flywheel puller
Page: Previous  1, 2
Greezy Joe
Greezy Joe is offline
PostPosted: Thu Aug 26, 2010 5:45 am    Post subject: Reply with quote
Wow, really trying to follow the need for a flywheel puller for a VW engine. Been using 2 Snap-on prybars for 40 years, even with 8 dowel cranks, no problem. Gently wiggle and then apply some steady easy pressure and they are off. Nothing has ever been damaged. Each to his own but sounds like a Mountian is being made out of a Mole Hill. Laughing Laughing
Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound".
bugnut68
bugnut68 is offline
PostPosted: Thu Aug 26, 2010 8:44 am    Post subject: Reply with quote
I just paid good money to have my crank and flywheel drilled for 11/32" oversize dowel pins. While it's possible I may not round out the holes trying to pry the thing off, I'm trying to avoid any damage whatsoever as I don't trust myself... Laughing
I'm in a situation where I can't afford to have to do things twice, as where I live there's absolutely no one that knows how to work on performance VW engines.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
earthquake
earthquake is offline
PostPosted: Thu Aug 26, 2010 9:42 am    Post subject: Reply with quote
Greezy Joe
Have you ever tried to remove a "Wedge Mated" flywheel? with out a puller its a bitch. I have never tried the hammer trick but I might next time I have to pull a FW.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Kelly J. Nolte 3/20/53 - 11/6/08
http://www.rememberingkelly.com/
DEATH TO CHINGERS!
Greezy Joe
PostPosted: Thu Aug 26, 2010 8:26 pm    Post subject: Reply with quote
earthquake wrote:
Greezy Joe
Casey
Nope, never even seen one other than in a picture. I thought about adding that to the post to say "If it is Wedgemated, all bets are off" Laughing
07 GMC Truck
12 Jeep Wrangler
damicotile
damicotile is offline
PostPosted: Fri Aug 27, 2010 6:04 am    Post subject: Reply with quote
I never posted a pic of the puller I finally made.
I made it from some scrap steel I had lying around.
So here it is. Quite simple to make.
I aim to trim away some of the steel to make it more user friendly.
It's 3/4" thick. I used a bolt from a gear puller for the center.
'73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________
agggilli
agggilli is offline
PostPosted: Sat Apr 30, 2011 5:45 am    Post subject: Reply with quote
Holy crap! At 3/4" thick, the weight of the plate itself should have pulled the flywheel off! Shocked Seriously though, trim it down to match the flywheel and you have yourself a tool that will last a lifetime and then some. I just got a piece of 2" x 1/2" bar stock I'll be using to make a puller this morning.
jbbugs
jbbugs is offline
PostPosted: Sat Apr 30, 2011 5:53 am    Post subject: Reply with quote
Don't drop that beast on your foot!
Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
57'tubeframe dragbug
73' Super Beetle Chumpcar Endurance roadracer
Patina my ass, that's a Rust Bucket!
www.jbbugs.com
bugnut68
bugnut68 is offline
PostPosted: Sat Apr 30, 2011 3:28 pm    Post subject: Reply with quote
A buddy of mine gave me a tip that proved valuable in getting the flywheel off, at least for a non-wedgemated flywheel. Insert a large screwdriver behind the flywheel and wedge it against the webbing of the case. While prying with steady pressure, rap on the outer rim of the flywheel with a hammer. The ringing vibration will work it loose. Worked like a charm for me, and didn't mess up my dowel pin holes.
RockCrusher
RockCrusher is offline
PostPosted: Sat Apr 30, 2011 8:48 pm    Post subject: Reply with quote
Ok....here is the double secret RC Wedgemate flywheel removal technique. Shhh Don't tell anyone about this.........
Use the sensor hole that is in some blocks and insert a 1/2" steel rod to contact the FW and whap it with the hammer once then turn the FW 180* and whap again, done. On new blocks we drill the sensor hole. This works for regular FW's also...just dont go crazy. Wedge a screw driver or prybar in opposite where the hole is and tap the rod thru the hole. Your FW will walk right off. Be sure to leave the gland nut in there a thread or two so the FW doesn't take a dive.
RC
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
Page: Previous  1, 2
Page 2 of 2
