Reyes Samba Member
Posted: Tue Jun 22, 2010 3:53 pm Post subject: Yakima box on top of camper pop-up? |
Can a Yakima box go on top of the camper pop-up? We need more room for bags, pillows, etc. and thought we'd put a rack and box up there. It would be emptied out before the pop-up would be pushed up. I have a 1982 Vanagon camper.
Thanks! |
bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1377 Location: Halifax, N.S.
Posted: Tue Jun 22, 2010 4:26 pm Post subject: box |
Hey..I get to say it first....Welcome...and change your fuel lines!
Yes a box can go up there.
Brian. |
buildyourown Samba Member
Posted: Tue Jun 22, 2010 4:47 pm Post subject: |
I have the biggest box Yakima makes on mine. Works great. More for camp chairs, tables, grills, bike wheels, dirty gear, etc.
Search for pop top shocks. Then you don't have to unload to lift. |
scottjk Samba Member
Joined: May 31, 2006 Posts: 485 Location: Salt Lake City, UT
Posted: Tue Jun 22, 2010 5:30 pm Post subject: yakima box |
Absolutely!!!! Also, I highly recommend Jack Bombay's pop top shocks. Best mod I've ever done to my Westy. If you think you might want to install the shocks I'd install them first and then install your roof rack mounts so there isn't any interference between the bolts. Some guys have combined the rear rack mount and pop top shock together to reduce the number of holes drilled.
http://www.thesamba.com/vw/classifieds/detail.php?id=798951
Scott _________________ 1985 Westfalia 2.5L EJ |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2725 Location: Portland Oregon
Posted: Tue Jun 22, 2010 9:06 pm Post subject: Re: yakima box |
scottjk wrote: |
I think this /\ is a good way to go, if you do decide to use the shock ball mount as one of the bolts for the "artificial rain gutter" (ARG/rack mount) I can send you longer ball mount to make sure you have a long enough threaded section with the additional thickness of the ARG.
Thanks for the kind words guys! _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
Posted: Wed Jun 23, 2010 1:01 pm Post subject: shocks |
I have the link saved to my desktop. It's my next purchase for sure. Just a matter of timing...and sweet talking...and asking for help lifting the top...one too many times. hehehehehehe |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 947 Location: Portland, OR
Posted: Wed Jun 23, 2010 6:54 pm Post subject: Re: Yakima box on top of camper pop-up? |
Reyes wrote: |
Thanks! |
Exact set-up I have been running for three years. Works great. I'm adding Jack's pop top helpers because the beast is heavy. _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
Reyes Samba Member
Posted: Thu Jun 24, 2010 1:36 pm Post subject: |
Thanks so much for the information, and Brian, thanks for the welcome. Changing fuel lines is a bit out of my know-how league, but I am curious why they need to be changed?
Disclaimer: I am not mechanically inclined at all  |
CQ Samba Member
Joined: April 11, 2009 Posts: 546 Location: San Diego, CA
Posted: Thu Jun 24, 2010 2:23 pm Post subject: |
Reyes,
I think you are about to open a can of worms with that comment. Because that is probably the most important thing you can do, right there with making sure you have brakes.
Check out Page 3 of this discussion for nasty pictures.
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=40 _________________ 82 Westy 'Betsy'
72 Bus 'Bertha' -Sold
Learning about 2.0L AFC Everyday. |
woggs1 Samba Member
Joined: February 22, 2007 Posts: 531 Location: South Pacifica California
Posted: Thu Jun 24, 2010 2:47 pm Post subject: |
Question:
Reyes wrote: |
Answer:
_________________ 4 speed 88 Westy |
Posted: Thu Jun 24, 2010 3:07 pm Post subject: Fuel Lines |
Pay someone to replace your fuel lines. After driving around for over a year without knowing about this issue I was shocked to see one of my injector hoses leaking right on top of my exhaust system.
Our vans are old and operate with a fairly high fuel pressure. Hoses get old and fail. The whole exhaust system wraps around this engine creating a poor environment for any fuel leak.
Make sure whoever you get to replace your hoses uses proper materials, namely good clamps specifically made for fuel injection as well as quality fuel injection hose. Take a look at the fuel hose kits from Van Cafe or Go Westy to get an idea of quality products.
