man130 Samba Member
Joined: August 25, 2008 Posts: 406 Location: long island , ny.
Posted: Sun Dec 12, 2010 7:34 pm Post subject: |
Alex, I took a small plastic soda bottle filled with gas and hung it on hood to keep it higher then pump,I had pump unbolted and sitting inside the hood area to work on it.Then I un hooked hose from pump till gas came out then stuck hose quickly unto pump (primed it basicly)then tapped 12volt source till the gas came out .Might want to try it that way to take out all other variables like tank hoses clogged whatever if it dont work this way it dont work. It should not make a stream of gas just a little spit with each touch of power.After you get it working you can hook it up right and measure how much gas its acually pumping. forgot off top of my head how much its suppose to pump. If I remember I pulled both ends off pump and soaked it in penatrateing oil for a little while and cleaned out what I could,not much in there really to ness with. good luck |
Worknclassbug Samba Member
Posted: Mon Dec 13, 2010 8:31 am Post subject: |
I agree with the above. Mine was doing the same when I first got it clicking but my trouble was the check valve in the pump was stuck open so whatever fuel it was pumping it was sucking right back into the pump when the piston returned. A good soak in penetrating lube freed it up. But like what was said above, I would verify that the pump is actually getting fuel. There is a filter between the tank and the pump. Mine was pretty nasty. Take the fuel line off that feeds the pump and make sure you are getting fuel to it. If you are checking for fuel at the heater it takes a long time for the fuel to get there if the pump is dry. Every time the pump clicks it only pumps around a drop of fuel so it takes forever for gas to get up to the heater if the line is dry. Good luck. _________________ 73 Thing
71 Karmann Ghia (2.2L Subaru Conversion)
72 Deluxe Transporter
Huntington WV
Member of The Wagenfolks |
duderman Samba Member
Joined: January 14, 2010 Posts: 79 Location: central Oregon
Posted: Mon Dec 20, 2010 4:10 pm Post subject: bn-4 motor |
Last Friday night my BN-4 started running rich. I went threw it last winter and installed it in the spring. I've been using it almost daily and love it. I pulled it Saterday night and found that the motor had run dry and slowed enough to make it not burn clean. Before I install my other motor I would like to oil it, greese it, lube it, whatever. My question is: Do they need to be maintained? What would be a good lube so I don't have this problem again? It will take me a few days to get both heaters apart so I'll be checkin in. Awsume thread. I hope it's still alive. Thx. |
Solomon Grundy Samba Member
Joined: December 26, 2004 Posts: 747 Location: Silicon Valley
Posted: Sun Nov 06, 2011 8:43 pm Post subject: |
In my vast amount of skill and stupidity I managed to break the grounding screw on the motor housing.
It all started when I was inspired to find out why my fuel pump on my BN4 decided to stop working 8 months ago. Per this below post. “Heater (fuel pump) question”
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=20
After trying some similar procedures I discovered the pump would work as long as I had the spark plug disconnected. This also worked in reveres so I surmised perhaps I too needed to check and clean my points. This would be a new adventure being I never had the BN4 fully dismantled…
A long around step “8. Remove the screw holding the brown ground wire to the motor housing.” I broke the screw off in the motor housing… BLAST!
I believe this unit has never been disassembled so you can imagine everything is very had to take apart.
Now I need to know something before I really screw it all up.
Can I still proceed to step “9. Give it a tap and the motor assembly will come out of the housing:” without destroying the unit?
I have tried to tap it out but it is well stuck from all these years of being used.
Where should I apply the force if I can in fact tap it out with the grounding screw still in?
///Mink wrote: |
I wasn't sure where to add these pics, so I'll put them here since I spent most of my debugging time in this thread. I troubleshot mine to the point that i knew I needed to clean my points, but for the life of me I couldn't figure out how to get to them in the first place. There were lots of references to "just pull the caps off and bam, there are your points". So I figured these might help someone else.
To get to the points, the fan motor has to come out. So pull the heater out of the car and get it on the bench.
1. Remove the 4 screws along the seam in the outer case
2. Pry open the case enough so that you can get to the clamp holding the fan assembly in:
3. Using a 10mm wrench, socket, whatever, remove the bolt and the clamp.
4. Disconnect the 4 fan wires (brown/black/green/white) and feed them through the outer case while pulling out the fan assembly.
The fan assembly is out!
5. Remove the small rear fan - it's held on with an allen screw. You will probably have to clean some gunk out of it to see it.
6. Remove the big orange fan - thread a 4mm screw into the brass fitting to push the fan off the motor shaft. A Bug taillight screw works great for this.
7. Remove the clip holding the motor into the housing:
Now you can follow the procedures in the rest of this thread to clean and adjust the points and/or replace the capacitors.
I hope this will help someone in the future. |
_________________ "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Dr. Seuss
VW 181 Archive: https://sites.google.com/site/jeffgilleland/vw_archive
| _______
| |_______| '73 Thing "481"
| _\_\_|_/_/_
| |O||_4_||O|
http://vwthingregistry.com
https://doublecabshaka.wordpress.com |
Russ5000 Samba Member
Joined: September 01, 2011 Posts: 2 Location: Northridge, CA
Posted: Sat Dec 17, 2011 6:50 pm Post subject: BN4 Heater reset? |
Hi, you have really made it very easy to understand how the heater works, thank you very much for that. My heater also does not heat, my first question is if the reset switch is tripped will the fan still work or should it not come on.
