Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Fri May 14, 2010 6:18 am Post subject: Thermostat usage |
I have a 1984 Mexican Beetle, which I think came with a 65/70 degree thermostat. Unfortunately, I tossed it years ago. I have recently aquired a 90 degree thermostat with a cable threaded onto it ( presumably for the air control ring style fan shroud) and was curious if I could use it if I re-thread the actuator rod (it has different threads). I know the correct answer is to get the proper thermostat, but was just curious if anyone has more knowledge on the subject. If nothing else, maybe this thread could be used in the future as a good reference for when these thermostats become VERY hard to come by. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Fri May 14, 2010 7:11 am Post subject: |
Go to Performanc-Engines and Transmission Foeum. There is a Post on there about rebuit ones. From what I read on that topic, the t-stat that you have may be for a Type 2. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
Zach Thomas Samba Member
Joined: August 12, 2008 Posts: 929 Location: Lake Stevens, WA
Posted: Fri May 14, 2010 7:44 am Post subject: |
As you said, it's not necessarily right and I don't know enough to know if it would be bad to use. But, couldn't you take a small cylinder (barrel nut maybe?) and drill one side to fit the type 1 rod and the other end screw onto the thermostat? _________________ 62 Rag - a little crusty |
Bruce Samba Member
Posted: Fri May 14, 2010 10:51 am Post subject: Re: Thermostat usage |
Paul Windisch wrote: |
... I have recently aquired a 90 degree thermostat with a cable threaded onto it (..... |
You have a Type 4/Bus thermostat. Sell it to a Bus guy and buy the right one. You should be able to do two deals with a net cost to you of zero. _________________
