Closet door mod
Page: 1, 2, 3, 4, 5  Next
1621 is offline
PostPosted: Thu Jun 10, 2010 12:19 pm    Post subject: Closet door mod Reply with quote
I must first give credit where it's due. Mootpoint posted this one a couple years ago: http://www.thesamba.com/vw/forum/viewtopic.php?t=264050&highlight=closet
After admiring the functionality of this for sometime, and finally working up the courage through several of his pep-talks, I finally cut into the cabinet wall. It's really not as difficult as it might seem, and anyone with basic woodworking skills can accomplish this in an afternoon.
Used a 4" hole saw for the corners, and the finest tooth jigsaw blade I could find.
My initial measurements were to determine how much depth was in the closet, and where I wanted the door. I needed to clear the GW shoulder belt and I wanted the door to open 90* with the seat back up. Once determined, I used a right angle ruler to draw out my left vertical and bottom lines using the rearmost cabinet opening as my guide.
I had the frame from the donor, so used this as a template for drawing out the cut lines. Then it's time to drill out the corners.
Make certain to clear the cabinet before drilling/cutting.
The point of no return. This is the first of the four corners to be drilled out. The center hole was simply practice.
I used the right angle rulers as both a guide and to keep the jigsaw level during cutting. Likely not the best method, but it worked.
The hole! Shocked
Routed out the slot for the T-molding using a Freud 63-104 router bit. LOTS of dust. A bit of glue in the resulting slot, and tapped the original T-molding right in.
The finished project - works exactly as intended and looks like it came from Westfalia this way. The only thing I'll add is a couple more mesh pockets like seen on the back wall to the inside of the door for convenient storage.
'85 Westy
madspaniard
madspaniard is offline
PostPosted: Thu Jun 10, 2010 12:26 pm    Post subject: Reply with quote
this is the kind of posts I really enjoy reading, awesome job! looks 100% stock when did you say you are coming down here? seriously, I have the parts.
reluctantartist
reluctantartist is offline
PostPosted: Thu Jun 10, 2010 1:07 pm    Post subject: Reply with quote
That is really nice work!
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
GBA 88West LA
GBA 88West LA is offline
PostPosted: Thu Jun 10, 2010 1:15 pm    Post subject: Reply with quote
i so want to do this but can never seem to find the door in grey plenty of browns ones avail but no grey ...looks great ....thank god you noticed the little closet troll in there before cutting Wink
88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin
campism
campism is offline
PostPosted: Thu Jun 10, 2010 1:16 pm    Post subject: Reply with quote
Way to go!
Timwhy
Timwhy is offline
PostPosted: Thu Jun 10, 2010 4:32 pm    Post subject: Reply with quote
Very Nice!!
Love the pics!!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
wbx
wbx is offline
PostPosted: Thu Jun 10, 2010 7:00 pm    Post subject: Reply with quote
Super clean!!! Me likey.
'84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go.
snoop
snoop is offline
PostPosted: Thu Jun 10, 2010 7:02 pm    Post subject: Reply with quote
Thanks Erik...keep blazin' trails!
87 Westy Camper
ddonnell
ddonnell is offline
PostPosted: Thu Jun 10, 2010 9:22 pm    Post subject: Reply with quote
Looks AMAZING!
Applause Applause
Wish I had a Westy to do cool mods with..
1990 Vanagon Carat-SOLD
1995 Dodge Ram 2500 4x4 V10
1966 Baja "The Beast"
instagram #bajabugproject
View user's profile Send private message Facebook Classifieds Feedback
MarkWard
MarkWard is offline
PostPosted: Fri Jun 11, 2010 7:55 am    Post subject: Reply with quote
Where did you get the overhead net and the pocket nets? Nice work by the way. Measure twice cut once. Smile
climberjohn
climberjohn is offline
PostPosted: Fri Jun 11, 2010 8:18 am    Post subject: Reply with quote
1621,
The Man with the Cajones Grandes to make that first cut!
Way to go!
-CJ
PS - Hang onto the hole saw and jigsaw blade, I might borrow them soon, hee hee. . .
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
1621
1621 is offline
PostPosted: Fri Jun 11, 2010 8:22 am    Post subject: Reply with quote
The overhead net was a GW purchase. Handy for small, light, and loose items - honestly not as frequently used as I had initially imagined. The mesh pockets are found at Bus Depot, and I use those all the time.
In this case, I measured dozens of times before I worked up the courage to cut! Nerve wracking to say the least.
'85 Westy
carterzest
carterzest is offline
PostPosted: Fri Jun 11, 2010 9:23 am    Post subject: Reply with quote
climberjohn wrote:
1621,
Way to go!
-CJ
X2. Looking for a gray door Wink
Happiness=Portland, Oregon in the rearview mirror!
Vanagon Nut
Vanagon Nut is offline
PostPosted: Fri Jun 11, 2010 6:20 pm    Post subject: Reply with quote
From someone who's not so good with wood, much thanks!
Using the square for jigsaw is a neat idea!
One of these days, like if I ever have children and need more space, I may get around to making a sliding door for that area.
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
EL31415
EL31415 is offline
PostPosted: Fri Jun 11, 2010 11:43 pm    Post subject: Reply with quote
Thank you for sharing
If I only had the courage to cut and drill into my westy
1985 Westy
SirIvor70
SirIvor70 is offline
PostPosted: Sat Jun 12, 2010 1:21 am    Post subject: Reply with quote
Did the same mod myself and one of the best things I have done to the van....that and the pop top struts.
Took a big deep breath to start the cutting, but well worth it. Now if I can only find reverse hinges to turn the door around the other way !! Smile
Steelhead
Steelhead is offline
PostPosted: Sat Jun 12, 2010 8:11 am    Post subject: Reply with quote
I'm probably not understanding, but can't you just turn the door upside down to put the hinges on the other side?
'77 Bay Window / '89 Caratsburg (aka. the Stormtrooper)
1621
1621 is offline
PostPosted: Sat Jun 12, 2010 8:40 am    Post subject: Reply with quote
Unfortunately it's not that easy. The hinges are a two piece design that relies on gravity to keep the door in place. Flipped to the other side and the door would simply fall off.
The hinges off of the left-swinging lower door by the bench seat would work, everything else in the van swings to the right. It must be a political thing. Laughing
The hinges on the door side are also riveted in, a different design altogether from the cabinet side. Those would need to be drilled out and replaced as well.
'85 Westy
spitsnrovers
spitsnrovers is offline
PostPosted: Sat Jun 12, 2010 8:49 am    Post subject: Reply with quote
There are some photos and directions at [url] ww.griffco.ca/interest/[/url] and look for the Westfalia link.
Just more ideas for a wardrobe mod.
'88 VW Westfalia
'75 Triumph Spitfire 1500
1621
1621 is offline
PostPosted: Sun Jun 13, 2010 10:54 pm    Post subject: Reply with quote
Disregard my previous statement. It is far easier to reverse the hinges than previously thought. Thanks WW_Victoria for the info!
*Taken from this thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=416764&start=40
WW_Victoria wrote:
I love this mod as well - and I added shelves...
just a note though... to make the door swing this way I sourced the hinges from the small water access door on the water cabinet... not necessary, while playing today I realized these hinge parts are reversible. I just knocked the cap and the pin out of the hinge with a hammer and a nail...
[/code]
'85 Westy
Page 1 of 5
