dokarex Samba Member
Joined: January 13, 2007 Posts: 251 Location: SHELBURNE NS
Posted: Wed Dec 01, 2010 1:26 pm Post subject: doka rear seat belts |
Hi
Picked up a set of seat belts from a 88 Jetta to install in the rear of my Doka. There is a captive nut in the c-piller for one attachment point. The question is were are the other two?? and if they are not there why did they put the one and not three???
If they are not there has any one installed 3pts in the rear, if so could you share some photos.
Thanks
Danny _________________ 1987 Doka 1.9TD from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2006 Jetta Wagen 1.9TDI
B6200 Kubota Diesel
16ft Freestyle catamaran
16 ft Sunray 85 Horse (sunk) |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11998 Location: Santa Cruz, CA
Posted: Wed Dec 01, 2010 1:40 pm Post subject: |
The doka rear 3 point seat belts are specific to the trucks due to the foot that is bent into the bracket for the attachements. It is bolted to the seat rail down by the base. Mine are stock and were delivered with the truck from factory- nothing special.
Good luck |
GMByers Samba Member
Joined: December 07, 2008 Posts: 642 Location: Retired in NW PA
Posted: Wed Dec 01, 2010 3:22 pm Post subject: |
Bought my three point seat belts from the dealer while living in Germany. Mine look just like syncrodoka's.
I want to install head rests, just haven't had the time to sit down and figure it out. _________________ And then there were two...downsized to 83 Doka &
74 Thing. |
Posted: Wed Dec 01, 2010 3:56 pm Post subject: |
Thanks Syncrodoka
Thats why I couldn't find the third one, they didn't use three only two
Looks like a pretty simple mod that can be perform with a bench vice
If that won't do it our welding shop will
thanks
B6200 Kubota Diesel
Posted: Wed Dec 01, 2010 4:43 pm Post subject: |
Make sure that the retractor base was installed vertical from the donor car like mine pictured. If the donor was installed at a angle of flat they won't work. The inertia wheel will not work correctly if the pendulum is sitting at a different angle than designed for. The result would be a seat belt that cannot be spooled out and/or will not lock up in case of collision.
Good luck. |
BushChicken Samba Member
Joined: March 11, 2010 Posts: 250 Location: California
Posted: Wed Dec 01, 2010 5:40 pm Post subject: |
syncrodoka wrote: |
Good luck. |
Definitely something to look for, but the belts may not be dual sensitive (not sure what Jettas used and it may be different if they are the front or rear belts). If they are only web sensitive you can mount them any which way.
Just try and spool them out in different positions, if it works at multiple angles (or at least at the angle you intend to mount them) you are golden. |
Central Syncronizer Samba Member
Joined: November 19, 2008 Posts: 302 Location: Vancouver
Posted: Wed Dec 01, 2010 6:04 pm Post subject: |
GMByers wrote: |
I want to install head rests, just haven't had the time to sit down and figure it out. |
I've installed 3 rear headrests in mine. For each headrest, I drilled two holes down through the cross member at the back of the cab to take the posts. Cut some plastic tubing that the posts drop into to hold them from dropping all the way down, and secured them from coming out with a couple cotter pins through the post at the bottom. (hose clamps would be easier though)
Each post had to have two minor bends made so that the headrest isn't angled too far forward or conversely pressing on the rear window. (The plastic tubing that the posts sit in has to be oversized a bit to accept the bends)
To finish them off, I cut some foam tubing to length which pads the posts a bit.
Some pictures here, just scroll down:
http://88syncrodoka.blogspot.com/ |
MKIII and Sons Samba Member
Posted: Wed Dec 01, 2010 6:31 pm Post subject: |
not all dokas came equipped w/ rear seatbelts?
my canadian spec syncro has them stock. _________________ broke.status |
Posted: Thu Dec 02, 2010 12:12 am Post subject: |
MKIII iz KING wrote: |
my canadian spec syncro has them stock. |
A lot of them came with only lap belts, no shoulder belts.
CentralSyncro, that is exactly what I want to do...now I just hate the thought of drilling the holes.
Gary _________________ And then there were two...downsized to 83 Doka &
74 Thing. |
Posted: Thu Dec 02, 2010 2:23 am Post subject: |
Quote: |
but the belts may not be dual sensitive |
They should be. That is the way all of mine function. |
edbee Samba Member
Joined: October 15, 2009 Posts: 49 Location: BC, Canada
Posted: Sun Mar 02, 2014 2:57 pm Post subject: Doka rear seatbelts |
SyncroDoka - in your post from Wed Dec 01, 2010 1:40 pm you included a couple of photos that are not 'working' any more. Any chance you could repost them.
I recently bought a 1989 Doka (originally from Sweden) and it has no belts in the back at all. I hope to install 2 shoulder belts and a lap belt for the middle position.
Thanks!
Ed _________________ 1991 Syncro Westfalia - Bostig Zetec
1989 Syncro Doka - Volvo powered
other misc vehicles including a '46 M16 1.5 ton truck (Studebaker) |
Bman Samba Member
Joined: April 28, 2005 Posts: 895 Location: South Coast, Oregon
Posted: Wed Mar 05, 2014 5:54 pm Post subject: Re: Doka rear seatbelts |
edbee wrote: |
Sorry, I just saw this and reposted the pix in the gallery so that they will stay up.
healeykit Samba Member
Joined: August 22, 2010 Posts: 12 Location: Ottawa ON
Posted: Thu Mar 06, 2014 7:12 am Post subject: |
Has anyone ever tried to add a three point seat belt for the middle position? |
edbee Samba Member
Posted: Thu Mar 06, 2014 8:30 am Post subject: doka rear belts |
Thanks for the photos syncrodoka and bman!
Now I can see exactly what is needed and how they mount.
syncrodoka - my new (to me) doka is the same color as yours. Just curious what modifications you have done to the drive train in yours. _________________ 1991 Syncro Westfalia - Bostig Zetec
Posted: Thu Mar 06, 2014 10:10 am Post subject: |
I put in syncro.org springs and OME shocks but I wouldn't do it the same if i had to do it again. The springs sagged and i have blown a full set of shocks in a short amount of time. I liked the ride of the original springs and i would try the boge shocks with them for general use.
The biggest return on the $ was going through and replacing ball joints, bearings, radius rod bushings, trailing arm bushings and swapping the steering rack bushings with the poly version. The vans drive really well when everything is as it should be.
Have fun. |
