58 Westy Restoration
Page: Previous  1, 2, 3 ... 9, 10, 11, 12  Next
npbusguy
npbusguy is offline
PostPosted: Sat Nov 06, 2010 1:40 am    Post subject: Reply with quote
Looking great Jim!
I am back from my big trip in case you need a hand, let me know.
vws-microcars4jim
vws-microcars4jim is offline
PostPosted: Wed Nov 17, 2010 9:28 pm    Post subject: Reply with quote
I have now welded up over sixty small holes in the nose of this bus, all left from some old-school bodywork techniques. I have also been slowly hammering many dents out, while trying not to stretch the metal too much.
Maybe saving this nose is too big an effort. I have been looking at the less-than-great noses that are on the market for $1K or more, to me it seems this is worth trying to save.
I was thinking once the nose was done this project would be smooth sailing.
Then I took off the red paint from the rear corners for another surprise.
Someone thought brazing was a good idea. Shocked
JOGR
JOGR is offline
PostPosted: Wed Nov 17, 2010 9:45 pm    Post subject: Reply with quote
That corner looks like a fat old lady cottage cheese thigh.
Josh
www.JOGRUSA.com www.facebook.com/JOGRUSA
kombicol
kombicol is offline
PostPosted: Wed Nov 17, 2010 9:56 pm    Post subject: Reply with quote
Great thread and epic resto.
If your going to try and repair that nose and rear corner, get yourself a shrinking disc if you havent got one already.
spookymulder
Samba Proletariat
Location: I'm either at 95608, 97537 or 94708 only my CPA knows for sure
spookymulder is offline
PostPosted: Wed Nov 17, 2010 10:01 pm    Post subject: Reply with quote
Sounds like you have some experience with them Laughing
Gmiee5
Gmiee5 is offline
PostPosted: Thu Nov 18, 2010 12:32 am    Post subject: Reply with quote
WOW what a great job on the bus!! I thought my bus had allot of work Very Happy
You are definitely spending the time and not cutting the corners.
As for the nose I say replace it...
If you fix the nose it will be the one place that will bug the crap out of you knowing that it probably should have been replaced. IT’s just my two cents.
_______________________
brettsvw
brettsvw is offline
PostPosted: Thu Nov 18, 2010 11:05 am    Post subject: Reply with quote
That corner looks bad but not as bad as the corner on my old 67 deluxe.
I love your build thread and look back at it often to give me the extra will power to push forward.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
buseric
buseric is offline
PostPosted: Sat Dec 04, 2010 2:29 pm    Post subject: Reply with quote
I am really enjoying this thread. Great to see someone go to so much effort to save an early westy...
sethm
sethm is offline
PostPosted: Sat Dec 04, 2010 3:12 pm    Post subject: Reply with quote
Sack of nickles Laughing
66 Westy/Dormobile convert
bigbulli
bigbulli is offline
PostPosted: Fri Dec 24, 2010 8:26 am    Post subject: Reply with quote
Great work, keep it going Cool
1954 Barndoor
1955 Oval
Barndoor Mirror Arm Screws - http://www.thesamba.com/vw/classifieds/detail.php?...5d3c7d7793
Barndoor Wheel Tray Bolts - http://www.thesamba.com/vw/classifieds/detail.php?id=1997654
Tistlo
Tistlo is offline
PostPosted: Fri Dec 24, 2010 4:33 pm    Post subject: Reply with quote
Good thread!! Keep up the good work Smile
Lots of good pics 'n tips. You should get yourself a slapper and dolly for the nose and that extremely straigt corner of yours Rolling Eyes
looking forward for updates here
vws-microcars4jim
PostPosted: Wed Dec 29, 2010 2:57 pm    Post subject: Reply with quote
Thank you all for the encouragement. It has been slow going lately and I have nothing to blame except myself, and the cold garage working conditions.
Thanks Brett, I look at your thread for inspiration too, but I can't get over the wood chip work area, perhaps it is more forgiving than concrete. Think
I have been doing little projects (until my fingers go numb).
Scored this sand green crank start apron from the Holcombs garage, thank you Brian! Wink
It had been hacked for beetle tailpipes, and had rust.
I noticed it comes apart, which is handy for repairing!
I have been assembling all the parts that make up a '58 shift assembly, and I'm afraid I'm not done yet.
Thanks to Bill from FL for the shifter.
Thanks to Rich for the early front shift rod.
Thanks to Hazetguy for the M-spring, although there is no cutout for it on my shift plate.
You can see in that photo where I cut-and-spliced the earlier rod.
I got it all together and it shifts, although not super-smoothly.
I don't know if the plate is correct or will affect this.
Is this correct or should there be a different "link"?
The rear bushing (at the transmission) that is installed is the one that was on the bus when it came apart. I found another in my parts stash, is either correct?
Thank you to all that have posted on TheSamba, it is very helpful. Cool
Jim
PostPosted: Wed Dec 29, 2010 4:51 pm    Post subject: Reply with quote
Either rear shift bushing will work but the one in your hand is more "correct".
JOGR
JOGR is offline
PostPosted: Fri Jan 14, 2011 3:24 pm    Post subject: Reply with quote
I stopped by Jim's yesterday and checked out the progress on the bus. Jim was busy cleaning the garage and taking advantage of a relatively warm day to have the garage door open, I think it was about 20 degrees?
Anyways, it is looking good buddy, getting it in primer really is fun and makes it look better! I think its time to start welding the gerson metal in.. you can't measure forever! Measure it up and weld that shit in.. We'll build a rotisserie and finish the underside later, just start putting it together, don't be skeered!
It looks awesome, we'll be camping in no time....
Josh
buseric
buseric is offline
PostPosted: Fri Jun 17, 2011 9:35 pm    Post subject: Reply with quote
Any updates on this bus? Was looking great at last post..
JOGR
JOGR is offline
PostPosted: Sat Aug 13, 2011 8:16 pm    Post subject: Reply with quote
Was thinking about your bus today.. Any progress?
Josh
vws-microcars4jim
PostPosted: Sat Aug 13, 2011 9:28 pm    Post subject: Reply with quote
Not much to report lately. My wife is divorcing me, turns out all the funky green metal and other parts purchased for this bus will likely be consideted marital assets. I may lose it all so I haven't done more work. Buzz the bus cat / project inspector has been taken from me Sad . Saturation with alcohol also isn't helping get much done.
Jim
Cuñado Wear
Cuñado Wear is offline
PostPosted: Sat Aug 13, 2011 10:51 pm    Post subject: Reply with quote
Jim,
Hang in there brother! I've been down this same road and its long.
Sorry to hear this.I gave her everything in my case except my vert and tools.
the drinks didnt help me much either.
Good luck. and take care.
Bulli Klinik wrote:
I may be a little late to the party, but what the hell is Cunado Wear?
Looking for front kick panels for late 63' Deluxe Basalt Gray
60' Double Cab
63' 15 Window Deluxe
ricekooker
ricekooker is offline
PostPosted: Sun Aug 14, 2011 4:37 am    Post subject: Reply with quote
Jim
Sorry to hear this.
Sell the parts and metal cheap to a friend. I'm sure they'd donate it back to you.
JOGR
JOGR is offline
PostPosted: Sun Aug 14, 2011 2:47 pm    Post subject: Reply with quote
I have room for funky green storage.
What about the 360? What a mess... Stay strong brother!
Josh
Page 10 of 12
