stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Sat May 08, 2010 12:09 pm Post subject: 2-way windshield washer nozzles that fits - edited |
I have tested the 2-way washer jets from a 76-85 Porsche 911 and they fit without mod. The jets of water can be adjusted to hit the middle of the windshield at the extreme position of the adjustment. You should really adjust it so they hit the top of the windshield at stationary and then the water jets will hit the middle of the wind shield when you are driving at speed.
Cost is $8.25 not cheap but worth it. I have tested only the ones from Pelican parts so nozzles from other vendors may be different. Part number is 914-628-203-11-M78
http://www.pelicanparts.com/cgi-bin/smart/more_inf...1976-85%29
Edit:
The Porsche nozzle stands 6mm above the body panel and the OE nozzle stands 18mm above. So the jets are shooting at the glass at a much lower angle than the OE jets. That make it difficult to adjust the jets as a little angle change will results a big movement of where the water land on the windshield. The van I put the Porsche jets on has the chrome plastic insert and it stick out above the rubber. The water jets just barely clear that molding. You need lots and lots of patience to adjust the jets but you only need to do it once.
Also, the Porsche jets has a smaller base than the OE jet, so it will not cover up the old markings made by the old jets. The ends that goes into the body is exactly the same as the OE jets. _________________ Steve
87 Westfalia full camper 4 speed
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Sat May 08, 2010 6:30 pm Post subject: |
Oh NO!
Impulse buy!
Am now $23 poorer.
Hope they work... _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Sat May 08, 2010 7:55 pm Post subject: |
How about some pics of them installed and in use? Thanks for the post. It's to late for me as I got the 3 jet washers from the UK. $$$$$, but really nice. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
tripod808 Samba Member
Posted: Sat May 08, 2010 9:55 pm Post subject: |
I was close to biting the bullet for the smart nozzles, I'm glad someone found a cheaper alternative.
Pictures please! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
insyncro Banned
Posted: Sun May 09, 2010 4:26 pm Post subject: |
Good lookin' out.
The whole Smart Car noozle deal seamed like a waste to me.
All that money for something that doesn't fit.
Thanks Porsche. |
goffoz Samba Member
Posted: Sun May 09, 2010 7:56 pm Post subject: |
just FYI the nozzles from a 1999 and earlier, mercury villagers work well.they stand 2" tall and have adjustable dual sqirters.
(2000 and later have smaller units)
The fit is different but an easy mod.
I snagged both nozzles, all the plumbing with check valves, for $7 from a P&P |
insyncro Banned
Posted: Mon May 10, 2010 5:22 am Post subject: |
goffoz wrote: |
pictures please. |
Classicvibe Samba Member
Joined: August 03, 2009 Posts: 743 Location: Salt Lake City
Posted: Mon May 10, 2010 8:09 am Post subject: |
Pictures people! Get out your cameras and snap some pics. "Fit" is a very relative term, as there are many interpretations on just what constitutes a good "fit." The are complicated little buggers... _________________ On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter |
kevinm Samba Member
Joined: September 08, 2008 Posts: 117 Location: Minneapolis, MN
Posted: Mon May 10, 2010 6:51 pm Post subject: |
How does one remove the existing nozzles without scratching the paint? Do you just slip a thin piece of plastic under them to push in the tabs?
- Kevin |
Posted: Mon May 10, 2010 9:22 pm Post subject: |
kevinm wrote: |
- Kevin |
Clamp onto them with a pair of Vise-grips and twist a quarter of a turn. This will destroy the tabs on the nozzles, so make sure you have a replacement before removing the old ones. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Mon May 10, 2010 9:29 pm Post subject: |
The van I put the Porsche jets on has the chrome plastic insert and it stick out above the rubber. The water jets just barely clear that molding. |
Have you driven the van at freeway speeds and verified that it still works? This is the reason why the cheap 2nd gen SMART car nozzles aren't a good solution. |
Posted: Tue Sep 28, 2010 9:46 am Post subject: |
syncrodoka wrote: |
Bump.
Yes.
I installed one on the driver's side. If anything these squirters spray too high and they have to be adjusted down almost to the limit.
Works nicely, though. 6 months or so now. _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Tue Sep 28, 2010 1:46 pm Post subject: |
but still no pictures. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
Posted: Tue Sep 28, 2010 2:19 pm Post subject: |
Sorry..
The van is kind dirty. _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
Posted: Tue Sep 28, 2010 2:24 pm Post subject: |
So, it looks like a narrow window to clear the molding and still hit the windshield? Easy adjustment? The $60 ones sold by another Sambanista rise like 3/4" to clear that molding hurdle. Comments? Also, how do we find that squirter? Thanks for the update! _________________ On a mission, the destination is just an excuse.
Thanks. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
jerrydog411 Samba Member
Joined: September 28, 2009 Posts: 388 Location: North Vancouver, BC
Posted: Tue Sep 28, 2010 2:54 pm Post subject: |
Thanks a bunch ... I ordered a couple of pairs for my & my buddy's van.
Cheers,
John |
Posted: Tue Sep 28, 2010 4:33 pm Post subject: |
Classicvibe wrote: |
So, it looks like a narrow window to clear the molding and still hit the windshield? Easy adjustment? The $60 ones sold by another Sambanista rise like 3/4" to clear that molding hurdle. Comments? Also, how do we find that squirter? Thanks for the update! |
Exactly.
Yeah.. it takes a couple trial and error adjustments.. but you'll find the zone.
The particular part and the supplier is linked up in the first post. (Thanks Steve88!) _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
Posted: Tue Sep 28, 2010 6:06 pm Post subject: |
j dirge,
With only one dual jet installed, how can you stand it with one side of the windshield can be washed cleaner than the other side ?
BTW, what is ' Outer Sunset " ? I go to 30th X Ortega all the time. _________________ Steve
87 Westfalia full camper 4 speed |