The other problem you should probably look in to is the plastic firewall fuel hose connector. It becomes brittle over time and should be removed. Most of us have either completely removed it and have run the fuel hose through the firewall protected by a grommet or you can buy a metal reproduction that one of our members produces. Not sure who it is. I personally believe the connector was to facilitate assembly line operation and isn't necessary.
Regardless this isn't an issue you should take lightly. There are plenty of people here that would be willing to help you though the process.
Reyes Samba Member
Posted: Thu Jun 24, 2010 3:13 pm Post subject: |
I think I read on a different (older) thread that fuel lines don't need to be replaced with diesel engines. Is this correct?
Thanks so much. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7165 Location: Honolulu,Hawaii and France
Posted: Thu Jun 24, 2010 4:44 pm Post subject: |
they do need if they are bad.Specially the clear ones on the injection pump.
It won't get in fire as easily,that's it.  |
PIRATE Samba Member
Joined: May 05, 2005 Posts: 253 Location: San clemente CA
Posted: Thu Jun 24, 2010 6:19 pm Post subject: |
i have my yakima box loaded with lots of stuff an i also have jack bombays shocks the heavy duty ones and i was dissapointed by them
I am a strapping 25 year old and am about to have a freaking hearnia with my long board and box with it loaded. but what can i say i do have about 100 lbs of stuff up there + a surf board
just thought the shocks would help more than they did _________________ 2003 jetta wagon
1987 westfalia 2wd
1987 Syncro GL
1964 vespa vbb 150
1973 vespa sprint
2005 toyota tacoma Ole reliable |
woggs1 Samba Member
Posted: Fri Jun 25, 2010 7:25 am Post subject: |
PIRATE wrote: |
just thought the shocks would help more than they did |
You should mount the cargo box as far back as possible. This makes it much easier to lift. I load mine to the hilt and it goes up pretty easily because it is almost hanging off the back. Before I put the shocks on it was impossible for one person to lift it. _________________ 4 speed 88 Westy |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Fri Jun 25, 2010 10:00 am Post subject: |
One more vote for the pop top shocks. I'd say they are mandatory if you have a cargo box. Get the heavy duty ones.
Avoid putting heavy stuff in the cargo box. Use it for pillows, camp chairs, sleeping bags, duffel bag of of extra clothing, etc.
Yes, mounting the box farther back makes it easier to lift, but then you may need a ladder to access it. Mounting the box forward allows you to use the front right seat as a step to access your stuff without a ladder.
It's a trade off, but I like the box mounted toward the front so I can more easily get inside it.
Cheers,
CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
woggs1 Samba Member
Posted: Fri Jun 25, 2010 2:04 pm Post subject: |
climberjohn wrote: |
Cheers,
CJ |
I agree to get the heavy duty ones, the regular ones won't cut it for loads on top. My personal preference is to use a ladder to get to my cargo box. I load lots of heavy stuff up there. It also gives me a place to carry my extra gas.
Posted: Fri Jun 25, 2010 2:53 pm Post subject: My Load |
I have a triple level board carrier - heavy steel and I generally carry at least 3 boards along with my rocket box full of sails, booms, and chairs. Before hd shocks = 3 people to lift, after hd shocks I can do it myself. It takes effort but it makes life much easier. _________________ 1985 Westfalia 2.5L EJ |
PIRATE Samba Member
Posted: Fri Jun 25, 2010 5:20 pm Post subject: |
i thought i ordered the hd shocks but i better check because mine is impossible to get up with rocket box and surfboards mabey he sent me the wrong ones _________________ 2003 jetta wagon
1987 westfalia 2wd
1987 Syncro GL
1964 vespa vbb 150
1973 vespa sprint
Reyes Samba Member
Posted: Fri Jun 25, 2010 6:33 pm Post subject: |
Thanks again for all the info. As far as the yakima rack, can a auto body place install the racks for me, or would I take it to a mechanic? Also, my pop-up does not go at a diagonal, it is horizontal when lifted (it is a country homes pop-up).
It sounds like I should order to heavy duty shocks to have those installed at the same time as the yakima rack? |
