0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3342 Location: OR & CA (Oregon/California)
Posted: Thu Dec 02, 2010 6:57 pm Post subject: adjusting headlights |
hi all,
I repaired/replaced some of the headlight adjusters and now the headlight beams are not correct anymore. I plan to put the vanagon in front of a wall and adjust them myself...
but I don't know:
- how far the front of the van from the wall?
- what is the height from the ground to the beams?
- what is the distance between 2 beams?
- are the highbeams (square one) need to be higher than the rectangle ones?
Could anybody please help...
many thanks,
(89' vanagon with rectangle/square headlights) |
RGS Paul Samba Member
Joined: April 20, 2007 Posts: 626 Location: Los Alamos, NM
Posted: Thu Dec 02, 2010 7:28 pm Post subject: Re: adjusting headlights |
"- how far the front of the van from the wall?"
10 m (32.8') to the headlamp face. Make sure the ground is level.
"- what is the height from the ground to the beams?"
1/3 the height of the center of the headlight housing, assuming that the center of the housing is more then 135 cm above the road. Otherwise, 30 cm.
"- what is the distance between 2 beams?"
Distance between the beam centers should be the same as on the vehicle. Beams should be equally far away from the center of the van.
"- are the highbeams (square one) need to be higher than the rectangle ones?"
Yes, aim them horizontally and symmetrically to the center of the headlamp housings and the vehicle.
If this all sounds a little regimented it's because it is, it's from the Bosch Automotive Handbook, a small reference I suggest we all purchase immediately after buying a Bentley Manual.
Hope this helps,
Paul _________________ '87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman |
Posted: Thu Dec 02, 2010 7:35 pm Post subject: Re: adjusting headlights |
I start by adjusting mine while pointed towards a wall and then fine tune them by driving back roads and getting them right to where I want them. If you typically carry heavy loads at night, you should maybe load the van up before doing the adjustment. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10178 Location: N. Idaho
Posted: Thu Dec 02, 2010 7:46 pm Post subject: |
I'll second the standard aim for a starting point, then fine tuning for your preferences. I like to aim the right headlamp slightly farther toward the shoulder than stock and low beams slightly lower because I use high output bulbs in my vehicles (HIR bulbs - great product).
Bosch Book - X2. Great read if you're a true car nut / vehicle nerd. I like the section in mine on crosswind stability where it looks like one of the examples of a challenging design is a Vanagon.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Thu Dec 02, 2010 11:38 pm Post subject: |
headlight adjustment?
I can't tell if mine are on
this is the correct way to aim
go to tech\aim
http://danielsternlighting.com/ |
Posted: Fri Dec 03, 2010 9:40 am Post subject: |
Daniel stern is where i get my HIRs. Great knowledge guy. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX |
Posted: Fri Dec 03, 2010 12:05 pm Post subject: |
wonderful...
thanks a lot,
