maddriverman Samba Member
Joined: March 11, 2008 Posts: 295 Location: carlton,oregon
Posted: Wed May 26, 2010 6:01 pm Post subject: |
Can anybody tell what a good guage wire would work for the engine sect,
including the oilsend. unit everything I need seems to be the real thin wire.
the generator wires are great its just the other 2 or three wires goin to the carb and coil. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Wed May 26, 2010 6:30 pm Post subject: |
Better to go a little big than too small... _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Wed May 26, 2010 6:55 pm Post subject: |
If you have a parts bus you could cut up the wiring harness, usually the stuff in the middle of the long PVC tube is in great shape and is ideal for making repairs. I like to solder, shrinkwrap, and then cover the repairs with fresh pieces of PVC tubing. It takes a little bit more time but the repairs are pretty much invisible. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed May 26, 2010 7:39 pm Post subject: |
campingbox wrote: |
Greg said it best. Find a bay in a junkyard (where you'll find most bays anyway)- and liberate its harness. My engine bay now looks exactly as it should- and I have spare 'coils' of color coded wire for every future need. _________________
EverettB wrote: |
FU#5 |
Posted: Wed May 26, 2010 11:22 pm Post subject: |
Im sure not everyones a fan of this idea...But,is there a size or gauge of wire that will work for the carb,coil & oil send. unit?.. |
Posted: Thu May 27, 2010 7:46 am Post subject: |
From your post everett,16 gauge will work in the engine compartment?
At least for a hack job. |
Posted: Thu May 27, 2010 9:27 am Post subject: |
Thank you!! |
Alexmobil Samba Member
Joined: November 28, 2010 Posts: 71 Location: El Salvador
Posted: Tue Aug 25, 2015 3:46 pm Post subject: |
Zombie thread warning =)
Hello Everybody. Im about to rewire the Double Cab.
Printed and studied the wiring diagram, conversion chart and I bought/ repaired most of the switchs and electrical related stuff.
The question is: The AWG 20 wire for the tail light circuit seems to be too thin
Is it a deliberate way to underpower the tail light circuit to make noticeable the brake light brightness? ( circuit with AWG 16 wire)
Im using the wiring diagram vw transporter from aug 1966.
Thanks in advance. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Tue Aug 25, 2015 7:42 pm Post subject: |
If it was too small the wire would run hot. No problem with that for us.
We likey zombies! _________________ In Stereo, Where Available! |
