JeffDenson Samba Member
Joined: December 29, 2010 Posts: 71 Location: Hillsborogh N.C
Posted: Wed Jan 12, 2011 4:27 pm Post subject: advice please on my Syncro |
So I have cleaned all I can with the oven, fridge and cabinets in. I am going to have to take them out to clean them the rest of the way. I can tell that the rodents had there way under it. I wanted to ask if there is any thing I should or shouldn't do and how hard of a project is this? |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Wed Jan 12, 2011 4:34 pm Post subject: |
I didn't take mine out but if you have the time and space it is a good idea plus you get to check for rust. An excellent way to clean in small places that you can't reach is hot steam but you need good circulation (I suggest a fan) to dry it out. I vaguely remember a few threads that have dealt with taking the cabinets out. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
campism Samba Member
Joined: September 07, 2007 Posts: 3857 Location: Richmond VA
Posted: Wed Jan 12, 2011 4:55 pm Post subject: |
Westy interior removal is pretty easy if you have the Bentley for guidance and a friend to help with two of the pieces. Bag and tag all the fasteners. You can have everything behind the front seats out in about three hours without hustling. A great way to inspect for rust and the best opportunity for soundproofing. |
JPrato Samba Member
Joined: December 15, 2006 Posts: 775 Location: Livonia, NY
Posted: Wed Jan 12, 2011 6:05 pm Post subject: |
Yes, bag and tag all the hardware you take off. I think the proper sequence (the way I remember anyway) is to start at the sink/stove/fridge cabinet and work your way back. Here is a reference I used http://www.vanagonauts.com/%5B76.20%5D-Sink-cabinet,-removing148.htm Then the water tank cabinet, overhead compartment and finally the closet. It is not as overwhelming as it looks. Take your time and you will do fine. As stated you can give a really good cleaning and check for rust.
Joe _________________ Joe
06 Subaru Legacy turbo (how am I gonna fit this sucker into the Westy....)
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
46 Cessna 140 |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2580 Location: Missoula MT
Posted: Wed Jan 12, 2011 6:26 pm Post subject: |
Just be careful with the rodent debris don't wanna be breathing that shit |
ericos_bob Samba Member
Joined: November 20, 2009 Posts: 71 Location: australia
Posted: Wed Jan 12, 2011 6:47 pm Post subject: |
Ditto on the rust checking. In my experience it can pay off big time not cutting corners. Í removed absolutely all interior from my syncro (wasn't a westy) and found the floor was rusting pretty bad in spots. If I hadn't fixed this when i did I'd have a camper with holes in the floor by now and it'd suck having to rip out your nicely cleaned furniture all over again. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11473 Location: Santa Cruz, CA
Posted: Wed Jan 12, 2011 7:12 pm Post subject: |
In addition to worrying about all of the mouse stuff you should be aware that campers rust from the inside out along the the driver's side wall. Be prepared to deal with rust issues and remove the factory fiberglass in that wall as it is contributing to the problem.
Posted: Wed Jan 12, 2011 7:23 pm Post subject: |
syncrodoka wrote: |
So do you think getting that wall coated with line x would be a good Idea? Of course after all rust is removed.
Thanks for the link, and all the help! What would we do with out forums! |
Home Team Van Samba Member
Joined: January 02, 2008 Posts: 465 Location: wilmington, nc
Posted: Wed Jan 12, 2011 7:56 pm Post subject: |
The problem with that rust is that it's probably worse on the inside. Mine didn't look anywhere near that bad on the outside but I ended up cutting out the panel and replacing it. Because the insulation inside the van retains moisture they rust from the inside out. Fixing what you see on the outside won't solve your problem. here are the steps to removing the interior from a previous post of mine.
Home Team Van wrote: |
crystal... It really isn't difficult. Just bag and label everything. Pictures while it's still together would help you too. Don't forget to unhook your battery. I just put my interior back in so from memory:
Starting with the bench seat there are 3 floor bolts, 2 bolts attaching to the engine deck, 2 brackets(one to the water cabinet and one under the back ash tray). Actually before removing the bench you need to remove the armrest beside it. There is a screw at the bottom rear of the armrest then pull it back towards the rear of the van.
Overhead cabinet has 2 bolts going thru to the closet and I think 3 bolts with brackets that attach to the bed above. Access them from inside the overhead cab.
The closet has 1 bracket attached to the engine deck right at the rear edge of the van and 1 visible inside the closet. there is also 1 screw thru a plate inside the closet. There will be 2 bolts connecting the closet to the water cabinet. You may need to unscrew part of the upper bed to remove the closet. I didn't but I did need to to put it back in.
To remove the water cabinet first unscrew the cap from the bottom of the tank. It took me a few minutes to realize what was going on there. unhook the receptacle and fuse from the water cab and push inside cab. Unhook the power from the pump and from the side of the water tank.You can unhook the water vent, fill hose and hose that go to faucet from inside or pull the box from the outside of the van and unhook from there. Remove 3 bolts that go into the frig cabinet.
Sink and stove. Unscrew the vent on the outside. the frig is connected to it. Make sure the propane is off and disconnect 2 lines at tank. Look in this cabinet and unhook plugs for faucet and frig. Unhook propane lines inside cabinet. Unplug frig from receptacle and remove receptacle. Unhook 1 hose that acts as the drain. unhook 2 hoses that go to faucet. there is 1 bracket that is attached to the wall of the van near where the camping fuses are. There is one bolt attaching the cabinet to the floor. remove bracket that holds front table.
