Denzel full flow filtercan - insert?
oval56
oval56 is offline
PostPosted: Thu Jan 13, 2011 5:38 am    Post subject: Denzel full flow filtercan - insert? Reply with quote
so the time is close and i can install my denzel pump cover and filterhousing on my new engine (74x82,5)... but i have a problem, does anyone know where to get the right oilfilterinsert for that housing?
thanks
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
John Moxon Premium Member
John Moxon is offline
PostPosted: Thu Jan 13, 2011 6:18 am    Post subject: Reply with quote
Is that larger than the F3P Andi?
John.
oval56
oval56 is offline
PostPosted: Thu Jan 13, 2011 6:27 am    Post subject: Reply with quote
no john, but the diameter of the inner tube is bigger, i can measure it today / tonight.
the inner tube as a owhn oilpresure valve with spring installed and is bigger the housingdimension should be the same...will check it
www.oval56.com
www.dbkvw.com
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Thu Jan 13, 2011 8:03 am    Post subject: Reply with quote
Hello-
My full flow canister filter is model FH6-PL, and uses a CH-6PL filter.
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Mr. Okrasa Premium Member
Original Old Speed
Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Mr. Okrasa is offline
PostPosted: Thu Jan 13, 2011 10:36 am    Post subject: Oil Filter Size Reply with quote
Many people have the misconception that any filter can be used as a "full flow". The typical "by pass" oil filter that is used on the Okrasa engine is not the same as the one used for the "full flow" Denzel. If you notice this Denzel oil filter has a LARGER inlet and outlet openings necessary for maintaining proper flow/pressure while filtering 100% of the oil. Cheers!
Notice this black and white photo of an original Denzel engine with the same filter. Note the diameter of the oil lines to and from filter.
Here is another photo of a Denzel engine I purchased that has the same diameter filter and lines below:
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint Wink
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
PostPosted: Thu Jan 13, 2011 10:47 am    Post subject: Reply with quote
So what's the designated Fram model # on that one Joe?
John.
Original Old Speed
PostPosted: Thu Jan 13, 2011 11:30 am    Post subject: Reply with quote
Here are some more photos that show the major differnces between the two filters. I purchased several of these
NOS Denzel full flow oil filters years ago when nobody wanted them because they were too big???? Cheers!
VW www.Okrasa.com
356 www.PreA356.com
PostPosted: Thu Jan 13, 2011 11:50 am    Post subject: Reply with quote
Ah right Joe thanks for that...the same as Paul's.
gimmesomeshelter wrote:
Hello-
Paul
John.
oval56
oval56 is offline
PostPosted: Thu Jan 13, 2011 1:56 pm    Post subject: Reply with quote
as ia said full flow:
which filterinlet can i use??
www.oval56.com
www.dbkvw.com
Danpa
Danpa is offline
PostPosted: Thu Jan 13, 2011 7:14 pm    Post subject: denzel full flow filtercan - insert? Reply with quote
This is the Wix filter I'm using for my old Purolator NE-1517;
Part Number: 51076
UPC Number: 765809510760
Principal Application: Dodge Trucks (65-75), Chrysler Industrial Engines
All Applications
Style: Cartridge Lube Metal Canister Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.198
Outer Diameter: 3.367
Inner Diameter: 0.764
Nominal Micron Rating: 25
Just about done changing it over from a bypass to a full flow.
oldbusboy
oldbusboy is offline
PostPosted: Mon Dec 23, 2013 12:31 pm    Post subject: Reply with quote
If I wanted to track down the larger diameter oil lines for this larger filter who has them? I'd need both the oil line and banjo fittings.
Trevor
1968 porsche
Danpa
Danpa is offline
PostPosted: Mon Dec 23, 2013 8:07 pm    Post subject: Reply with quote
Trevor
Don't know if this helps or not.
http://www.newcoproducts.com/flexi-hoses/german-hoses.htm
PostPosted: Tue Dec 24, 2013 1:03 am    Post subject: Reply with quote
Trevor
Ask Mike if he can help you...he supplies Fram Filter oil lines to your specificatios: http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=34259
John.
thomas.
thomas. is offline
PostPosted: Thu Dec 26, 2013 10:46 am    Post subject: Reply with quote
For those who weren't aware the original is again available in the USA.
http://www.cbperformance.com/ProductDetails.asp?ProductCode=1699
vwmadeinireland
vwmadeinireland is offline
PostPosted: Thu Sep 13, 2018 7:09 am    Post subject: Re: Denzel full flow filtercan - insert? Reply with quote
No that kit is a BYPASS kit, not a FULL-FLOW canister/filter.
I have 7 NOS Denzel filters left in case anyone is interested:
yesitsme
yesitsme is offline
PostPosted: Sat Jul 25, 2020 6:52 am    Post subject: Re: Denzel full flow filtercan - insert? Reply with quote
Hi,
I’m interested in buying one of your full-flow filters, if you still have one. I‘m in Germany.
Regards
Norfried
Big_E_Deluxe
Big_E_Deluxe is offline
PostPosted: Tue Jul 28, 2020 6:23 am    Post subject: Reply with quote
Trevor
For banjo fittings, try Belmetric: https://www.belmetric.com/metric-banjo-fittings-c-1041/?zenid=0fp107m9quve3s39148kpq36a0
For banjo fittings & lines, try Partsklassik: https://www.partsklassik.com/c-14-shop-supplies.aspx
Edit: Didn't realize how old this thread was, haha. Never too late to post info I guess.
Erik
1958 VW Beetle - "Max": https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
1959 VW Bus - "Hans" - Double Door Panel (sold): https://www.thesamba.com/vw/forum/viewtopic.php?t=746927
2014 Porsche 991.1 Carrera S
