MrMan Samba Member
Posted: Tue Nov 16, 2010 7:52 pm Post subject: Engine cabin |
| So i want to make i engine cabin look clean the paint inside of it now is not so good. I had an idea to clean it real good and spray it with that rubber under body spray, Would that be a bad idea? I'm concerned about heat, Would that be a problem? |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42934 Location: at the beach in Northern Wokistan
Posted: Tue Nov 16, 2010 7:59 pm Post subject: |
pull the engine, clean and sand then spray with a single stage paint that matches your bus. I would NOT use that rubber stuff due to flammable and traps water under it. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
nathansnathan Samba Member
Posted: Wed Nov 17, 2010 8:36 am Post subject: |
| I would go for gloss paint, definitely not a textured finish, for the sake of being able to easily wipe it down. |
buckettt Samba Member
Posted: Wed Nov 17, 2010 9:49 am Post subject: |
I degreased/ (and used mineral spirits) cleaned up all wires/connections...
then painted tin/fan shroud with high temp black and silver....then used white appliance epoxy spray paint (hardware store) to paint compartment...I used the same white paint on wheels and has held up for years...I didn't remove engine...just removed engine seal/ battery and covered/masked everything up...paint prep time about 20 minutes ( tin foil works great to cover small stuff )
aeromech Samba Member
Joined: January 24, 2006 Posts: 17745 Location: San Diego, California
Posted: Wed Nov 17, 2010 10:45 am Post subject: |
Lighter colors work best for an engine compartment. I like to use the same paint as the exterior. Black is the worst thing you could do. Anything with a texture is just going to collect grit and grime. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53188 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Nov 17, 2010 10:52 am Post subject: |
X2, light and smooth is better to see that screw you lost in the very front corner and wipes up with a rag, dark and bumpy not so much. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Wed Nov 17, 2010 1:49 pm Post subject: |
I have to ask all these people with clean repainted engine bays. Did you have to deal with grumbling tar like gunk under the old paint? Mine has that under the paint on the frame rails and the front wheel wells inside the cabin. Awful stuff. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Wed Nov 17, 2010 2:00 pm Post subject: |
| RatCamper wrote: |
| I have to ask all these people with clean repainted engine bays. Did you have to deal with grumbling tar like gunk under the old paint? Mine has that under the paint on the frame rails and the front wheel wells inside the cabin. Awful stuff. |
No, not really. It takes some work but if you get it very clean and maybe sand a few areas, they come out very nice.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Brionp Samba Member
Posted: Wed Nov 17, 2010 2:58 pm Post subject: |
Scrape it with a putty knife and wire brush, wipe with solvent. Sand, 180 or 220 grit, wipe with solvent. Prime the bare spots, sand again with 400 grit and wipe with wax and grease remover. Get some 3M Heavy Duty Drip Check, (One of my personal favorite products, it shrinks as it dries and holds paint very well, cool stuff) and seal any seams that you can get to. One more round of primer, pay extra attention to the battery tray area. But not too thick. Quick sand and another wipedown with wax and grease remover. Wipe down with a Tackey Cloth, you get them where you buy paint and they are a must for a good paint job. Paint it the same color as the body. Single Stage, Omni is what I'd use.The engine compartment is a busy area that hides mistakes very well. Its a good place to start, or learn about painting. This is a project that has a big payback at the end. Mine turned out so pretty I wanted to lick it. But thats another story. Thank God for Samba. Something to keep my hands and head busy. Who needs all of the TV, Talk Radio, Politics, Media Money Churning B.S. . I get all of the Comedy/Tragedy/Drama/And Success Stories that I need right here in the Forums.
Quick P.S. After you have finished putting on the finish coat, walk away. Any boogers will be much easier dealt with AFTER the paint dries. DO NOT TOUCH IT WHEN IT IS WET. Ever. Period.
Desertbusman Samba Member
Posted: Wed Nov 17, 2010 3:56 pm Post subject: |
Two major ingredients needed to have it nice. A desire to have it nice and then elbow grease. _________________ 71 Superbug
71 Westy |
raymino Samba Member
Joined: August 26, 2009 Posts: 89 Location: Durango, CO
Posted: Thu Nov 18, 2010 8:00 am Post subject: |
| RatCamper wrote: |
You may be talking about cosmolene here. I think from the factory it is over the paint to protect it (works good if kept clean). You may be the victim of someone who resprayed without first removing the cosmolene! Someone who didn't follow BrionP's great paint primer above. _________________ '79 Westy Headflow Masters 2.0L FI
'87 GTI 16V Sold!
'06 Jetta 2.5 Package 2
'71 Super Marine Blue |
grandpa pete Samba Member
Posted: Thu Nov 18, 2010 4:27 pm Post subject: |
"OLD SCHOOL" oven cleaner,hot or not , been using it for---years Wash off what you can and spray again  |
