yrgecheffe Samba Member
Joined: July 25, 2006 Posts: 9 Location: Lethbridge, Alberta Canada
Posted: Mon Jul 19, 2010 6:52 am Post subject: Hang on we can add Nitrous to the mix!!!! ???? |
Sounds great i will post a pics of my bus etc so you can see what i'm dealing with. I appreciate your interest and coaching let me know when is good for you.
Thank You
Al
I apologize for my error it should be STEPHENSTEIN |
bushaus Samba Member
Joined: November 18, 2007 Posts: 809 Location: Long Beach, Calif
Posted: Wed Jul 21, 2010 11:09 pm Post subject: |
I consider myself an intelligent guy, and I am well-known for my skills in creating things with my hands, but.....
this thread is absolutely mind blowing technically. And the welds and fab are true art. Please keep up the fine work, and keep us posted. _________________ 1967 13 window walkthru bus
1965 Karmann Kabriolett beetle
hitest wrote: |
Even if completed, the abarth's gonna belch spluey all over your Eriba. |
Posted: Fri Jul 23, 2010 8:12 pm Post subject: Sorry for the delay.. |
Dr.
Sorry for the delay but i have been working like a rented mule. And I own the damn company.
Here are some pics of my bus. I would really like to mount the 3.6 in the rear but measuring from the back of the engine to the center of the axles on the tranny it looks like i will have to move the rear wheels up towards the front at least 5 inches. I know other guys have done similar conversions. Is the 3.6 engine and automatic i have that much larger than a 3.2 engine, Or wait, is their something diabolical i have completely overlooked.
What is the best time to call you at the number you sent me.
I am in and out on holidays for the next while as my wife cannot understand three weeks in the shop working on this conversion is a holiday.
Thanks
Al
67dubcab Samba Member
Joined: February 12, 2009 Posts: 214 Location: sebastopol C.A
Posted: Fri Jul 23, 2010 10:21 pm Post subject: Porsche Powered Mid-Engine Double Cab Build |
Hey Al,
Your panel looks excellent!
No bodywork, just work on the "Porsche performance modified transporter" part.
No worries on the busy part, my boss is a tyrant (also self employed) so I understand.
Best time to call is after 4pm weekdays, and hit or miss on the weekends.
This sunday I am working on my d.c. but am sandblasting at my shop so try in the morning 9am or so.(or sat. after 9am)
Stephen _________________ Porsche powered mid-engine double cab build
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight= |
Posted: Mon Aug 23, 2010 10:09 pm Post subject: porsche Powered Mid-Engine Double Cab Build |
Here are some shots of the shortened and re-splined drive shaft.
Not so interesting but a crucial part in the build to fool the 3.2 that it is still in the back of a porsche 911 and not in the middle of a truck facing the wrong way.
Bit too long.
That should work. _________________ Porsche powered mid-engine double cab build
gostros Mr. Obvious
Posted: Wed Oct 06, 2010 9:42 pm Post subject: |
any updates? |
Posted: Sun Oct 24, 2010 12:00 am Post subject: porsche Powered Mid-Engine Double Cab Build |
O.K, a little something to show.
I am cleaning up the chassis before I re-install the drivetrain to go back to Seth's shop for more of the fancy stuff.
I sand blasted the new and old engine bays and then used Pickelex 20 on the bare metal (also stripped the bed by hand and am using the same procedure for paint except it will get a final coat of bedliner finish in grey) next is the MasterSeries silver primer (see photos) and finally the MasterSeries grey paint.
The red looking stuff is West system epoxy mixed with high density filler, to fill and strengthen some of the deeper rust pits.
The truck came from the Seattle area and was completely undercoated, prolly as soon as it hit the dealer, good and bad, as the basic frame is clean underneath, its just getting down to the underneath that is bad.
I took a tip from a thread on Pelican Parts forum about using the harbour freight multi-tool to knock (vibrate) off most of the offending matter.
While I am not a fan of crappy tools (I actually own a air powered Fein multi tool that the H.F. tool copies) sometimes you need crap to battle crap. It worked great.
Once the grey paint is applied my next task is to install the modified fuel cell and begin running fill and fuel lines.
The engine also needs new fuel supply and return lines as the stock mid- 80's rubber lines are prone to unplanned external combustion events- just like its VW brother. _________________ Porsche powered mid-engine double cab build
LeviMan2001 Samba Post Whore
olskool58 Samba Member
Posted: Sun Oct 24, 2010 9:24 am Post subject: |
just found this thread- awesome build- I love the vw-944-swap-ability, used 944 stuff on my bus- using it on the baja, however you've taken it to a whole new level- I guess it'll be time to change it up when my motor croaks _________________ 66 sundial
54 3 fold project
59 Baja monster project
63 ghia |
JustBuggy Samba Member
Joined: August 01, 2010 Posts: 849 Location: SF Bay Area, Ca.
