tnjanderson Samba Member
Joined: August 27, 2006 Posts: 39 Location: Puyallup, WA
Posted: Sat Jan 01, 2011 11:14 am Post subject: BN-4 Heater Timer |
Hi folks! I've read all of the BN-4 related postings, but do not see anything describing my situation. Basically, after running for 3 minutes or so, my 16 amp fues (the one in the fuse box) pops and everything shuts down. I've tested the motor points, cleaned the flame switch, etc., but no joy. I suspect the problem may be in the timer switch, but cannot find any postings discussing how to test the timer. I have the THING Shop manual, but it does not give much information on the timer itself. Can anyone help me with a timer test procedure? Many thanks in advance! |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Sat Jan 01, 2011 11:41 am Post subject: Re: BN-4 Heater Timer |
tnjanderson wrote: |
Another route to take would be to bypass the timer switch and see if the fuse still blows. Unplug the connector going into the back of the switch, and then jumper the red and grey wires to turn the heater on. If that is successful, i.e. the fuse doesn't pop in three minutes, then jumper the black and gray wires with the ignition switch on. If the fuse doesn't pop, you know the problem is in the switch. |
Posted: Sat Jan 01, 2011 4:03 pm Post subject: BN-4 Heater Timer |
Captain Spalding:
Thanks for the reply. I first started the heater up and let it run. At about 2 minutes, the 16 AMP fuse blew. I turned the system off and put in a new fuse immediately. When I did so, the fan came on (even with key and switch off) as I would expect --- the cool down cycle. When it shut down, I crossed the red and gray wires. 16 Amp blew immediately. Then I crossed the black and gray, turned the key on and blew it again. I guess the problem is not in the switch at this point. Any other thoughts on what I might try in my efforts to run down the real problem?
Manya thanks in advance!
tnjanderson |
Posted: Sat Jan 01, 2011 4:39 pm Post subject: Re: BN-4 Heater Timer |
Hmm. Strange that there was a delay with the switch but none with simple crossing of wires. For no logical reason I'm tempted to suspect a short before a component failure. I guess step one would be to check out the gray wire and the solid blue wire - check the connectors at the ends and check for continuity to ground. Have a look at the relay and the other components on the heater and make sure none of the connectors are touching one another, particularly the safety switch (where the gray wire connects). |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Sat Jan 01, 2011 5:44 pm Post subject: |
The heater is lighting right? And runs for awhile blowing hot air before the fuse pops?
When the thermo-switch flips could be when the fuse pops.
Posted: Sat Jan 01, 2011 5:55 pm Post subject: |
FYI, other BN-4 circuit diagrams in the Samba technical section, here and here. |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sun Jan 02, 2011 8:58 am Post subject: |
sounds like either your gas pump is not working or your spark plug is dirty _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Posted: Sun Jan 02, 2011 12:11 pm Post subject: BN-4 Heater |
Thanks Emeritusx, Captain Spalding and Mike Brasso. I have cleaned and checked everything and concluded it must be in the thermo switch inside the Flame Sensor, or possibly the Safety
Switch --- or a combination of the two. I add in the Safety Switch because when I disconnect the fuel pump (by removing the 8 amp fuse), the fan motor will continue to run essentially forever. I thought it might be the cold air keeping it running, but when I put my torpedo heater next to the car and put a lot of hot air into the fan intake, the fan still runs on forever. I quit timing it at 10 minutes. So, problem still persists. Heater comes on just fine, but after 2 to 3 minutes, the 16 amp fuse blows. When I immediately put in a new fuse, the fan kicks in until the appropriate cool-down period is passed.
Any additional thoughts before I start buying parts on a trial-and-error approach????
tnjanderson |
Posted: Sun Jan 02, 2011 2:06 pm Post subject: |
So it never lights? you never said if it was blowing heat.. |
Posted: Sun Jan 02, 2011 2:17 pm Post subject: BN-4 Heater |
Folks:
Sorry for the confusion. The heater does light up and provide heat as normal --- just quits after about 3 minutes when the 16 Amp fuse blows.
Any additional thoughts????
tnjanderson |
Posted: Sun Jan 02, 2011 5:05 pm Post subject: |
That pretty much rules out the cold circuit, and the fact that your heater fan never shuts off means it doesn't seem to be going back to cold ... I would start with the thermal-switch. Using the diagrams the captain left (print them) you can isolate circuits, it maybe something as simple as a wire is touching ground and when the flame good signal goes true that circuit grounds out.