I'm sure I left some stuff out but that should get you most of the way. |
_________________ _________________________________
82 Diesel Westy |
Posted: Wed Jan 12, 2011 8:18 pm Post subject: |
Thanks for the info. Taking pictures is a great idea! So what do I do to stop the damage on the inside I was thing line x coating  |
OwnYourReality Samba Member
Posted: Wed Jan 12, 2011 8:45 pm Post subject: |
JeffDenson wrote: |
Best to "use the search" for that one. Type in 'rust', or 'rust repair' & you'll get a plethora of info. There's more opinions about it then there are colors. I spent hours upon hours sifting thru it, then researching & sifting some more before I tore down my Syncro this summer to tackle the job. Well worth the effort for sure. Lots of experience to draw from in these forums. Enjoy the bonding time with your new van, looks like fun. _________________ "Imagination is more important than knowledge"
Al Einstein |
Posted: Wed Jan 12, 2011 8:46 pm Post subject: |
JeffDenson wrote: |
Al Einstein |
ckissick Samba Member
Joined: August 22, 2006 Posts: 481 Location: Bay Area
Posted: Wed Jan 12, 2011 9:35 pm Post subject: |
While the fridge is out, it's a good time to do the GoWesty upgrade that makes it easier to fire up on the propane. _________________ Charlie
1950 Beetle
1983 Westfalia
1989 syncro Tristar
1966 Porsche 912
1989 Beck Spyder
2007 GTI Fahrenheit |
Posted: Thu Jan 13, 2011 9:24 am Post subject: |
ckissick wrote: |
While the fridge is out, it's a good time to do the GoWesty upgrade that makes it easier to fire up on the propane. |
and to soundproof, replace insulation, replace fridge fan, replace water lines, put in hard wood floors, etc... it goes on and on.
Once you get everything out you'll be able to see the extent of the rust. Only then will you be able to figure out the best way to tackle it. Once I replaced that lower panel I did coat the inside wall behind the stove/sink with bed liner just for piece of mind. I have a lot of pics showing how I fixed mine. Let me know if you want to see anything. _________________ _________________________________
82 Diesel Westy |
DAIZEE Samba Member
Posted: Thu Jan 13, 2011 9:35 am Post subject: |
by the way a non carpet floor is easier to clean and/or to dry when gets wet. I had laminate (floating) put in mine. Then keep a piece of rug for outside the slider. Guess you have to stick with carpet up front. I pressure washed my front formed carpet, put down new underlay and reused that carpet. I threw out the underpad due to all the years of rodent urine. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4634 Location: Twain Harte, CA
Posted: Thu Jan 13, 2011 10:00 am Post subject: |
And find the source of the moisture.
It can be coming from the utility ports..
or from the vertical panel seams..
or from the window area..
My Westy.. which only shows a slight discoloration hint of corrosion near the leading front edge of that horizontal kitchen seam.. leaks from all three of those locations.
If you decide to pull the water cabinet, too, you'll likely find corrosion along the seams of the rear wheel well arch.
If you do not source and close up these leak source(s).. all your hard work to repair rust can be undone, maybe in just a yr or two.
If water is allowed to pool in there and sit? You'll be seriously bummed.
I removed my kitchen unit about a year ago.. Its been out since.
The project can lead to lots more work. Be prepared for that.
I was and am not ready to do the vertical seam repair.. so I will leave the kitchen unit out which makes this problem area much more accessible. I can mop up water when it accumulates, monitor the rust along the lower seam(which has been sealed with POR-15 from the inside), and determine if a temp fix will seal those vertical seams well enough (the ports are an easy fix, BTW)
My kitchen window shows one area with signs of rust, as well. That will have to come out before the project could be called "complete".
I'd recommend you NOT rush it.
I have personally seen a van (nearby my home) that had a lower seam panel repair done, new paint on the entire van, and then it rusted thru again within 2-3 yrs.
The van was not garaged. And it lived in a foggy coastal environment.
Good luck with your project.. even with the cleanup work, that van is a very nice find. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 2895 Location: Dartmouth, Mass.
Posted: Thu Jan 13, 2011 10:47 am Post subject: |
candyman wrote: |
Please heed Candyman's advice - it is really serious. On a different note - next time name the post so someone searching for the same info can find it. In other words you are dealing with mice and removing interior pieces - so the title could have reflected that. There's nothing specific to the Syncro at all in what you are doing.
John |
Posted: Thu Jan 13, 2011 5:16 pm Post subject: |
Thanks for all the help! I got the seats, carpet, sink/stove top off. Is there a bolt under the fridge? I am having a hard time getting the fridge out?
On the rust I have a lot of spots under my windows that are rusting out. I plan on removing all the windows and send it to the body shop. I have a guy that works with me that has done glass work for years. He is going to help me with that. I have lots of rust even at the back window. I am guessing I can still get all the glass molding/ weather striping? |
JunkYarDog Samba Member
Joined: March 11, 2007 Posts: 676 Location: New Mexico
Posted: Thu Jan 13, 2011 5:19 pm Post subject: |
Syncro's are junk plagued with problems, just put it on a truck and send it to me I'll take care of it.  _________________ I have never owned a VW I didn't like, but there have been a few Fords and Chevy's.
85' GL Sunroof
68' Beetle sedan
72' Chevy C10 (LWB Step)
(67' Volvo 122S pending) |
Posted: Thu Jan 13, 2011 5:25 pm Post subject: |
yes all the window seals are available. you can get the seals with or without the grooves for the chrome looking plastic edging. I believe the seals with grooves are more then of course you have to buy the edging too if you go that route,.
When you say you can't get the fridge out are you talking about the whole cabinet or just the fridge? Did you undo the flue vent on the outside of the van? _________________ _________________________________
82 Diesel Westy |
