'56 wolfsburg panel
joe56vw
joe56vw is offline
PostPosted: Sun Jul 18, 2010 8:36 pm    Post subject: '56 wolfsburg panel Reply with quote
been working on this bus for about 8 years now
here are some pics of it when i first got it
and pics since i have had it
some of the hard to find parts i collected for it
'60 15 window walkthrough
why is there no sarcasism button on here?
joe56vw
joe56vw is offline
PostPosted: Sun Jul 18, 2010 8:41 pm    Post subject: Reply with quote
some of the metal work i had done
after the rust repair was done
joe56vw
joe56vw is offline
PostPosted: Sun Jul 18, 2010 8:50 pm    Post subject: Reply with quote
so many parts i dont know where to start Confused
test fitting my new bumper, front and rear safari
joe56vw
joe56vw is offline
PostPosted: Sun Jul 18, 2010 8:52 pm    Post subject: Reply with quote
4 1/2 narrowed beam and drop spindles
brakes were a pita
and after two days of drilling and tapping new treads got my doors on
joe56vw
joe56vw is offline
PostPosted: Sun Jul 18, 2010 9:01 pm    Post subject: Reply with quote
back from the painters had a friend do a faxtina paint job on it
these pics don't do the paint job justice it looks really cool in person
the start of assembly
arriving at it's new home
had to put in into storage for a little while because of i moved
joe56vw
joe56vw is offline
PostPosted: Sun Jul 18, 2010 9:12 pm    Post subject: Reply with quote
after a long winters nap it finally came out of storage
let it dry out for a couple of days then i got in there and start
narrowing the rear end and finishing it
testing out the lights after i had a freind do a custom wiring job for it
joe56vw
joe56vw is offline
PostPosted: Sun Jul 18, 2010 9:22 pm    Post subject: Reply with quote
heres some pics with the bumpers on and the suspenions finished finally
finally got the motor in what a pita nothing fit right so it took forever Rolling Eyes
the oil filter had to be moved and the mufflers had to be bent down just to get the bumper brackets on
after a test run around the yard
azure63rag
azure63rag is offline
PostPosted: Mon Jul 19, 2010 12:11 am    Post subject: Reply with quote
Simply BadASS! Cool Cool
RA 70
RA 70 is offline
PostPosted: Mon Jul 19, 2010 12:16 am    Post subject: Reply with quote
Very nice.
Keysar
Samba Grammar Tutor
Keysar is offline
PostPosted: Mon Jul 19, 2010 12:23 am    Post subject: Reply with quote
I know what you mean man haha
Clara wrote:
...but mainly perfecting my tossing peanuts shells out the window into the air scoops technique.
cdennisg
cdennisg is offline
PostPosted: Mon Jul 19, 2010 1:44 pm    Post subject: Reply with quote
Was this bus at the Vintage Meet? If so, I'm sorry I missed it.
One point to mention. I think you're going to dislike having those dual mufflers scraping out back. A custom hideaway would be the way to go. I sold a complete setup including flanged heater boxes to match the exhaust for $50 on Saturday. It would have been perfect for your bus.
nothing
i_am_cool_fred
i_am_cool_fred is offline
PostPosted: Mon Jul 19, 2010 2:27 pm    Post subject: Reply with quote
what did you do on fixing the "window" that was cut into teh side? donor bus, or just flat metal with a bend?
how hard was it to weld in without warping?
proud owner of a defunct 1979 sunroof kombi
Brian Denning, as seen on Gearz TV
SkooobaSteve
SkooobaSteve is offline
PostPosted: Mon Jul 19, 2010 3:28 pm    Post subject: Reply with quote
I've done it, had cut a hole for a jealousy window into my panel used sheet metal and just took my time. Going slow was the best thing I could have done. Still some warping, (I was still learning,) but it did turn out nice.
Jonathan
Romans 6:13
WTB 67 beetle rear seat belts.
59 Euro ragtop build with my dad
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553&postdays=0&postorder=asc&start=0
65 dlx Slow build
http://www.thesamba.com/vw/forum/viewtopic.php?t=391061
Jerry Hundley
Jerry Hundley is offline
PostPosted: Mon Jul 19, 2010 8:12 pm    Post subject: Reply with quote
badass for sure Cool
Jerry Hundley (AKA Slammed 66)
Because Stock Sucks!!!!
70 baywindow deluxe
65 slammed bug
69 bug
64 drag buggy
50ate
50ate is offline
PostPosted: Mon Jul 19, 2010 10:08 pm    Post subject: Reply with quote
WTF does any of this have to do with a 56 wolfsburg pnl? correct me if im wrong as im not a "bus Guy" but man joe it looks good..
alex
joe56vw
joe56vw is offline
PostPosted: Mon Jul 19, 2010 11:43 pm    Post subject: Reply with quote
i had cut up another panel many years ago and i saved alot of donor metal from it
as far as the welding i just did small welds every 6" around the opening
joe56vw
joe56vw is offline
PostPosted: Mon Jul 19, 2010 11:48 pm    Post subject: Reply with quote
it was suppose to be at vintage but i had a little issue with the trailer
and it's not roadworthy yet so i couldn't drive it there
the mufflers are just temp. i am going to make some later on
joe56vw
joe56vw is offline
PostPosted: Fri Dec 16, 2011 11:22 pm    Post subject: Reply with quote
had to pull the beam out to fix some things so i thought i would raise the center pin while it was out
since it's narrowed 4 1/2" the shocks didn't line up so i made a bracket for them
it's first road test
finally after almost ten years it is drivable
Kelly
Kelly is offline
PostPosted: Sat Dec 17, 2011 6:43 am    Post subject: Reply with quote
looks good Joe. You should cruise down this way with it soon.
It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky
scottvw
scottvw is offline
PostPosted: Sat Dec 17, 2011 8:08 am    Post subject: Reply with quote
Cool bus. I like the stance.
