Paint Detailing Repro Fuchs?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Stretch32
Stretch32 is offline
PostPosted: Fri Jul 30, 2010 8:12 am    Post subject: Paint Detailing Repro Fuchs? Reply with quote
I'm planning to buy a set of Flat-4 Fuchs soon and wanted to paint detail them. My question is, can I paint the chrome version without having to strip the chrome off first? Would it be easier and more durable to just buy the polished versions and paint those? I've seen guys paint the chrome versions before but I wonder how well the paint actually sticks or if they use a certain prep method before laying down the paint. If I went with the chrome ones I thought I'd use some "liquid sandpaper" as a surfacer to help the paint adhere better (it worked well when I repainted my BRM's). Any thoughts or ideas from the painters would be appreciated before I decide which ones to get. Thanks in advance,
Stretch
Stretch32
PostPosted: Sun Aug 01, 2010 8:20 am    Post subject: Reply with quote
A Quick Edit: I bought the chrome versions since I felt they looked so much better. Anybody have any ideas about how to lay paint on them without it flaking off in a few days? I've never tried to paint a chrome wheel before so I'm at a loss right now. Any help would be great. Thanks again,
Stretch
'61transporter
'61transporter is offline
PostPosted: Sun Aug 01, 2010 4:03 pm    Post subject: Reply with quote
Hey,
If you really want to make your Flat-4's look awesome, I would say strip off the chrome first, and then paint it. Without stripping the chrome, your detailing is gonna look rough. Good luck!
-'61transporter
Are ya feelin lucky punk? Well, are ya?
scottz
scottz is offline
PostPosted: Mon Aug 02, 2010 8:12 pm    Post subject: Reply with quote
Nope. You do not need to strip the chrome. I painted my chrome Flat fours a few months ago and the came out great!
Basicly you use an adhesion promoter. It's made to help paint stick to chrome or plastics.
The brand I used was called buldog.
Roughed up the area with 80 grit sand paper by hand.
Then use the Bulldog adhesion promoter, then sealer (if it's smooth enough) I used a black sealer.
Then I used a single stage gloss black.
Sanded.
Adhesion promoter.
Black sealer.
Paint.
Done.
And DONE! Cool
Stretch32
PostPosted: Mon Aug 02, 2010 8:18 pm    Post subject: Reply with quote
Cool, I also got Bulldog adhesion promoter and I roughed up the surface with some scotch bright pads and sandpaper. I just sprayed the adhesion promoter then layed the paint on. I didn't use a sealer so I'm hoping there won't be any adverse affects. The first rim is actually drying as I'm typing this so I'll see how it all works out once he tape comes off. Thanks for the replies,
Stretch
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Tue Aug 03, 2010 8:50 am    Post subject: Reply with quote
Great job scottz!! Are those ISP caps?
Looking for aluminum single port Kadron manifolds.
scottz
scottz is offline
PostPosted: Tue Aug 03, 2010 2:32 pm    Post subject: Reply with quote
Thanks! Yes they are ISP caps, great product!!
Stretch32
PostPosted: Tue Aug 03, 2010 5:54 pm    Post subject: Reply with quote
I've got the chrome center caps painted (pretty tedious work) and one 4.5 chrome rim painted so far with the others to follow soon. I used a slightly more flat black to paint the rim since it appears most original Fuchs were detailed in a dull black. Thanks again for the help,
Stretch
LeviMan2001
Samba Post Whore
LeviMan2001 is offline
PostPosted: Tue Aug 03, 2010 6:12 pm    Post subject: Reply with quote
Stretch
If you're going for original how come it's chrome?
http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs
my65rhd
my65rhd is offline
PostPosted: Thu Aug 12, 2010 5:18 pm    Post subject: Reply with quote
I sure need to detail my fuchs...Looking good guys....Kyle
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Thu Aug 12, 2010 7:35 pm    Post subject: Reply with quote
Stretch32 wrote:
Killer detail job on the caps. I see the "stuttgart" was just too crazy to tackle!
Stretch32
PostPosted: Fri Aug 13, 2010 2:59 pm    Post subject: Reply with quote
Well, I finally got them all painted with center caps installed. Hopefully the paint will prove to be more durable than I think. Here they are mounted on the car with 4 wheel disc brakes along with a CB 2" narrowed adjustable beam and dropped spindles.
69 Jim
69 Jim is offline
PostPosted: Fri Aug 13, 2010 3:01 pm    Post subject: Reply with quote
Well done. Cool
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Fri Aug 13, 2010 7:40 pm    Post subject: Reply with quote
Stretch32 wrote:
Yep great job, and much $pent so far to get there. A little more knuckle busting on that rear end and a little tweak to the front adjusters and it will all really pay off.
EMPIFLAKE
EMPIFLAKE is offline
PostPosted: Tue Aug 17, 2010 7:43 pm    Post subject: Reply with quote
glandnut wrote:
Look's dope!! Wink Did this car use to have raders???
Stretch32
PostPosted: Tue Aug 17, 2010 9:40 pm    Post subject: Reply with quote
Thanks,
No, it had BRM's on stock drum brakes for awhile which I now have listed in the classifieds. Unfortunately I can't run them anymore since I've converted to 5x130 discs.
EMPIFLAKE
PostPosted: Wed Aug 18, 2010 6:55 am    Post subject: Reply with quote
Stretch32 wrote:
Thanks,
Just checkin to see if I know you your car is very familiar this is my 62!
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Wed Aug 18, 2010 11:45 am    Post subject: Reply with quote
You're thinking of Aarons car with the type IV on Raders up here...
Stretch32
PostPosted: Wed Aug 18, 2010 12:19 pm    Post subject: Reply with quote
I use to live in Jacksonville but I didn't have BRM's installed when I did. It was basically stock with stock wheels. I did go to a few local shows and drive ins as well as Bug Jam a few times when I lived there. I'm pretty sure I've seen the '66 your talking about with Raders in Jax a few times. Very nice car.
Stretch
hkoch
hkoch is offline
PostPosted: Tue Sep 20, 2016 4:59 pm    Post subject: Re: Paint Detailing Repro Fuchs? Reply with quote
Bringing this post back up. How has the paint been holding up on the chrome. Getting ready to detail and set of repos myself.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
