TomSimon Samba Member
Posted: Mon Aug 17, 2009 10:22 am Post subject: |
so THAAAAT's why the practicle stroke limit is said to be ~74mm stroke... those pesky cam lobes
thanks guys! |
tommy-turtle Samba Member
Joined: March 07, 2002 Posts: 165 Location: roseville
Posted: Thu Feb 18, 2010 12:10 am Post subject: |
man no post since 2009. we all need to get back in there |
Posted: Thu Feb 25, 2010 10:52 am Post subject: |
agreed Tommy...
I am building 2 engines for the 36hp Bonneville class.
so... I have a set of WW Okrasa heads in the works.
I have (2) 912 cranks being prepared and (2) custom flywheels being made by Jose at DPR.
I tried to buy a Pepco from a local guy I know... it was not to be, it seems he got a better offer while I was enroute to look at it, an he stopped picking up my calls and txts. Oh, but he did manage to remember my phone number 2 months later when he needed some fast cash and wanted to 'off' a couple of core 36hp longblocks
anyone else working on anything interesting? |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Mon Mar 01, 2010 8:40 am Post subject: |
Rich Kimble has rekindeled the 36 hp drag class at Bug-In's I believe. WW has ponied up to sponser the Okrassa class
from the Bug-In site
“T6” Thirty-Six Horse Trophy Bracket -All the participants in this special bracket must have an engine based on the 36hp case. Wolfsburg West has posted $500 to the first car to win using their new “Okrasa-Style” kit.
Let the fun begin _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Roadcow Samba Member
Joined: November 14, 2003 Posts: 1012 Location: Stockton, Ca. area
Posted: Mon Mar 01, 2010 9:36 am Post subject: |
Oh that's great news! _________________ 71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat |
Julio Iniguez Samba Member
Posted: Fri Mar 12, 2010 7:24 pm Post subject: |
Ok, like other races it takes a minimum of four cars for a class.
I know I'll be there along with Al Higdon, does anyone else plan to be at Irwindale racing a 36er in the T-6 class? It would be awesome to see a vintage class and not have to be in the T-3 but will if I have to. Hopefully it's not just Al and me with our 36er like always, come on out and let's have some fun!!
Julio |
Posted: Mon Mar 15, 2010 9:19 pm Post subject: |
Results? who took Wolfsburg West's money? Bueller? Bueller? Anyone? |
Posted: Mon Mar 15, 2010 9:49 pm Post subject: |
TomSimon wrote: |
http://www.bugin.com/dragday.htm
good job you guys |
Posted: Tue Mar 16, 2010 4:28 pm Post subject: |
Thank you sir and no one took the Wolfsburg West money because you have to have one of their motors to qualify. But it was fun anyway knowing the class was for us guy's. There were a few people at the show saying they were going to race at Bug-in. |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Sun Mar 28, 2010 10:16 pm Post subject: |
TomSimon wrote: |
Got my two 356 cranks back from Jose at DPR on Friday,excellent job as usual. 72mm stroke with 36hp rods, 50mm mains. I'm trying one of the custom flywheels as well that Tom mentioned. Also got a batch of new valve springs made. They are a free length of 43mm just like originals but have a pressure rating just a bit higher than stock. I got tired of taking apart a dozen heads to find a nice set. These will be up for sale on my website as soon as tomorrow. As always if anyone has any cam cores out there, I need them. Sent my last batch to get reground last week, they sell fast!
Springs
Crank (one of two)
Flywheel
_________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
Posted: Sun Mar 28, 2010 10:30 pm Post subject: |
Is the "custom" flywheel the same one that Blackline57 so graciously shared with everyone last year in their build? The one which was a stock 1600 flywheel with the 36hp center machined in and 8 doweled? It was nice of them to share their build details with the rest of us and I appreciate their cutting edge thinking. This allows the use of any 1600 Clutch and Pressure plate. I'm using the Kennedy 1700 pound on mine, balanced. _________________ 71 Westy Roadcow
67 Panel
63 Bug
74 Ghia Vert
80 Cabby 2.1 16v
98 Passat
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Mon Mar 29, 2010 1:03 am Post subject: |
the 200mm flywheel is also on another way possible.
for porsche 356 are 200mm flywheels available to use typ1 pressureplates and clutches plus 12v starter. the only thing is to use other shims to adjust endplay..but they are in more than one size available not like the only 0,32mm for 36hp.
