Bones 53 Samba Member
Joined: February 19, 2005 Posts: 661 Location: Reno NV
Posted: Sun Oct 03, 2010 6:41 am Post subject: Mallory's start retard question |
The digital VI has a start retard function and I'm not certain what the purpose is. I have been a bit disappointed in the way the car starts with the mallory system. It does not fire at the twitch of the key as it did with the bosch stuff but instead takes a few more revolutions to fire up. I tried setting the retard function both up and down but don't really see a change. This is with a unilite, digital hyfire box and mallory coil. Initial timing is set at 10 and total is 32. Elevation is 4800 feet.
Does anyone have experience with the start function adjustment? Thanks |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Sun Oct 03, 2010 6:43 am Post subject: |
if you are not running a pretty substantial compression ratio, you probably don't need the start retard... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
vdubnut58 Samba Member
Posted: Sun Oct 03, 2010 7:37 am Post subject: |
The purpose of the start retard is so you can run a lot of initial timing. You can even lock it out at 32 but have the retard set to start the motor on 8. Adjusting this won't make your car start at the twitch of the key. Since your have a start retard you should try 8* for start up 22* at idle 32* total and see how your car runs. I have my msd set up with the largest bushing so it only allows for 12* of advance. So I run 20* with 32* My msd fires instantly |
Posted: Sun Oct 03, 2010 7:47 am Post subject: |
Thanks for the info. I'm running 9.6:1 so not too much at this elevation with a K10. I'll mess with it some more. |
