stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Wed Aug 04, 2010 10:24 am Post subject: Radiator card board deflectors |
I am replacing the radiator and in the process of doing this, the two card boards at both side of the radiator just fell apart in pieces. Can I leave them out or should I get new ones at a cost of $32 ? _________________ Steve
87 Westfalia full camper 4 speed |
pinealservo Samba Member
Posted: Wed Aug 04, 2010 10:49 am Post subject: |
I'd replace them either with the $32 replacements or something custom. Doesn't do your cooling system much good if the air going into the nose goes around the radiator instead of through it, and there's a lot of space to fill there. |
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Wed Aug 04, 2010 10:54 am Post subject: |
I replaced the two I could order... the bottom and left, if I recall correctly. The other side appeared to be NLA and was in good enough shape that I reused it.
pd _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
SouthOlive Samba Member
Joined: October 31, 2009 Posts: 133 Location: The Nexus of Crisis
Posted: Wed Aug 04, 2010 10:57 am Post subject: |
Quote: |
Can I leave them out or should I get new ones at a cost of $32 ? |
Mine are missing too, where are they available? _________________ 1985 Westy
2011 GTI |
Posted: Wed Aug 04, 2010 11:01 am Post subject: |
SouthOlive wrote: |
Mine are missing too, where are they available? |
I bought mine at Van-Cafe.
GeeZ12 Samba Member
Posted: Wed Aug 04, 2010 11:02 am Post subject: |
I use the foam pipe insulation you get from hardware stores or 'noodles' you get for your kids to play in swimming pools - comes in 4 ft lengths - just cut and compress to fit around the radiator.
just my 2¢ |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Wed Aug 04, 2010 11:13 am Post subject: |
I haven't done this, but i remember someone in another thread had this idea, and it sounds plausible....and cheap! Use your old crumbling pieces of cardboard to use as a template, and cut new ones from corrugated plastic. So where do you find corrugated plastic, you may ask. Well, your neighborhood intersection probably has some sitting around. it will look like this:
or like this:
paint it with a nice Krylon Fusion paint in a flat black, and there ya go. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
randywebb Samba Member
Posted: Wed Aug 04, 2010 12:59 pm Post subject: |
mine are intact, but warped
any ideas on how to hold them in place when I put the Grill back on? _________________ 1986 2.1L Westy 2wd Auto Trans. |
OhChit Samba Member
Posted: Wed Aug 04, 2010 2:21 pm Post subject: |
I recently did a set on a friends Van when upgrading his radiator, he picked up some of that Black Arts and Crafts Foam Poster Board from one of the marts. It worked out faily well and we just zipped tied the sides in place using a few black wire ties, on the bottom we used the screw locations. I think that the plastic yard signs might be a little more sturdy and thought that I remembered seeing that forsale also in black in AC More etc Arts and Crafts section. _________________ Fast Cars, and Slow Women Makes me DrooL. |
Californio Samba Member
Posted: Wed Aug 04, 2010 3:00 pm Post subject: |
Aluminum flashing. Cut with scissors to fit both sides and the bottom, lasts forever. I covered mine with sound deadener and then foil insulation after installing. |
Posted: Wed Aug 04, 2010 3:11 pm Post subject: |
The guy at Van-Cafe suggested that roofing felt (folks call it "tarpaper") has been suggested, and I considered scavenging some from a roofing job and laminating it with contact cement to build it up to 3/16" or so. I decided the one used piece I had to reuse was good enough, though... it was tired but not disintegrated.
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Wed Aug 04, 2010 3:30 pm Post subject: |
I don't know re the condition of mine as I did not know of their existance and if I even have them. Can the absence of these lead to coolant system boiling? _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
tencentlife Samba Member
Posted: Wed Aug 04, 2010 4:11 pm Post subject: |
They do very little, if your cooling system is otherwise in good working order you would never notice they were missing.
I have a customer's van that is getting a new radiator and he ordered the panels new from VC. I'm going to install them but if it was my own van, even with a used radiator I wouldn't bother with them, with a new rad I definitely wouldn't bother. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
DAIZEE Samba Member
Posted: Wed Aug 04, 2010 4:22 pm Post subject: |
thanks. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Posted: Wed Aug 04, 2010 4:25 pm Post subject: |
Just the comment I wanted to hear. Thanks 10c. _________________ Steve
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Sun Aug 08, 2010 3:11 am Post subject: |
I've run mine with some of them missing and the original radiator. When I replaced the radiator I bought new ones from the Bus Depot and this year I discovered that one side of grill was missing it's deflector so I made one with several layers of roofing felt.
Bottom line thought is that I have seen not improvement in cooling with or without them. _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
Posted: Sun Aug 08, 2010 7:04 am Post subject: |
The way I see it the one across the bottom is the only one that even conceivably raises pressure on the front face of the rad, and even that would be negligible because the pressure there is already high and once it touches the front of the rad the air is too viscous to escape the fins. It would be like the diffference between going 50 mph and 50.5 mph. The side ones couldn't produce any effect to speak of, there's barely any gap for them to fill. Yet another of VW's solutions in search of a problem. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Sun Aug 08, 2010 10:30 am Post subject: |
tencentlife wrote: |
I have a customer's van that is getting a new radiator and he ordered the panels new from VC. I'm going to install them but if it was my own van, even with a used radiator I wouldn't bother with them, with a new rad I definitely wouldn't bother. |
On my engine swap, that was one of those details I was going to get around to once it was running. Never did. The lack of deflectors doesn't seem to be an issue. The cooling system is in good shape.
1988 West DIY 50º ABA
VE7TBN |
