bvd Samba Member
Joined: September 17, 2010 Posts: 207 Location: Long Island, New York
Posted: Sat Jan 08, 2011 2:46 pm Post subject: Am I missing the Bellows Thermostat? |
Hey guys, these pictures are from my 74 standard which I believe has a rebuilt engine in it with a case from a '75 beetle. I've been reading up on the cooling system and the importance of the bellows thermostat (which as I understand are not produced anymore and fetch high prices). Anyway I looked under my right cooling tin sled today between the push rod tubes and do not see one...I am assuming I am looking in the right spot?...thanks
here are some photos:
Uploaded with ImageShack.us
Is this where the thermostat bracket mounts to the case...in the middle???
Foreboding Zombie Graveyard in the background...
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76909 Location: Sneaking up behind you
Posted: Sat Jan 08, 2011 2:50 pm Post subject: |
Looks like it's missing.
[img][/img]
BTW... you should come to the DasVolks meeting this Wednesday in Farmingdale.
Also you should reduce the size of those pictures to help the topic load faster. _________________ Glenn
Member #1009
#BlueSquare |
bvd Samba Member
Posted: Sat Jan 08, 2011 6:07 pm Post subject: |
Thanks Glenn. So I guess all I really need to get is the thermostat bellows, the thermostat bracket, and then the rod that connects from the top of the bellows to the flap linkage on the fan shroud right? Is it possible to see if the flaps on my fan shroud are there and intact with the engine still in the car? I am hoping the PO didn't remove those as well.
From what I can tell, this would be the correct set up for my car?
http://www.thesamba.com/vw/classifieds/detail.php?id=1055737
If the thermostat had failed the bellows would be fully expanded correct?
And Glenn, does Das Volks meet once every month? I have to work this Wednesday night, but I hope to come to one soon. |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Sat Jan 08, 2011 6:26 pm Post subject: |
yeah, that should do it. i doubt you will find a better deal than that. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Sat Jan 08, 2011 7:07 pm Post subject: |
bvd wrote: |
Is it possible to see if the flaps on my fan shroud are there and intact with the engine still in the car? . |
Have a look at the bottom of the fan shroud where the cylinder tins overlap. Just above this joint, there should be 2 holes on each side for some M6 shroud screws. If the screws are there, the flaps are there. If there are just open holes, you've got no flaps either.
Finding these screws may be a bit difficult, they are hidden by the intake manifold. You may have to feel for them.
Here is a pic showing the right side flaps in the shroud. Note this is the view from the front side of the engine where you can't see with the engine installed.
Here is a complete thermostat kit:
http://www.thesamba.com/vw/classifieds/detail.php?id=957356 _________________
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
emu88 Samba Member
Posted: Sun Jan 09, 2011 10:46 am Post subject: |
Yeah mine is missing too. I think people remove or or neglect to replace them in hot climates - stupid thing really, cause they cost a lot for what they are. |
bvd Samba Member
Posted: Sun Jan 09, 2011 1:10 pm Post subject: |
Hey thanks for all the help and great photo references guys...it's really helping me to understand how this whole system works. Unfortunately, I stuck my hand behind the fan shroud today to find that the holes are empty, meaning the flap assembly is not there. I guess in the grand scheme of things it's not all that bad. I just had one more question. I've been trying to determine if my car has the rear air deflector tins, but have been unable to find a picture of them installed. On Rob and Dave's site, they said they are under the rear pulley?
Here they are on Cip1:
http://www2.cip1.com/SearchResults.asp?Search=air+deflector+tins&Search1=Search
Thanks |
Bruce Samba Member
Posted: Sun Jan 09, 2011 2:06 pm Post subject: |
Here's a pic of the left one installed.
It is the part with the hole in it, directly below the exhaust port. The two shiny screws hold it in place.
This one shows the right one:
Held in place by the same shiny shroud screws. _________________
emu88 Samba Member
Posted: Sun Jan 09, 2011 3:21 pm Post subject: |
Here are my two, left and right:
Seem to be slightly different from Bruces, especially the right one. |
AutoLuxLexES Samba Member
Joined: July 02, 2010 Posts: 65 Location: In the desert somewhere..
Posted: Sun Jan 09, 2011 4:16 pm Post subject: |
why are the air deflectors different?
maybe one for SP motors and other for DP?
Charley |
emu88 Samba Member
Posted: Mon Jan 10, 2011 2:40 am Post subject: |
AutoLuxLexES wrote: |
Charley |
That is what I suspect, but not sure. Others will surely know. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Mon Jan 10, 2011 5:57 am Post subject: |
I believe the tins are different because the geometry of the engine is not mirror-like. The #1/#2 cylinder head is more rearward than the #3/#4 cylinder head. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
priss Samba Member
Joined: May 06, 2010 Posts: 348 Location: bradford MA
Posted: Mon Jan 10, 2011 8:52 am Post subject: |
There ia an air scoop that picks up warm air from off the heads and ducts it up through the rear tin where it is connected by a flexable hose to the oil bath air cleaner at the carb pre-heat flap.
Some are on the right, some are on the left. I have a 1970 singleport, mine is on the right. |
