Cuņado Wear Samba Member
Joined: December 10, 2006 Posts: 1145 Location: The "O"
Posted: Sat May 15, 2010 3:57 am Post subject: help me,help me. |
i need help fitting hood on just paint 63vert cant seem to get fittment right on top.after adjusting it seems either to low or high. help!!!! _________________
Bulli Klinik wrote: |
I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
60' Double Cab
63' 15 Window Deluxe |
zeroman Samba Member
Joined: February 05, 2010 Posts: 891 Location: Cane field
Posted: Sat May 15, 2010 3:58 pm Post subject: |
I don't know any tricks. Did it fit before? It wasn't sand blasted, welded or anything since being removed to change its shape was it?
it doesn't close right or its not matching up with the body at the top of the hood. Should just be a matter of loosening the bolts and moving it a touch.
Just keep tweakin it. Loosen slightly.. move it.. tighten a bit and try again. _________________ 77 super convertible |
Posted: Sat May 15, 2010 10:23 pm Post subject: |
ya i've tried to move up and down nothing seems to work. it did seem to fit better before paint they did fix dent in bottom half but nothing on top were i cant get to sit right. _________________
60' Double Cab
Posted: Tue May 18, 2010 7:30 pm Post subject: |
well there's no magic to it. If it fit before.. unless you took out the hinges (and even if you did) it should be adjustable. maybe they bent in the bottom and you can't make it fit in both places? _________________ 77 super convertible |
Posted: Wed May 19, 2010 12:30 am Post subject: |
i played with for three hours and i cant tell if it sits better. i do think that it has to be bent alittle. i tried every combo. i dont know if its because im not a body guy or if there is somthing wrong.thanks for help. i think i might take back to body shop and see if they could fit it better. _________________
60' Double Cab
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Tue May 25, 2010 8:01 am Post subject: |
I would take it to a body shop if you are banging your head. They will likely be able to do it in 15 minutes and cost you next to nothing. |
Posted: Tue May 25, 2010 11:12 am Post subject: |
ya i'm gonna take to body guys. thanks _________________
60' Double Cab
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue May 25, 2010 11:26 am Post subject: |
If you take the hood off you can file/grind your bracket to bolt the hood down lower. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Red Rim Body Shop Samba Member
Joined: May 28, 2010 Posts: 3 Location: Albuquerque New Mexico
Posted: Fri May 28, 2010 12:22 pm Post subject: adjustment |
you can always oval out your hinges. I mean where the bolt holes are. You will get more room for adjustment. Use bigger washers after wards or bolts with bigger heads. |
Posted: Fri May 28, 2010 8:34 pm Post subject: |
ya i spoke to body guys and they said they will take care if it. and if after it still does look right i will give them the tips you guys are giving me. thanks again everyone. i'll have pics up soon. _________________
60' Double Cab
