AlteWagen Troll
Posted: Wed Jul 21, 2010 10:40 am Post subject: Krylon close matches to factory colors |
Some interesting info on another thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=421762
Thought it might be more appropriate in the paint section for others to find easily.
Here are my findings
Krylon Jade green vs. L380 Turkis
pretty damn close!! Its a little bit lighter than the og turkis but good enough.
Krylon Cherry red vs. L456 Ruby red
Close but not as deep as true L456 ruby red, it is a little more bright red than the ruby.Its reported that Rustoleum Regal Red is a closer match.
Here are some pics from the thread matching other colors
Krylon Fusion River rock vs. L345 Light gray
Krylon Pebble gray is said to be a close match as well
Krylon Dover white vs. L82 Silver white
Krylon Almond vs. L87 Pearl White
Other reports from posters with no pics
Krylon Rust Tough Battle Ship grey is reported a close match for undercarriage factory primer. It does seem VW had different variations for their primer though.
Rust-Oleum Painter's Touch Gloss Ivory Bisque vs. L 282 Lotus White. And when I had trouble finding it, I also used Painter's Touch Heirloom White
Please add your matches with comparison shots against factory colors in non faded areas. |
AlteWagen Troll
Posted: Wed Jul 21, 2010 2:48 pm Post subject: |
Here is another one.
Krylon Honeydew Ambrosia vs. L289 Blue White
VERY CLOSE. Pic is bad due to lighting but on the left side almost under the seat frame where the og paint gets no sun exposure the krylon blends in perfectly!
Here are the two krylon colors together
Finally after 20 years the bus will have some color again!!
edit:
here is a picture of both Krylon honeydew and jade green (blue white/turkis) on the bus
jonny1309 Samba Member
Posted: Wed Jul 21, 2010 3:00 pm Post subject: |
Great idea derluftwagen. I was following the other thread thinking we need a krylon/rattle can thread of its own. _________________ Jonny
Barndoor Mafia wrote: |
Add a cop mustache, some cholo shades and a Doyers cap to the guy in the suit .......... Tocayo. |
scottvw wrote: |
kiss my ass Tom....I'm without centercaps right now. |
OgCalLook wrote: |
nothin' wrong with: Nose down - Ass up!! |
Ragman wrote: |
Did you tell her that Al Reed painted them? |
lonslo wrote: |
My tailbone still hurts like hell. |
Tri-Bus Samba Member
Joined: November 29, 2005 Posts: 732 Location: Butler PA
Posted: Wed Jul 28, 2010 5:30 pm Post subject: |
any close matches to the 73 white on westy's i think it was called pastel white _________________ 73 Westy
A VW team with a triathlon problem, or something like that.... |
gondiwindi Samba Member
Joined: December 12, 2006 Posts: 1195 Location: Tampa Bay, FL
Posted: Thu Jul 29, 2010 5:53 pm Post subject: |
I just bought the jade green for my bug. It's a little lighter than the OG, but will definitely work until I can wrap up the rest of the body work and get a pro-paint job. The spray nozzle is cool too. It went on quickly and smoothly. Good recommendation. |
zeroman Samba Member
Joined: February 05, 2010 Posts: 891 Location: Cane field
Posted: Fri Jul 30, 2010 1:51 am Post subject: |
I found rustoleum almond is almost 77 "polar white". Close enough to paint the seat belt dings on the door. _________________ 77 super convertible |
blacktruck Samba Member
Posted: Fri Jul 30, 2010 8:11 am Post subject: |
Krylon Jade green......trying to locate this particular color on the krylon site is maddening.All I could spot was a satin jade, |
AlteWagen Troll
Posted: Wed Aug 18, 2010 6:25 pm Post subject: |
grazie
looks good |
simspot Samba Member
Joined: June 26, 2007 Posts: 7 Location: Stockton,Ca.
Posted: Wed Aug 25, 2010 11:41 am Post subject: jade green Krylon |
anthracitedub Samba Member
Posted: Wed Aug 25, 2010 6:58 pm Post subject: |
I went to Tractor Supply Store and bought a gallon on Massey Ferguson grey enamel…its a dead ringer for L469 anthracite. I did a spray out and placed it on top of my anthracite beetle…not even a shade different! 32$ a gallon. |
eguti66 Samba Member
Joined: July 21, 2004 Posts: 260 Location: Stockton,CA
Posted: Thu Aug 26, 2010 1:20 pm Post subject: |
I have a question, My bus is suppose to be turkis/Blue white which i will use the the Krylon jade / Honeydew. What white should i use for the bumpers and window frames? _________________
drscope wrote: |
Ummmm, if you can't find out where the hole is by feeling around, then FORGET about installing the light! |
66 beetle
65 karmann ghia
58 beetle
58 convertible beetle
64 11w standard
68 Squareback |
AlteWagen Troll
eschmidt14 Samba Member
Joined: March 01, 2008 Posts: 124 Location: Nassau Bay, TX
Posted: Sun Sep 05, 2010 9:42 am Post subject: |
Is there a close match for a L31K sunset orange or L20B brilliant orange?
Thanks,Eric |
Floridian Samba Member
Posted: Mon Sep 06, 2010 8:33 am Post subject: |
eschmidt14 wrote: |
Thanks,Eric |
http://cgi.ebay.com/New-KRYLON-52411-PUMPKIN-ORANG...2c5712a365
Using the ebay link for reference maybe Pumpkin Orange would be the closest when compared to Brilliant Orange ......This colors does kind looks like Hugger Orange to me - late 60's GM OEM color...
The link also has a chart that shows Krylon colors that some look close to VW OEM colors...Using this chart could help to get close to the color that is desired.. |
AlteWagen Troll
AlteWagen Troll
AlteWagen Troll
Posted: Sat Sep 18, 2010 2:39 pm Post subject: |
Another from split forum
http://www.thesamba.com/vw/forum/viewtopic.php?t=432538
tstracy39 wrote: |
I'm doing a little gauge restoration/customization and have come to the point of needing to match the paint colors that appear on the speedo and clock needles. I was planning on mixing up a small bit of alkyd enamel to do the job, but it turns out I might not need to. I went to the hardware store and the first two spray cans I tested out turned out to be very close to the original colors. They are:
Standard Rustoleum brand: "French Roast" spraypaint. Very close to the (Chestnut?) brown paint used to paint parts of the clock and speedo.
Standard Rustoleum Brand: "Almond" spraypaint. Very close to the off-white paint used to paint the needles and numbers etc.
These are both gloss paints, but can be matted out with a coat of Rustoleum Crystal Clear Matte Finish.
I promise to update with a few pictures once my parts are complete enough to start painting. I apologize in advance if it takes awhile. |
_________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
OvalinAz Samba Mini Tech
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sun Sep 26, 2010 7:24 am Post subject: |
Krylon Honeydew is Krylon #2335 |
