7thing3 Samba Member
Joined: April 05, 2003 Posts: 473 Location: Cleveland, OH
Posted: Tue Dec 28, 2010 6:34 am Post subject: Cruise Control LED Indicator in Instrument Cluster |
I finally got all the bugs worked out of my Rostra cruise install on my 1987 Syncro. One of the nice features is the unit provides a wire that goes to ground when the cruise is engaged so that you can lead it to an indicator light that always has 12+ running to it (kind of like the old Bug warning lights).
Anyone have any idea how I could use the vacant LED spot next to the OXS LED in the cluster? Any idea if I could get a custom screen made like they do for the conversions for the check engine light?
Another thing I thought of doing was using the front diff lock light as an indicator but that might confuse some people. _________________ '73 Thing--Ted
'77 Super Beetle Convertible
'87 Vanagon GL Syncro
'84 Mercedes 280 CE |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Tue Dec 28, 2010 8:01 am Post subject: |
Quote: |
Any idea if I could get a custom screen made like they do for the conversions for the check engine light? |
There is a guy in the classifieds that could probably make one up for you easily. http://www.thesamba.com/vw/classifieds/detail.php?id=557972 |
Posted: Tue Dec 28, 2010 8:56 am Post subject: |
Thanks--exactly what I was looking for.
Any ideas on the wiring/bulb, etc.? _________________ '73 Thing--Ted
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Wed Dec 29, 2010 10:09 pm Post subject: |
The simplest would be to just wire into the OXS circuit. There is no actual LED or foil wiring to the blank spot next to the OXS. The little colored "LED" there is really just a dummy. _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
Posted: Wed Dec 29, 2010 11:22 pm Post subject: |
2 issues--I really don't want a red light for this as it generally means a problem. Would like to go with a green or blue. Also I ordered a new insert that includes the OXS.
Can I knock out the dummy and put an LED in its place? _________________ '73 Thing--Ted
Posted: Tue Jan 11, 2011 12:32 pm Post subject: |
Finished product. 3.0 volt 5mm green LED, 470 ohm resistor. Panel insert from Klauswesty (outstanding, by the way!). Maybe I should have gone with a dimmer led. I will have to see how it is at night but I don't relish tearing it all apart again. I figure those foil connections only have so many disassemblies in them before something goes wrong.
kamzcab86 Samba Moderator
Posted: Tue Jan 11, 2011 1:49 pm Post subject: |
Clever! I like it; looks factory original! _________________ ~Kamz
2016 Golf GTI S
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Tue Jan 11, 2011 2:00 pm Post subject: |
Looks great man, dimmer LED next time for sure.
Whats this cruise control setup you speak of? |
insyncro Banned
Posted: Tue Jan 11, 2011 2:04 pm Post subject: |
Cool! |
Posted: Tue Jan 11, 2011 2:13 pm Post subject: |
Rostra _________________ '73 Thing--Ted
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Tue Jan 11, 2011 2:22 pm Post subject: |
Excellent. _________________ ☮️ |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Tue Jan 11, 2011 4:32 pm Post subject: |
Nice job.
Try a 1,000 ohm resistor instead of the 470 ohm. This will reduce the current by half thereby making the LED half the luminous intensity. This will appear to be about 2/3rds as bright. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
Posted: Tue Jan 11, 2011 7:22 pm Post subject: |
Thanks. I'll see how it goes. _________________ '73 Thing--Ted
Posted: Tue Jan 11, 2011 7:24 pm Post subject: |
The resistor is kind of a PITA to get to but I can easily get to the line that feeds it. If I keep the existing 470 ohm resistor what ohm resistor should I use--another 470 or a 1000? _________________ '73 Thing--Ted
Posted: Tue Jan 11, 2011 8:25 pm Post subject: |
If you add another 470 ohm inline it will be like having one 940 ohm resistor. You could even add more 470 ohm resistors inline (in series) to lower it more. I'm guessing you bought a 5 pack of resistors at Radio Shack or something. _________________ 1986 Vanagon Westfalia EJ25
Posted: Tue Jan 11, 2011 8:27 pm Post subject: |
presslab wrote: |
I'm guessing you bought a 5 pack of resistors at Radio Shack or something. |
Exactly what I did. I will add them one by one until I find a brightness I like. _________________ '73 Thing--Ted
Posted: Thu Jan 13, 2011 11:16 am Post subject: |
Added 2 more resistors and dimmed it out a bit. Turn signal used for comparison:
coastdog Samba Member
Posted: Fri Sep 08, 2017 10:17 am Post subject: Re: Cruise Control LED Indicator in Instrument Cluster |
Does anyone know if WestyKlaus or 1971BugGuy are still able to make custom LED panel inserts? I'm installing the GW CRUISE CONTROL kit and would really like to put an LED indicator in the panel.
Thanks for any replies |
dbartisan Samba Member
Joined: January 24, 2010 Posts: 14 Location: Aliso Viejo CA
Posted: Fri Sep 08, 2017 11:09 am Post subject: Re: Cruise Control LED Indicator in Instrument Cluster |
I'd be up for a custom insert as well with a check engine light icon next to a cruise control icon on the bottom.
-Steve C. |
Posted: Mon Sep 11, 2017 3:55 pm Post subject: Re: Cruise Control LED Indicator in Instrument Cluster |
Can anyone tell me if a single LED bulb can simply be powered by a 12 volt power source or is there something required to lower the voltage to the light. I'm hoping to put an LED in a blank space in the warning cluster to indicate cruise control on/off. |
