Robw_z Samba Member
Posted: Sat Dec 11, 2010 5:53 pm Post subject: Replacing door glass w/o removing trim/seals? |
Hey,
I'm trying to replace a busted drivers side door glass. When I removed the glass from my parts van, I removed the seals and chrome trim as well to get it out.
I'm having trouble getting this glass to go in with the seals intact. I removed the inner, lower window scraper(the only seal which can be removed without causing lots of trouble) for more wiggle room, but I still can't get this thing to go in.
Can it be done? I really don't want to mess with removing the chrome trim.
-Rob |
madmax25 Samba Member
Joined: March 04, 2007 Posts: 204 Location: Kansas City MO
Posted: Sun Dec 12, 2010 10:28 am Post subject: |
the only way I've ever been able to remove/install the glass is by taking off all the seals. Not too much work if you have some patience. I recall it took me well under an hour to do a window with the chrome. You might try taking out the front felt channel (the one that slides into the wing window frame), it comes out easy and might give you enough clearance. Probably won't be enough though.
It kinda makes sense that the seals should be too tight to change the window in place, otherwise the glass would be flopping about. _________________ -Elliot
'88 Vanagon GL "Big Red"
'90 Westy |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Sun Dec 12, 2010 12:55 pm Post subject: Window |
Replacing a door glass is straight forward really . You need to remove the inner and outer scrapers as well as the upper and rear guide channel.(flocked rubber trim"
The rear of the door has a deep pocket to allow the glass to be installed. The easiest thing to do is to put the lower front corner into the door and then the rear lower part will just clear the metal at the back of the door and slip right in. It is a little unnerving at first , but it just slips right in . Do not take the outer chrome trim off or the vent assembly out to do this .
Once in the door put the window all the way up and there are two holes in the top of the door to attach it to the regulator .
Be sure to put the plastic back on the door as it is an important part of protecting your door panel and keeping drafts at bay.
Put the outer and inner scrapers back in before connecting the door glass as well as the run channel.
I have done probably fifty of these and make a living dealing with glass. I think I know what I am talking about here.
Stacy |
Paulbeard Samba Member
Posted: Thu Aug 06, 2015 10:38 am Post subject: Re: Window |
16CV's wrote: |
Stacy |
This is a bit clearer than what Bentley offers but pictures would help. If I knew what I was doing, I'd take some myself but I'm still figuring it out. Taking off the guide channels creates enough room? I'll see how this goes. It's a lot more complicated to replace the wing window rubber than I imagined. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Merian Samba Member
Posted: Mon Aug 17, 2015 5:44 pm Post subject: |
any pics yet? |
