Long distance continuity tests
Rhinoculips
Rhinoculips is offline
PostPosted: Wed May 12, 2010 9:35 pm    Post subject: Long distance continuity tests Reply with quote
I need to test some wires going from the dash to the engine compartment, what is the best way of doing this? A really long jump wire?
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
targis58
targis58 is offline
PostPosted: Wed May 12, 2010 9:47 pm    Post subject: Reply with quote
I have a roll of 100' 24guage wire with aligator clips on both end to check long distance continuity. Works good on vanagons as well as on house projects
90 westy 2wd w/ TBD
16CVs Premium Member
16CVs is offline
PostPosted: Wed May 12, 2010 10:54 pm    Post subject: long wires and testing Reply with quote
Buy a " power probe " ,it comes with leads long enough to go around a Semi .
It has a lot of great features like being able to check components and let you know if a circuit is Power ,ground or dead .
They may seam expensive at over $100.00 ,but will be the most used arrow in your quiver .
Stacy
tencentlife
tencentlife is offline
PostPosted: Thu May 13, 2010 7:10 am    Post subject: Reply with quote
This is easy to do without the need for extra jumpers if you can isolate both ends of the wire you want to test. You can either do it by voltmeter or testlight, or ohmmeter:
Just clip your testlight or voltmeter to a power source on one end (alternator positive pole is always hot in the engine bay), the other lead to the wire you want to test. If the wire is isolated from ground, you would see no voltage or the testlight will not light up. Then go to the other end of the wire and ground it, your testlight will glow, or your voltmeter show voltage.
Or use the ohmmeter, connect the leads between any grounded point and one end of the wire you want to test, there should be infinite ohms, then ground the opposite end and you will see a circuit. This method is easiest because you don't need to find a positive power point. Best of all is if your VOM has a continuity buzzer you can put it in ring mode and test this way without the need to see the meter.
See innovative Vanagon accessories at the Vanistan shop:
I don't use The Samba Private Messaging. Please use the contact link at www.intrepidoverland.com
"Official" IntrepidOverland thread for news and discussion:
