How Many Still Have the A&E TransAwn 2000 Awning?
Love My Westy
Love My Westy is offline
PostPosted: Wed Dec 15, 2010 8:22 pm    Post subject: Reply with quote
Here are some photos of my mounting brackets. The awning is removed for use on my other camper.
Rear Bracket: (notice the jackbombay poptop shocks)
Front Bracket (I have a 10 foot awning)
I have driven lots of miles on dirt roads and I've only had to replace the brackets that mount above the rain gutter. I made them out of 3/16" aluminum I bought at Home Depot.
kamzcab86
kamzcab86 is offline
PostPosted: Wed Dec 15, 2010 10:39 pm    Post subject: Reply with quote
Here's a close-up of my awning's brackets; they're similar to ones already posted:
The gutter is just slightly bent; not really too bad for being installed for 20 years.
The only things that have failed on it are the clips holding the cover on.
~Kamz Anxious
2016 Golf GTI S
GBA 88West LA
GBA 88West LA is offline
PostPosted: Tue Dec 21, 2010 9:23 am    Post subject: Reply with quote
the van adapter kit is a exact replacement, received the kit yesterday, matched it up to the OG and its right on target...not missing a thing. thanks for the link, i can put my awning back on come spring Wink Laughing
88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin
Jake de Villiers
Jake de Villiers is offline
PostPosted: Tue Dec 21, 2010 9:30 am    Post subject: Reply with quote
You have to be careful not to lower the pop-top with the clips flipped back. The top catches the clip and bends them backwards - ask me how I know...
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
Love My Westy
PostPosted: Tue Dec 21, 2010 2:36 pm    Post subject: Reply with quote
I have managed to bend mine on occasion. They are hard to bend back into shape as they are spring steel. They also damaged my poptop seal in that location but it is not a big deal as it is in fine shape otherwise.
Jake de Villiers
PostPosted: Tue Dec 21, 2010 6:51 pm    Post subject: Reply with quote
They can be made to work again - I only bent the rear one and was able to get it into good enough shape that the clips still hold the awning shut! Wink
So far, so good...
www.thebassspa.com
sanfordphoto
sanfordphoto is offline
PostPosted: Tue Jan 18, 2011 10:44 pm    Post subject: Reply with quote
Word to the wise, be carful bending back the latch hook. I just snapped one of mine, had no give after 20 years.
Now looking for a replacement!
Good awning parts info here: http://www.caravansplus.com.au/dometic/awnings/catalina-spec.htm
Cheers, Sanford
91 syncro camper
RCWesty
RCWesty is offline
PostPosted: Tue Jan 18, 2011 11:00 pm    Post subject: Reply with quote
You can add me to the count.
Sanfordphoto, please post where you purchased the latch replacement. I noticed mine was wearing thin.
Also, anyone mount a third bracket to fit just behind the slider door? Mine is the 10 ft version and it has only two mounting brackets on either end and it does place a lot of stress on the gutters.
thanks in advance.
89 Burgundy Westy (sold)
90 Blue Syncro Westy
dokaman
dokaman is offline
PostPosted: Tue Jan 18, 2011 11:37 pm    Post subject: Reply with quote
I have one in my garage waiting for its next van..... So far I have used it on about six vans.
kamzcab86
PostPosted: Wed Jan 19, 2011 12:50 am    Post subject: Reply with quote
Yeah, that's probably what happened to the rear clip on mine considering it's slightly bent and won't stay latched (been that way since I got the van), hence the straps.
Scroll up and you'll see mine. The first owner most likely had it installed with the center bracket, since it matches the other two.
~Kamz Anxious
2016 Golf GTI S
sanfordphoto
PostPosted: Wed Jan 19, 2011 12:39 pm    Post subject: Reply with quote
thanks in advance.
Just called, you can't buy just the "latch" you have to buy the whole case. Guess I'll be looking for a latch at home depot or west marine - anyone have ideas.
Now, Regarding the two v. three brace. Thier are actrally two van adapter kits.
3103719.005 VAN ADAPTER KIT has two braces and
930035 VAN ADAPTER KIT has three
They fit the rain gutter very different.
Happy to pmail the pdf to anyone. I have the two brace kit and its on very tight.
Cheers, Sanford
USA
SERVICE OFFICE
The Dometic Corp.
509 So. Poplar St.
LaGrange, IN 46761
CANADA
Dometic Dist.
866 Langs Dr.
Cambridge, Ontarior
CANADA N3H 2N7
For Service Center
Assistance Call:
800-544-4881
crowinghen
crowinghen is offline
PostPosted: Sun Jan 23, 2011 10:52 pm    Post subject: Reply with quote
crowinghen wrote:
Campingworld can get Dometic parts-- not sure if it's cheaper than buying directly.
