body chassis bolts
laughatgravity
laughatgravity is offline
PostPosted: Wed Aug 18, 2010 1:05 pm    Post subject: body chassis bolts Reply with quote
10mm right? what is is the pitch? I want to tap and die the bolts and nuts.
also Im pretty sure a few on my nuts on the inside broke off maybe one is the bulk head too... any helpful suggestions? this winter i plan to replace the pans, and am thinking that i could cut access holes to pull out the broken one and welding new ones on.
ConchThing
ConchThing is offline
PostPosted: Wed Aug 18, 2010 2:55 pm    Post subject: Reply with quote
not sure of the size but TTS has the set, all 24, for a pretty decent price, including the washers. As for the amputee...maybe a magnet some how? Only idea that comes to mind Confused
'74 Thing,
'bones up' resto
63ziggy
63ziggy is offline
PostPosted: Wed Aug 18, 2010 4:53 pm    Post subject: Reply with quote
will have to check, some reason 8 x 1.25 pitch sounds familar.
the common 10 on the vehicle is 10 x 1.5 pitch I believe
View user's profile Send private message Send e-mail AIM Address Instagram Gallery Classifieds Feedback
Tingman
Tingman is offline
PostPosted: Wed Aug 18, 2010 10:19 pm    Post subject: Reply with quote
Get some weld nuts, (they have flanges on them). Where the holes for the nuts that are bad drill them out to the diameter of weld nut, but not larger than the flange. Push the nut into the hole and weld the flange to the surrounding metal.
73 Thing (current project)
84 300SD Mercedes (diesel)
86 300SDL Mercedes (diesel)
03 230SLK Mercedes
Semper_Dad
Semper_Dad is offline
PostPosted: Wed Aug 18, 2010 11:18 pm    Post subject: Reply with quote
74 VW Thing - Walküre (Now Project)
laughatgravity
PostPosted: Thu Aug 19, 2010 6:02 am    Post subject: Reply with quote
8 x 1.25 pitch is fender bolts.
I have a million of them, set from my car, set from donor car, 3 sets that the PO had. im going chose the best and clean the threads.
Thanks didnt think of those, seen em before but never installed. do I indent the metal to accept the flange? grind down the flange at all or just let it be?
I guess the body seal could handle the unevenness
locky
locky is offline
PostPosted: Thu Aug 19, 2010 8:19 am    Post subject: Reply with quote
I just replaced about 20 of these. Time consuming to say the least. I used my plasma cutter to cut the old nuts out. Then I took some 18 gauge sheet metal and cut it to the proper width and length, leaving extra to overlap my hole. I then took my fender and bolted it on one of the old nuts. Then very carefully took my patch metal and slid it in behind the fender to the correct place and used a jiffy to mark the hole. I then pulled the piece back out and drilled a hole on my mark. Next I flipped that piece over and welded my new nut in place. I then took that piece back to it's spot and slid it back in overlapping over my hole to the correct spot. Then slid the bolt in to make sure it fit. I then took my marker and marked the edges of my patch on my fender well and pulled everything out, and lap welded the piece in. I did this procedure for all of them, taking my time to make sure they fit. Once welded in, grind down the welds with a flap wheel and fill with glass.
locky
locky is offline
PostPosted: Thu Aug 19, 2010 8:21 am    Post subject: Reply with quote
I got my nuts from Kubelman