Thank you,
Russ |
sobeity Samba Member
Joined: February 07, 2012 Posts: 8 Location: Converse tx
Posted: Tue Feb 07, 2012 8:26 pm Post subject: |
thanks every one on here! just got my heater going after two months of trying everything on here...thank you all so much!
it's hot in my thing...frickin stoked, WHOO! |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Tue Feb 07, 2012 9:13 pm Post subject: |
Congratulations! Feels good, doesn't it? Remember to use the heater often to keep everything working.
Oh. And welcome to the forum! |
Posted: Wed Feb 08, 2012 11:22 am Post subject: |
it DOES feel good...chicken skin good...i learned the last few months to keep a thing going good its best to use it, it likes to be driven and used otherwise its all goes to poop...i let mine sit for the last couple years while traveling around...not such a good idea...last two months been workin on it...heater has never been used,,,i'm the third owner of this one...father to son to me...son says they never used the heaters in any of their things...couldn't get them to work...knowing that secret safety switch on the back is a big help... |
Posted: Wed Feb 08, 2012 4:33 pm Post subject: |
i do have a question? the hose that connects the oil bath air cleaner to the carb is not there and there is a cap on the carb. do i need that vacuum hose there? |
memphisthing73 Samba Member
Joined: August 03, 2010 Posts: 61 Location: Memphis, TN
Posted: Fri Feb 10, 2012 7:09 am Post subject: |
Found this page. Seems to have full manuals for BN4 (in English)
http://oacdp.org/ebersp.html _________________ '72 Beetle
'73 Thing |
Posted: Tue Oct 23, 2012 3:40 pm Post subject: |
I am being defeated on getting the small set screw holding the inner fan out. I have broken or bent every allen wrench that I have of the correct size. Have soaked the screw well with several different sprays. Thinking that it might be time to try heat. Somewhere I have one of those tiny butane torches so will try that. Guess I should make some form of heat shield to go between the fan and the cavity underneath it.
Thoughts? |
man130 Samba Member
Posted: Tue Oct 23, 2012 5:37 pm Post subject: |
I guess soak and heat as you suggested, if that fails I guess your gonna have to drill out the allen bolt and if you must maybe tap one size bigger if you mess up the threads drilling it out good luck |
Posted: Tue Oct 23, 2012 6:20 pm Post subject: |
Heat worked, I couldn't find my little Butane torch so I used the oxy-act rig with the smallest tip I have. Made a heat shield that fit between the impeller and the housing and gave it a few seconds of heat against the hub. Came free very easy.
What someone needs to do is come up with an electronic pulse generator for both the pump and ignition points. They electronics could just sit up under a cover on top of the unit with all the rest of the controls so would be easy to access. I wonder what is used on newer heaters? |
dekdiver Samba Member
Joined: August 06, 2010 Posts: 1 Location: Gig Harbor, WA
Posted: Sun Feb 24, 2013 6:26 pm Post subject: |
I hope this post is still being looked at. There is some great information here. I do have some problems that I am not seeing an answer to.
For the most part, I don't have any problems getting my heater going. However, if my temperature nob is pulled out too far, my safety switch will trip. I have also noticed that it tends to trip more often these days even if I don't have the temp nob pulled out too far.
Has anybody experienced this and can I make any adjustments or clean something to keep this from happening?
Thanks |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Tue Oct 06, 2015 9:04 pm Post subject: |
I have my heater torn apart. I followed the flowsheet to determine that the fuel pump wasn't receiving the signal from the points.
Got it all apart to reveal the points on both ends of the fan. Both were pretty dirty, a little corroded, and there is a lot of very fine dust inside the caps!
I was just curious about the best way to clean all that up? (I'm thinking contact cleaner should do fine.)
Also, what would be best to lube up the gear for the fuel pump points?
And while I'm in there, can I somehow lube the bearings of the fan? When I initially got it to run, it was making some bad noises but it quieted down. It sounds much better but is still a little noisy. _________________ Dave Cook
1973 Wild Westerner
My Thing |
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Wed Oct 07, 2015 7:45 pm Post subject: |
Great thread !! I am going to assume I will be referring to it once I can locate a complete BN4 to install into my 1973 Thing . . . |
Pbotsonis Samba Member
Joined: January 09, 2008 Posts: 506 Location: Parker, Colorado
Posted: Wed Oct 07, 2015 8:04 pm Post subject: |
ente_kaefer wrote: |
PM Sent |
Posted: Wed Oct 07, 2015 8:57 pm Post subject: |
Got the heater back in the Thing!
I ended up using white grease on the gear, and some silicone lube on the rubbing block for the other points. I attempted to dribble some silicone down into the motor bearings by the shaft though I don't know how much really made it down in there.
Since I couldn't easily find the info in the thread, I'll say that the point gap I used on both ends was .018. I used a metal nail file to clean them up, and hosed the whole area down with contact cleaner before lubing.
When I first tried to fire it up, the pump still didn't run. But just to see if it would fire up anyway, I clipped a jumper wire from the wire that is controlled by the points, and grounded it at roughly 3/second as I saw was the rate.
The heater fired up pretty quickly doing that. After a couple minutes, I quit manually working the pump and it was going on its own. I have no idea what the initial problem was, but that worked.
I let it sit there and run for a while, and the thermostat was cutting the pump in and out properly and all that. Also it times out after the heater is switched off properly.
I still have no windows or roof, but having some heat will take a little edge off during the mornings for now. _________________ Dave Cook
1973 Wild Westerner
My Thing |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
kenj06 Samba Member