@Mr. Motorhead
since okrasa repro more people need performance cams...right? |
Posted: Mon Mar 29, 2010 9:29 am Post subject: |
Yes, the flywheel hub gets welded and remachined for 8 6mm pin holes with the spg pattern. I've had 180mm flywheels machined for a 200mm clutch then added a 12v ring gear before. Only problem with that is if you don't do a whole boatload it costs way more than the welded 12v flywheel route.
You'd think the uptake in sales would be for performance cams due to the the sales of the WW head kits but oddly enough I've been getting just as many requests for stock grinds. Many thanks to all that have sent me cams, keep those cores coming! I'm even willing to grind your cam ( if you do make sure you mark it in some way). _________________ 30 years experience in the sales of new and used auto parts!
Some Chinese guy |
Posted: Fri Apr 02, 2010 8:37 am Post subject: |
I'm sending a load of 36 hp cams to WEB to be reground, after the dyno session with my WW Okrassa engine we started to calculate cam lifts and duration and came up with what we feel will be some better grinds (we had a WEB 86 grind). Also Tom Bruch is going to see if his guy will machine up some more of the offset rocker shafts to use Porsche rocker arms. Need more lift and duration. My engine would not rev higher then 5500 rpms
http://www.youtube.com/watch?v=qZhhFvk0HxA
http://www.youtube.com/watch?v=qOteIsByD4A
5500 at the end, 11 sesions, 77 pulls in 5 hours _________________ Stocking distributor of "The Funky Green Panels"
Eric Outland Samba Member
Posted: Fri Apr 02, 2010 9:17 am Post subject: Eric (VMR) |
Splitpile I was wondering what is your target for Lift and duration on the new Cam ?? Are You guy's shooting for higher than say 6200 RPM overall?? Eric |
Posted: Fri Apr 02, 2010 9:36 am Post subject: |
splitpile wrote: |
Also Tom Bruch is going to see if his guy will machine up some more of the offset rocker shafts to use Porsche rocker arms. Need more lift and duration. My engine would not rev higher then 5500 rpms |
Any one machined a set rocker stand off a 36head and fit a set of custom made shafts? After the machining and shorting down a set of 1600 shafts(I know and re drilling the holes in tempered/ steal is not easy, and shorting and tapping it is just as fun ) you could have a wide range of arms and ratios available. Yes you would most likely have to go with the Porsche style lifters so you could get the swivel and adjustment out of the push rods.
Also any one ever done the jaguar valve spring trick that was mentioned in "making the VW go book"? |
Posted: Fri Apr 02, 2010 2:27 pm Post subject: |
tommy-turtle wrote: |
How many pounds pressure do the Jag springs have? Anybody know? The springs I have in stock are about 88 pounds. _________________ 30 years experience in the sales of new and used auto parts!
Some Chinese guy |
Posted: Fri Apr 02, 2010 11:33 pm Post subject: |
Any one machined a set rocker stand off a 36head and fit a set of custom made shafts? After the machining and shorting down a set of 1600 shafts you could have a wide range of arms and ratios available... |
I saw a set last Friday, aftermarket T1 ratio rockers on modified T1 shafts, on modified 36hp pedestols, all custom machined to function like T1. Not cheap to do, very time consuming
Also any one ever done the jaguar valve spring trick that was... |
I am not familiar with that trick.... what is it Tommy? |
mightymouse Samba Member
Posted: Tue May 11, 2010 12:56 am Post subject: |
any reason to NOT counterweight? _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
