cargo floor heat vent outlet
airkooledchris
airkooledchris is offline
PostPosted: Tue Nov 16, 2010 10:01 am    Post subject: cargo floor heat vent outlet Reply with quote
my 79 bay has a heat outlet just under the middle seat in the cargo area...
this has been blocked off (with a rubber ball jammed in there a little ways) - how does this usually look?
I checked my manual and the ETKA software but I can't find any part numbers or pictures showing what should be here. Is there some kind of vent cover to keep crap from falling down into this vent when it's hooked up?
any tips, suggestions or misc tomfoolery welcomed.
busdaddy
busdaddy is offline
PostPosted: Tue Nov 16, 2010 10:46 am    Post subject: Reply with quote
There was a spring loaded flap shaped like a D that covered it.
Слава Україні!
airkooledchris
PostPosted: Tue Nov 16, 2010 11:05 am    Post subject: Reply with quote
this is perfect, thanks busdaddy!
I was failing to come up with the correct terminology when searching the forums and classifieds for it...
of course I missed the most obvious part, the regular manual!
ETKA and Bentley are a little bit too in depth for 'where's the heat thingy' questions I guess... ;p
Opossum
Opossum is offline
PostPosted: Tue Nov 16, 2010 11:11 am    Post subject: Reply with quote
See number 31 here (Ratwell's site): http://www.ratwell.com/technical/Microfiche/t202400.gif
"You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner
stevespeirs
stevespeirs is offline
PostPosted: Tue Sep 11, 2018 6:17 pm    Post subject: Re: cargo floor heat vent outlet Reply with quote
Part number for #30? I have the flap (31) and the spring (32), but am missing the vent.
1979 Microbus
Wasted youth
Wasted youth is offline
PostPosted: Tue Sep 11, 2018 8:22 pm    Post subject: Re: cargo floor heat vent outlet Reply with quote
Your vent probably got tossed by the previous owner. It slides into the tube after you remove the flap and spring. The vent then gets secured by one bolt of the middle seat anchor, if I recall correctly. My 1973 bus is equipped with one, but my 1978 piece is missing. If you need a picture, let me know.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Sep 11, 2018 8:33 pm    Post subject: Re: cargo floor heat vent outlet Reply with quote
just lift the flap and insert the outlet. When removed the spring holds it closed.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
my59
my59 is offline
PostPosted: Wed Sep 12, 2018 2:28 am    Post subject: Re: cargo floor heat vent outlet Reply with quote
When I removed the mouse house and tuned up the system, opening the flap made the back of the bus about 10 degrees warmer and helped balance out the draft from the sunroof.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
stevespeirs
PostPosted: Wed Sep 12, 2018 3:28 am    Post subject: Re: cargo floor heat vent outlet Reply with quote
No need for a pic thanks - busdaddy's owner's manual photo above is good info.
Does this look like the correct vent?
https://www.thesamba.com/vw/classifieds/detail.php?id=2168048
1979 Microbus
busdaddy
busdaddy is offline
PostPosted: Wed Sep 12, 2018 7:02 am    Post subject: Re: cargo floor heat vent outlet Reply with quote
No, that's an early defroster duct, the seller is confused.
Слава Україні!
stevespeirs
PostPosted: Tue Oct 23, 2018 6:32 pm    Post subject: Re: cargo floor heat vent outlet Reply with quote
Found a vent Very Happy
https://www.thesamba.com/vw/classifieds/detail.php?id=2073445
1979 Microbus
busdaddy
busdaddy is offline
PostPosted: Tue Oct 23, 2018 6:41 pm    Post subject: Re: cargo floor heat vent outlet Reply with quote
You sure did! , nice work! Very Happy
Слава Україні!
aerosurfer
aerosurfer is offline
PostPosted: Wed Oct 24, 2018 4:54 am    Post subject: Re: cargo floor heat vent outlet Reply with quote
That’s a great price! I sold one a few years ago for $100
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
stevespeirs
PostPosted: Wed Oct 24, 2018 4:59 am    Post subject: Re: cargo floor heat vent outlet Reply with quote
Yeah, spotted one on the local Craigslist a few weeks ago for $90. Glad I waited a while Wink
1979 Microbus
