syncro U joint question
TopBud
TopBud is offline
PostPosted: Sun Dec 26, 2010 5:12 pm    Post subject: syncro U joint question Reply with quote
I have some vibrations while driving. I inspected the U joint and it's "loose." I need to buy a new one, but can't seem to find one. I can only find a driveshaft, including greasable U joint which is a few hundred dollars. Is that the only option or can I find a U joint that is cheaper? Does NAPA or anyone else carry a less expensive U joint that fits.
Thanks
86 bostig SYNCRO
66 convertible Karmann Ghia
syncrodoka
syncrodoka is offline
PostPosted: Sun Dec 26, 2010 6:28 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...ft+rebuild
I was able to find the part at a agricultural parts supply shop cheap also.
TopBud
TopBud is offline
PostPosted: Sun Dec 26, 2010 8:36 pm    Post subject: Reply with quote
Thank You! I wasn't using the correct search terms. I'll let you know how it goes.
86 bostig SYNCRO
