GreaterMook Samba Member
Posted: Sun Jul 18, 2010 12:10 pm Post subject: Carb Identification. |
I am always kinda in the dark talking about carbs on these cars. I have a Solex H30/31PICT that I got off of a 1300sp and am running on my 1500sp which I have never heard of, I always hear about 34PICT and what not, but I don't understand what the number means. Is there a chart that can explain the differences between all the VW carbs and what the numbers mean. are they flow ratings for CFM or what??? and what carbs are better used on what applications.
I'm just trying to expand my knowledge on these cars
thanks for all the info in advance! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Sun Jul 18, 2010 3:39 pm Post subject: |
The H30/31PICT is an all-purpose aftermarket carb, that combines elements from the 30PICT-3 and the later 31PICT-3 (non-USA 1300DP) and 34PICT-3 carbs.
Here's a long discussion I wrote a few years ago about the various stock carburetors and the H30:
http://www.thesamba.com/vw/forum/viewtopic.php?t=185095
Also, the number for the carb name is not flow, it's just the size of the carb - 28,30,31 or 34mm.
The PICT is a Solex abbreviation. Try reading this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=321962&
-Andy |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Jul 18, 2010 3:52 pm Post subject: |
The number indicates the size of the throttle bore. The letters indicate the version.
28PICT started with the '61 40hp and went to '65.
30PICT's were started in '66 1300, and were used in modified (smog) form on 1500 SP's up until at least '70 that I know of.
34PICT came on '71- 1600 DP engines which have a bigger intake to match.
H30/31PICT is the Brazilian replacement carb for all 30PICT's.
BTW HotVW's March '05 issue had an outline VW carbs, Type 1, 2, and 3.
OMG this is not as good an explanation as Andy's link! He must've wrote that as I was researching the numbers. There isn't much to add to that post! |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sun Jul 18, 2010 4:37 pm Post subject: |
Andy has written some great threads ( a few of which he linked ) and has posted a ton of helpful info on this and many other subjects. Personally, I learned a lot of details from his charts and posts starting years back that I was not aware of and it has helped me tremendously in the rebuilding of these carbs matching things up specific for the customer base I deal with.
I am in Houston area and can help you out if you get into a situation where the carb(s) you have just aren't working out for you. |
WD0AFQ Samba Member
Joined: August 14, 2008 Posts: 595 Location: Dexter, Mo.
Posted: Sun Jul 18, 2010 4:54 pm Post subject: |
I am running a 1600 dp with a Pict 30/31. I have a progressive Holley and intake but the little carb works so well I hate to mess with it. Do yall think this carb is too small for the 1600 dp? My car will run 85mph plus with it. Good information here.
Dan _________________ 66 baja
http://www.danandteri.blogspot.com |
Posted: Sun Jul 18, 2010 5:09 pm Post subject: |
No, it's not too small of a carb for that engine. I run a 30PICT-1 on my 1600DP in my baja and it does fine. Personally, I wouldn't even consider that progressive.
-Andy |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Sun Jul 18, 2010 6:15 pm Post subject: |
keifernet wrote: |
GreaterMook, Take him up on this offer, he's a great guy and knows his stuff about carburetors, he built mine and I couldn't be happier!
How's that for nutswingin'? _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
