Posted: Thu May 23, 2002 12:50 pm Post subject: CV Boot Replacement... Urgent? |
I was under my '77 last evening replacing the valve cover gaskets (had a small leak) and noticed that the CV Boot on the passenger side is torn. Not sure how long it has been that way but I am wondering 1) how urgently does this need to be replaced and 2) is this a major pain to replace (scale of 1-10)?
Any feedback would be appreciated. We have a couple of 300+ mile trips planned in June and I am thinking I should probably fix this prior to departure.
Thanks! |
ekimthemad Samba Member
Posted: Thu May 23, 2002 3:05 pm Post subject: CV Boot Replacement... Urgent? |
If you are planning some longer trips I would suggest replacing them before hand. The sooner you can replace the boots the less likely the cv joints will be damaged.
It is a simple job to replace. I would buy two boots and do both on that side at the same time. All you have to do is crawl underneath and remove the six bolts on both ends of the axle. You should be able to get the axle off. There are probably clips holding the cv joints on. Remove those and slide the joints followed by the boots. Install the new boots. regrease the joint and put back together. I would recheck the tightness of the bolts after driving for a distance to make sure they stay tight. |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Thu May 23, 2002 9:25 pm Post subject: CV Boot Replacement... Urgent? |
I did mine on a 77 and it wasn't to bad, just a bit messy with the grease. Check out this site or search for another online as the directions are quite good. www.type2.com/bartnik/cvjoints.htm
Remember to check each bolt on the cv's because they may not all be the same, some might be 6m allen heads and others the triple square (which you can probably get cheapest from a good vw service shop, I paid about $10 CDN for mine). |
Posted: Fri May 24, 2002 5:48 am Post subject: CV Boot Replacement... Urgent? |
Thanks for the help! Doesn't sound like too much of a chore. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri May 24, 2002 8:12 am Post subject: CV Boot Replacement... Urgent? |
Be sure to dig the dirt out of each bolt with a tiny screwdriver really well or it's "strip city" then you have to go to hammer and chisel or if your luck big vice grips. Re torque spec is 25-30 ft-lbs.
When removing the joints be sure NOT to let them come apart, the balls must stay in their respected positions in the "cages" or you'll be having more fun than a Rubik's Cube! Wear the disposable gloves and really old clothes it can be quite messy. Also if the boot kits don't come with the grease make sure you buy MOLYSULPHITE (MOSO2??
good kits come with a tube and new bolts, but I buy some extra grease and packem really good (but dont fill the boot..) have fun!!!! |
Posted: Sat May 25, 2002 1:01 pm Post subject: CV Boot Replacement... Urgent? |
Oh yeah I forgot a tip, put 3 wireties through the cv cages and they won't fall apart when removing and cleaning... |
Joel Rosado Banned
Joined: July 14, 2002 Posts: 53 Location: La Parguera<Puerto Rico
Posted: Sun Jul 14, 2002 8:09 pm Post subject: CV Boot Replacement... Urgent? |
BENTLY MANUAL IS A GOOD SOURCE OF INFORMATION. NEED A SCAN???,E-MAIL ME AND I'LL SEND IT;DANNY |
Posted: Sat Jul 20, 2002 10:18 pm Post subject: CV Boot Replacement... Urgent? |
I AM ALSO HAVING PROBLEMS WITH CV BOOTS.I HAVE PURCHASED 8 NEW BOOTS IN THE LAST TWO YEARS AND SEEM TO DETERIORATE IN NO TIME.THESE ARE FACTORY BOOTS WITH THE AUDI LOGO ON THEM.THIS IS ON MY 77 WESTY DAILY DRIVER.IF ANYONE KNOWS SOMETHING I DONT,PLEASE LET ME KNOW...THANKS |