I just got a quote from them for some parts for a catalina 2500 awning that i got off Craigslist-- awning 40 bucks-- parts-- looks like a couple hundred for the one leg that's messed up-( 70 bucks for shipping??!!)- oh well, i still am ok with it.
susie
Just wanted to update- I ended up getting the parts for my A&E awning for around 50 dollars including shipping, from Dometic. Hubby just put it on tonight-- it looks great!
It seems to be pretty much like the Transawn but has 3 gutter supports, it's 8 feet long. Sweet find- less than 100 dollars all said and done.
If anyone needs help with parts let me know-- I kind of figured out how to navigate the Dometic parts site. They are real helpful people, but you kind of have to know the parts numbers.
Susie
1984 Westfalia a work in progress " Butters"
derekdrew
derekdrew is offline
PostPosted: Mon Jan 24, 2011 1:37 am    Post subject: Reply with quote
I have the TransAwn 3,000 and love it beyond beyond. I surveyed a zillion awnings at an annual meeting of VW vans last spring and none worked as easily and well as mine. Now I need to buy 3 more awnings, and I figure I will check out the dometic line or A$E line again this time and not use the same awnings that everybody else is using. 10 feet long is the best length, I felt. What I like about this awning most is that I can put it up and take it down practically in 5 seconds with one hand! Unfortunately, the trans awn 3,000 was discontinued quickly so it would be hard for me to track down a used trans awn 3,000 for sale, I guess. I would like to stay identical for all my awnings.
peasant
peasant is offline
PostPosted: Fri Feb 25, 2011 5:15 pm    Post subject: Reply with quote
susie
$50 is a great deal for the van adapter kit. They charged me $100 for the kit and it was closer to $150 after tax and shipping(automatic $25 flat rate).
I am going to put them on tonight.
89 wolfsberg weekender carat
89 Westfalia
yardbug
yardbug is offline
PostPosted: Sun Mar 13, 2011 11:42 am    Post subject: Reply with quote
Found this on a '85 vanagon at the local pick-n-pull 2 weeks ago. Riviera camper..
The guy at checkout asked.. "is that a projection screen?" I answered yes and he charged me $9.99. The only thing that would make this better is if it were brown or tan
'69 Tintop T2 - '86 Syncro - '87 Westy - '02 337 GTI - '99 4Runner - '13 4Runner
kamzcab86
PostPosted: Sun Mar 13, 2011 12:00 pm    Post subject: Reply with quote
Projection screen... Laughing Good find, for a killer price!!
And, um, I'd be happy to do a swap: Mine's brown/tan on a blue van; I'd love to have blue to match! Very Happy
~Kamz Anxious
2016 Golf GTI S
Love My Westy
PostPosted: Sun Mar 13, 2011 9:44 pm    Post subject: Reply with quote
OOPS...I backed into a tree and damaged the rear plastic endpiece and bent the case a little. I'm glad they didn't use a piano-like hinge because the whole awning slid forward about 10" inside the case, blowing off the front plastic endpiece without much damage to it. I slid the awning back into the case, glued the front endpiece where it was cracked and pop rivited it back into place. Then I went out to a plastic supply place and for 3 bucks got a piece of 3/4" acrylic plastic which I fashioned into a new endpiece for the rear and pop rivited in place after some aluminum straightening. It won't affect the function at all. The awning was designed very simply so it is easy to make repairs like that. I wish I could say the same about the Fiamma that we have on our trailer.
chojinchef
chojinchef is offline
PostPosted: Wed Mar 16, 2011 8:31 am    Post subject: Still have mine Reply with quote
On my 84. Gold and white, with end caps and prerequisite rust starting under lower mount brackets. (something else to deal with)
The projection screen thing intrigues me though. We do neighborhood Disney movies on the side of my house for the little ones (mine is 3) during the summer months. I have a 10 foot screen I got from a restaurant that was closing.
Might not be a bad idea for certain occasions. . .
Lavabo
Lavabo is offline
PostPosted: Tue Jun 21, 2011 7:56 am    Post subject: Reply with quote
i have a Travel Awn 2000 - (whats the difference with TRANS AWN ... ??)
im looking for gutter bracket for my 1973 westy and maybe later for the Eurovan 1996 (i guess the only way will be thule adapter)
here are some pic:
westfalia 1973 / SOLD 2020
bquigs
bquigs is offline
PostPosted: Tue Jun 21, 2011 11:28 am    Post subject: Reply with quote
Check out Gowesty. They make awing brackets for the BUS, the Eurovan as well as the Vanagon. They are wide and heavy duty steel construction. Strictly speaking they are intended for the Fiama awning but there doesn't seam to be any reason one couldn't use them on other awnings. The bracket wont engage the RV mounting slider on the case but since the bracket is wide, a few bolts can be used in an offset pattern to hold the awing to the bracket, should be more than strong enough. Im planning to mount my Trasawn this way and will report on the results when I get a chance to do it.
87 Syncro Zetec
Page 2 of 5
