Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Dec 22, 2010 7:42 pm Post subject: center brake light turn signal switch correctness |
hey guys, I have done my research here on TheSamba and there is good information but no clear answer to this question:
The center brake light deck lid uses a three wire turn switch with a strap type housing as shown below. I have bought all the pieces but they are not matchiing up so I am confused as to what I have and what is correct I realize that the early parts might be interchangeable with other makes like BMW etc. Can any of you clarify?
The switch on the far left had a tag with a 211 part # on it. It fits inside the housing but does not do so securely. The other switch fits in the housing securely but it is a six wire switch. It does not have a cancelling mechanism that I can find. The housing is deeper than the typical bus six wire housing I am currently using. Is the pictured housing perhaps a beetle only part and not meant for the bus? _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Wed Dec 22, 2010 8:17 pm Post subject: |
My '57 3-wire switch didn't use a strap housing - it's the same as the later one. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Thu Dec 23, 2010 7:17 am Post subject: |
check the opening for steering column tube. it is smaller on a bus 55-67 than on a beetle t/s housing prior to 60 model year.
the reason i say 1955 is because i believe barn doors had beetle size steering tubes,maybe. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1065 Location: Gilbert,Arizona
Posted: Thu Dec 23, 2010 5:37 pm Post subject: |
My Jan.'57 bus did not have a strap either.Or you could just buy this:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-211-953-513-B _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