Does this with ignition on and off right? that would rule out the dash switch. |
Posted: Mon Jan 03, 2011 8:01 am Post subject: BN-4 Heater |
Emeritusx:
Thanks for the input. I'll be the first to admit I don't fully understand the diagram provided by the Captain, but I'll try to get someone to help me with that. Am I correct in assuming the thermal-switch is in the Flame Switch, and thus that might be the fist thing to replace?
Thanks again to all who are contributing to my problem resolution!!!
tnjanderson |
Posted: Mon Jan 03, 2011 11:54 am Post subject: Re: BN-4 Heater |
Emeritusx:
tnjanderson |
Just for fun, you might try manually cycling the reset switch on the back of the safety switch a few times and then fire up the heater again and see what happens. |
Posted: Mon Jan 03, 2011 12:15 pm Post subject: BN-4 Heater |
Captain Spalding:
I tried that yesterday as I was attempting to get the Safety Switch to work properly. When the fan is runing, I can activate the switch and things shut down as expected. I also activated it several times (no power applied) during some of the other troubleshooting efforts. Given that it does not operate as the heater maintenance manual suggests (i.e., does not shut down after 120 - 180 seconds with the fuel pump disconnected), I'm pretty sure it is defective. I'm just not sure if it is a separate issue unrelated to the 16 amp fuse blowing, or a direct part of the fuse problem.
More testing once I get some additional fuses. thanks for your inputs!
tnjanderson |
29thSS Samba Member
Joined: August 25, 2010 Posts: 3 Location: Lookout Junction, California
Posted: Mon Jan 03, 2011 1:05 pm Post subject: |
Ok, I have heard these things turn into flame throwers after time. Is this true and if it is why not switch to an electric heater? |
Posted: Mon Jan 03, 2011 5:12 pm Post subject: |
29thSS wrote: |
You heard wrong. These heaters have been around forever and their safety record is exemplary. At 12V you need 100 amps to get a measly 1200 watts.. An electric heater will never work in a stock VW.
Anyway.. The block diagram above is best to learn how it works, read top to bottom left to right...
Switch on, a nc (edit NC = Normally Closed) contact on the flame sense relay allows CR to energize as long as temp reg falls in the range it was set for (it opens and closes to regulate temp)
Now that CR is energized Contact M J (edit Normally Open) conduct and Fan Motor turns on, Also powering the spark coil. Also Powering the Glow Plug through thr Thermo-Switch And powering the Flame safety Relay
If Flame safety does not see a flame within X seconds it opens and shuts the whole thing down.
Now once the Thermo-Switch switches to HOT Flame Safety is powered down and the glow plug is switched out of the circuit (reducing power consumption by quite a bit)
Thermo Shitch at Hot and the spark coil maintains power all the time, now you can regulate fuel flow (using Normally open contact MB) by opening and closing CR. This allows unit to cool once powered down... Very ingenious engineering - beautiful in its simplicity.
This all applies to the ladder diagram posted above. |
29thSS Samba Member
Posted: Mon Jan 03, 2011 5:47 pm Post subject: |
Well hell thats cool. I guess I am going to get to work on min them as it is 17 degrees outside and I would like a heater. Thanks for the info man. |
Posted: Mon Jan 03, 2011 7:58 pm Post subject: |
29thSS wrote: |
Ok, I have heard these things turn into flame throwers after time. |
Yep. Everyone has heard that. Funny thing is that with all those stories floating around about a heater belonging to a friend of a friend that blew up, you never hear anyone say "my heater blew up."
Emeritusx wrote: |
Anyway.. The block diagram above is best to learn how it works, read top to bottom left to right... |
That's the most lucid and succinct description of how the heater works that I've ever seen. Bravo. |
Posted: Mon Jan 03, 2011 8:28 pm Post subject: |
thanx
Ladder (relay) logic is my forte... Above all else.. I tinker in vw land and am at best an apprentice mechanic, but that kinda stuff I really love to do and am good at. It is the language that runs almost all automation in the industry, but is slowly becoming old school... |
Posted: Mon Jan 03, 2011 9:32 pm Post subject: |
Okay. Now that I've stared at the ladder diagram, I'm becoming a fan of the if/then/else nature of it. But, as I look at the ladder diagram and compare it to my wiring diagram, I don't think it jibes. I'm not saying one or the other is wrong - maybe I just don't get it. But could someone look at both and compare?
Edit: I think the logic is correct, but the labels might be switched in a few places. Check me on this. Third rung down, hot and C should be reversed, no? And J and B on the relay (CR)?
Last edited by Captain Spalding on Fri Jan 07, 2011 9:44 am; edited 1 time in total |
