GB2S Samba Member
Posted: Sun Mar 30, 2008 7:16 pm Post subject: rear clip & bumper mount replacement |
My 63 ragtop that I just bought was hit in the back. There is a small dent in the rear apron, but my biggest concern is underneath. The metal in the body behind the rear bumper mounts is rusted. Now my question is; should I straighten the rear apron, and put in 2 new pieces of metal behind the bumper mounts, or cut an entire section off the back of a donor car, metal and rear apron and weld it on as one piece. Any other ideas? thanks |
joshbuchan Samba Member
Joined: April 12, 2007 Posts: 712 Location: victoria bc canada
Posted: Sun Mar 30, 2008 9:10 pm Post subject: |
get some original german donor steel, no brazilian crap. it will be less work making it right and turn out better too, only way in my books |
mrkarl00 Samba Member
Posted: Sun Mar 30, 2008 10:12 pm Post subject: |
joshbuchan wrote: |
x2.....before i knew any better i bought a rear apron from jcwhitney...... i ended up having to go to the junkyard and pull, and now i have a rear apron that does not fit on my car and i can not sell it because it will not fit on any one's car _________________
satchmo wrote: |
I used thick nylon string from a weed whacker and lubed with ky jelly |
GB2S Samba Member
Posted: Mon Mar 31, 2008 7:57 am Post subject: |
O.K so replace everything with German metal, but would it be better to
just replace the rusted metal under the rear bumper mounts, and repair the apron, or replace it all asone piece?
Geoff |
Posted: Mon Mar 31, 2008 1:57 pm Post subject: |
either way probably the same amount of work. |
Jengel451 Samba Member
Joined: July 15, 2007 Posts: 479 Location: Greenacres, WA
Posted: Mon Mar 31, 2008 3:06 pm Post subject: |
Finding a decent rear clip was a PITA. So I decided to buy one repop replacement panel to see how bad it was going to be.
I was actually surprised how good it turned out and ended up doing both sides.
I kept the original apron though.
_________________ 63 Dee "lux Interior" RIP Lux
09 R1 Track Weapon
66 Ducati 160 Monza Jr
64 Ducati Mountaineer
72 Z50a PitMonster |
Posted: Mon Mar 31, 2008 11:36 pm Post subject: |
Where did you get the new apron from? looks good _________________
satchmo wrote: |
Posted: Tue Apr 01, 2008 7:46 am Post subject: |
As I said, I used the original, it was in decent shape, just had it media blasted to get as much of the rust and crap out as I could, it got thin in a couple of spots, but easily fixed before welding it back on. _________________ 63 Dee "lux Interior" RIP Lux
09 R1 Track Weapon
luv4skating Samba Member
Joined: January 16, 2008 Posts: 157 Location: Fort Washington, Md
Posted: Tue Oct 07, 2008 2:49 pm Post subject: |
Where did you get your replacment panel? |
Posted: Sun Oct 12, 2008 5:37 pm Post subject: |
luv4skating wrote: |
Wolfsberg west and CIP, both had the exact same quality panels.
If I was going to do it again, I'd go with Hooky's sheetmetal for sure. _________________ 63 Dee "lux Interior" RIP Lux
09 R1 Track Weapon
GB2S Samba Member
Posted: Sun Nov 28, 2010 6:08 pm Post subject: |
update: I've found a decent rear clip off a 1962. I also have the left and right repair panels. So, should I replace the rear apron and bumper mount areas as one unit, or as a 3 piece operation? I'd really like to hear from you if you've done this. I'm just learning to weld to the one piece unit would have to be done by someone else. Also, my rear apron need of attention.
Thanks Geoff _________________ 1963 Ragtop |
Vinnems Samba Member
Joined: December 23, 2008 Posts: 1183 Location: Simi Valley, CA
Posted: Sun Nov 28, 2010 6:14 pm Post subject: |
Guy at the body shop my car is at told me that, from his experience, 80% of after market meal will fit perfectly, the other 20% will need work. |
anthracitedub Samba Member
Posted: Sun Nov 28, 2010 6:34 pm Post subject: |
If you have an entire clip that is decent…I would just do it in one piece….but keep that other rear apron….save it for a rainy day. |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
Posted: Mon Nov 29, 2010 5:25 am Post subject: |
Vinnems wrote: |
not with vws
turn that around and its a more true statement _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
