1957 117 my daughter calls jack
Page: 1, 2, 3, 4, 5, 6  Next
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Thu Aug 05, 2010 8:22 pm    Post subject: 1957 117 my daughter calls jack Reply with quote
figured now that i am actually working on the beetle i would get a topic going for it. i brought this home the last day of 2009 and put it under wraps and by and large havent touched it untill recently mostly as i had a bus to finish immediate loose ends on.
car is a oregon titled to the motor car off the road since the 70s original unmolested car
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Thu Aug 05, 2010 8:25 pm    Post subject: Reply with quote
the immediate plans are to ge it running and collect for a eventual restore
1958 custom camper
1957 oval
1957 dd kombi
rud helsen
rud helsen is offline
PostPosted: Thu Aug 05, 2010 11:39 pm    Post subject: Reply with quote
nice oval! good luck with it!
love th interior too! Razz
ricky.santillan
ricky.santillan is offline
PostPosted: Fri Aug 06, 2010 12:18 am    Post subject: Reply with quote
Nice ragtop too!
Schwing
Schwing is offline
PostPosted: Fri Aug 06, 2010 8:11 am    Post subject: Reply with quote
Slow nice rag! This must be what the sheet metal is needed for, pretty funny since mine is a black with red interior 57 rag as well.
I am cutting the metal off the original door that was on my car but had some hinge issues and some crinkle-age.
Good stuff I wish my oval looked like yours!
Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Fri Aug 06, 2010 8:36 am    Post subject: Reply with quote
thanks guys i have been dying to start working on this one so i started a little bumping and straightening
hood
front clip
passenger fender
drivers side
going to be focusing on driveline this weekend
1958 custom camper
1957 oval
1957 dd kombi
left_coast*9
left_coast*9 is offline
PostPosted: Fri Aug 06, 2010 9:01 am    Post subject: Reply with quote
Nice man, I thought you might have a little rag top up your sleeve. Glad to see you've got it posted for all to enjoy. Nice start to a very nice car!
Jet City 1957 VW Oval Rag Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=408791
1965 Sea Blue Beetle Sedan
http://www.thesamba.com/vw/forum/viewtopic.php?t=472827&postdays=0&postorder=asc&start=0
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Fri Aug 06, 2010 9:13 am    Post subject: Reply with quote
a long way from where you are at but i will get there....gonna have to drive it while i collect parts
1958 custom camper
1957 oval
1957 dd kombi
aa390392
aa390392 is offline
PostPosted: Fri Aug 06, 2010 9:14 am    Post subject: Reply with quote
good luck and have fun..
1956 111
1956 151
1967 111
1967 111
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sat Aug 07, 2010 7:53 pm    Post subject: Reply with quote
made some more ground on the original motor today. the motor was with the car uninstalled when i got it. very dusty dirty but not oily greasy
after getting flucuating readings checking the end play i thought i should dig deeper. pulling the flywheel i discovered nos blue inkstamped thrust shimms. i scoped the plug hole to see clean crisp cylinders. dropped the valve covers and found no rockers intalled or pushrods. decided i better keep digging
all hopes of a quick assembly and go are now gone.
total crud wall behind the gallery plug. time to start cracking the case
head for 1/2 was upbeat
head for 3/4 just as crisp
once i pulled the cylinders even more evidence the tear down was a good choice it was like this on all 4
got the case cracked all new bearings reqround crank rebushed rods new cam. to clean the case and start putting it back together i got the slide hammer out and pulled all the plugs
went ahead and fit all my new galley plugs as well
hopefully this seattle weather will blow over and i can do some plumbing on the chasis tommorow if not might just start cleaning for my engine reassembly
1958 custom camper
1957 oval
1957 dd kombi
OvalinAz
Samba Mini Tech
OvalinAz is offline
PostPosted: Sat Aug 07, 2010 9:49 pm    Post subject: Reply with quote
nice car man how did you fix the rip in the fender, Sorry if this is a stupid question, lol
8/56 Oval
5/64 French Notchback
12/62 French 11 Window Bus
chromies should be outlawed and thrown in the trash
Pandraggers C.C.
camerod
Volksfab
camerod is online now
PostPosted: Tue Aug 24, 2010 8:55 pm    Post subject: Reply with quote
WOW you have been making serious progress! nice score on all of the "new" engine parts!
DON'T SHIT WHERE YOU EAT!
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Sep 05, 2010 3:32 pm    Post subject: Reply with quote
got a little more forward progress
got the crank set back together with new bearings
number four rod was at minimum side clearance so i had to pull it back off and clearance a little
everything went in clean
i was able to reuse all the original hardware
all sealed up
a few more nice details
.004" thrust
1958 custom camper
1957 oval
1957 dd kombi
left_coast*9
PostPosted: Sun Sep 05, 2010 3:46 pm    Post subject: Reply with quote
Wow man, I'm impressed, looking good! Wish I had the know-how to rebuild a VW motor. I'm sure I could teach myself how to do it with all the good books, videos, etc. out there, but still. If I had the OG motor to my car, I think I'd do it. Since that's not the case, I'm going with a 2276! Nice work man, keep it up. My build has been slowed by GD house repairs. Evil or Very Mad
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Sep 05, 2010 5:13 pm    Post subject: Reply with quote
i have a bigger motor going on the stand next. it has been sitting here in parts for years.i doubt i will ever put it in the oval.
1958 custom camper
1957 oval
1957 dd kombi
Schwing
Schwing is offline
PostPosted: Sun Sep 05, 2010 7:29 pm    Post subject: Reply with quote
slow looks nice!
I'm saving all of your pics please take more and share in this thread.
Thanks! Cool
Shadetree Westy
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Tue Sep 07, 2010 8:27 pm    Post subject: Reply with quote
spent my little available time today cleaning and sorting the valve train. hope to have the heads on in the next two nights
1958 custom camper
1957 oval
1957 dd kombi
Schwing
Schwing is offline
PostPosted: Wed Sep 08, 2010 6:47 am    Post subject: Reply with quote
I did the very same thing on Monday. Cleaned all the parts I had soaking in oil since I disassembled the engine - oil pump, various nuts and bolts, cam plug, etc.
I checked your engine # and it looks like you have a Feb '57, mine is about 2 months older - Apr '57, almost the identical car 2 months apart, pretty cool.
Keep snapping pics please of your engine build very very helpful along with everything else I have been saving (like the 36 engine rebuild step by step in the July '98 issue of Motor Trends)
Shadetree Westy
Rich's 50
Rich's 50 is offline
PostPosted: Wed Sep 08, 2010 6:49 am    Post subject: Reply with quote
Looking good Cool
FOLK'S THOUGHT YOU KNEW..........
Schwing
Schwing is offline
PostPosted: Wed Sep 08, 2010 7:11 am    Post subject: Reply with quote
Can I ask you where you got your engine stand? And approx how much? Worth it or is a shop bench ok if thats all I have?
Shadetree Westy
Page 1 of 6
