germ free as well.
A year ago I found this gray water system - but I believe yours to be much more economical!
http://secure.mycart.net/catalogs/catalog.asp?prodid=4757889&showprevnext=1
89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden
DAIZEE
DAIZEE is offline
PostPosted: Mon May 03, 2010 2:34 pm    Post subject: Reply with quote
I like that and very few corners for collecting stagnant water. Great thinker!
If you made one or two black ones to fill and put on your roof when parked you might get a solar shower. Just a thought. Would only have to fill them when stationary.
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
noganav
noganav is offline
PostPosted: Mon May 03, 2010 8:20 pm    Post subject: Reply with quote
Super clever. Nice work!
DAIZEE
DAIZEE is offline
PostPosted: Tue May 04, 2010 3:57 am    Post subject: Reply with quote
oops didn't read grey still neat
presslab
presslab is offline
PostPosted: Tue May 04, 2010 9:08 am    Post subject: Reply with quote
Thanks guys. It gives me peace of mind knowing that I'm not messing up the camp site for the next person.
stevey88
stevey88 is offline
PostPosted: Tue May 04, 2010 9:30 am    Post subject: Reply with quote
Can you post drawings that show where the inlet, outlet and the vent is located ?
Thanks
Steve
87 Westfalia full camper 4 speed
vweggie
vweggie is offline
PostPosted: Tue May 04, 2010 9:54 am    Post subject: Reply with quote
I saw many DIY solar showers like this when I was in Australia.
1990 Multivan 2.1 AT
chimivee
chimivee is offline
PostPosted: Tue May 04, 2010 10:42 am    Post subject: Reply with quote
Great work on a very clean install! I've considered this very project many times, while strolling down the plumbing aisle. I finally ended up buying the EuroCampers unit a few years ago... but have yet to install it. Embarassed I almost like yours better for its ingenuity. Smile
-James
86 Syncro Westy, etc
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
DAIZEE
DAIZEE is offline
PostPosted: Tue May 04, 2010 10:53 am    Post subject: Reply with quote
I use a pail for sink water. I also have a tall pail with seat and lid that I recycle thru the (a) washroom.
You are very talented AND I suspect that a grey water tank will become mandatory at some time. They brought it in for marine activity years ago. Your design really simplifies things. Applause
presslab
presslab is offline
PostPosted: Tue May 04, 2010 11:24 am    Post subject: Reply with quote
Thanks
The drain is at the very bottom, that's easy. Here is a diagram of the inlet side:
And two closer pics:
Classicvibe
Classicvibe is offline
PostPosted: Tue May 04, 2010 2:08 pm    Post subject: Reply with quote
Love it, great work! I have been considering this for a plumbing system I am considering for my weekender-this is extremely helpful. Great mod!
On a mission, the destination is just an excuse.
Syncro Solstice 2016...you goin?
1986.5 Wolfsburg Westfalia Weekender Poptop Syncro
wolfej1
wolfej1 is offline
PostPosted: Wed Jun 16, 2010 6:55 pm    Post subject: Reply with quote
Yes that is a good idea...still have not done it yet though Very Happy
http://www.thesamba.com/vw/forum/viewtopic.php?t=309438&highlight=
1982 Westy
2004 KDX200
2008 Kawasaki KLR 650
1979 Yamaha DT 175
1995 Toyota 4Runner
Birdmanhere
Birdmanhere is offline
PostPosted: Fri Aug 20, 2010 4:45 pm    Post subject: Reply with quote
Would there be any issues using this type of tank used for the sink water supply?
I only have ever used my sink for dishes/wash water and brushing my teeth, and I usually with sanitize the tank (bleach & rinse) every time before each trip. We drink out of water bottles camping.
Oh yeah, it will be in a 66 westy with an early bay Icebox sink unit. I had the bay tank in there until last weekend when i went to fill it up and it just flooded the bus (split the seam on tank), and plan on putting a truck fridge in the unit too now. It already has a 12v pump instead of the hand pump
You Vanagon guys always have the best solutions for mastering space and function.
66 Bus
71 Bug
foodeater
foodeater is offline
PostPosted: Fri Aug 20, 2010 5:15 pm    Post subject: Reply with quote
I wouldnt want to drink out of a PVC tank (the water would likely taste how the PVC smells), but it would probably be okay, for washing dishes. Not sure about tooth brushing.
89 Bluestar-2.5 Subaru Powered
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
Birdmanhere
PostPosted: Fri Aug 20, 2010 7:57 pm    Post subject: Reply with quote
Yeah that what I was sort of thinking although the water in the stock tank already taste like plastic after a day or so
66 Bus
71 Bug
presslab
presslab is offline
PostPosted: Fri Aug 20, 2010 9:35 pm    Post subject: Reply with quote
I found these three contimanates of PVC pipe:
Antimony
m-Chlorophenol
Cyclohexanone
Looks like an activated carbon filter will remove these effectively. I know PVC pipe is approved for drinking water. I think it will be ok but I suggest you use a filter.
chazmataz
chazmataz is offline
PostPosted: Wed Dec 08, 2010 9:38 am    Post subject: Reply with quote
nice work! i;ve been thinking about doing something for a grey water tank. the one that came with my van is from gowesty and i haven't been able to get it to drain very well. i have been watching for the eurocamper to get in stock but i like your idea and its pretty simple.
so i think i may do something similar to what you have done instead but i may tweek it a little.
chaz
Jon_slider
Jon_slider is offline
PostPosted: Wed Dec 08, 2010 10:07 am    Post subject: Reply with quote
you do fantastic work!
sell a kit Smile
for solar shower, you can use clear PVC. Bottom half painted black.
link to commercial solar PVC shower, and clear PVC supplier:
http://www.thesamba.com/vw/forum/viewtopic.php?p=4760299&highlight=clear+pvc#4760299
you could use the clear pvc to know how full the greywater is too..
climberjohn
climberjohn is offline
PostPosted: Wed Dec 08, 2010 11:41 am    Post subject: Reply with quote
A bit off topic, but here is a slick looking solar shower for mounting on top of your rig:
http://www.roadshower.com/
-CJ
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
Page: 1, 2, 3  Next