Posted: Sun Dec 05, 2010 8:25 pm Post subject: |
I love it! Setting the bar high for the rest of us. |
Twisted Minis Samba Member
Joined: December 24, 2007 Posts: 97 Location: Windsor, CA
Posted: Wed Dec 08, 2010 10:28 pm Post subject: |
Looking good.
This thing has inspired some gear turning for one of my own projects. I am glad to be a part of this build. _________________ If you can find it cheaper, I can fix it. |
Posted: Tue Dec 21, 2010 2:04 am Post subject: porsche Powered Mid-Engine Double Cab Build |
Thanks all for the comments, and Seth, it is getting a little closer to returning for some of your "fab magic"(what you have cooking up can only make us wonder and quake in fear and/or anticipation).
I have finally shot the MasterSeries grey and it ready for some re-assembly and systems install.
The level of finish remains at the daily driver shop truck status so it may be a bit industrial for some used to the show car attention to detail, pardon the paint runs.
It is not the paints problem, as it layed down well with a little thinner to help it flow through the cheep H.F gun which started loosing parts in the mist of battle, but I could only at times pull the trigger and guess the aim and overlap(only those who have dared to shuffle along on their back on a board with tiny wheels while firing a toxic plume onto a steel object five inches from their face know of what I speak).
So glad that is done.
[/img]
Fade to grey
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
Raul_MX Samba Member
Joined: May 10, 2007 Posts: 255 Location: Reynosa, MEXICO
Posted: Tue Dec 21, 2010 8:14 am Post subject: |
good day
I just found this post and... well, I'm shocked... loss of words.
The skills, fabrication, engineering, ideas that are being put to work on this truck amaze me. This is a truly a one-off build. Unique in many ways. I have never seen welds so clean!
Major Kudos, this build is bad ass... keep up posting some more updates.
Greetings from Mexico. _________________ Click Here for a clicking sound... |
Jer*Fab Samba Welder Dude
Joined: March 05, 2004 Posts: 629 Location: Upland, SoCal
Posted: Tue Dec 21, 2010 11:57 pm Post subject: Re: porsche Powered Mid-Engine Double Cab Build |
67dubcab wrote: |
[/img]
Fade to grey
Me Likey! _________________ 51 RHD Split
54 Barndoor Shop Single Cab
Also Narrowed Bug and Bus Beams!
Follow us on FaceBook and Click the "Like" Button or Instagram |
Posted: Thu Dec 23, 2010 2:32 pm Post subject: porsche Powered Mid-Engine Double Cab Build |
Thanks for the kind words,
The paint job looks better on the interwebs than in person but it as detailed as I wanted to go.
Here is a photo I missed on my last post, it shows the 944 torsion end caps which in a 944 help bolt in the complete rear suspension but in this case it re-enforces the frame and body connection a little.
Posted: Sun Feb 20, 2011 12:36 am Post subject: porsche powered mid-engine double cab build |
here are some photos of the fuel system which I need to complete before I re-install the drivetrain and get the d.c. back to the fabricator to work on the dry sump tank/exhaust/hydraulic clutch/ ect......
this is a R.C.I. fuel cell modified by Seth a while back to fit over the torque tube tunnel, went from 15 gallons to 13.
Seth fabbed a new 2" fill to line up with the fuel door and I used the stock fuel cell cap to run a fill vent to the new cap. the new cap is non-venting(which is great as I dislike the stock V.W. cap which vents fuel out every time you turn left). The new vent is the red thing at the top of the shot and it is a fancy two way valve which under super low pressure allows air in to replace the fuel but not constantly open to let vapors escape or liquid fuel out but will vent under higher pressure if the tank goes positive (parked in hot sun).
Porsche fuel pump which along with a Canton filter will mount on a aluminum bracket
A little bit of bling in the form of a Aero fuel cap from B.A.T. in florida, made in Britain it is nicely crafted.
Next up is throttle cable mount on back of engine since it is difficult to access once engine is installed. _________________ Porsche powered mid-engine double cab build
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3294 Location: Seattle, WA
Posted: Sun Feb 27, 2011 12:56 am Post subject: porsche powered mid-engine double cab build |
I finished the new engine mounted throttle bracket and tested the made to order throttle cable from Pegasus racing, works well. On to drivetrain install.
First up get the truck in the air.
Next slide on over 480# of engine (moving dolly under)
Up and in (about two hours working alone going slow)
Shortened torque tube.
944s2 transaxle
zuhaelter_82 Samba Member
Posted: Sun Feb 27, 2011 3:17 am Post subject: |
Oh man! Fab skills are top notch... I can't wait to see the end result. _________________ 64 Type II
MKI Jetta Coupe Diesel
MKI Jetta Sedan w/TD swap
B5 V6 GLS
B7 TDI Passat SE |
