sneal1956 Samba Member
Posted: Tue Dec 22, 2009 4:28 am Post subject: Bonnets / Hoods |
Do the bonnets change between the oval and the first big windows? or are the big window bonnets the same as the 61 - 63?
Also if anyone could show me a correct bonnet handle for a 56 I would appreciate it.
Thanks in advance. |
valentinesr Samba Member
Joined: June 30, 2008 Posts: 749 Location: Ontario, California
Posted: Tue Dec 22, 2009 4:50 am Post subject: |
I believe there are more differences than just the ribs in the photo that I have posted..It does have:
4 Tab Slots
Hood Badge Slots
Ribs on each side of the lower corners of the hood..
I dont know about the third bolt for the hood prop..
1956 Hood Bonnet
1958 Hood Bonnet (Notice the changes again in the lower corner)
Early Hood Bonnet (Notice Difference)
_________________ Valentine, Ray J Sr.
Ontario, California
thebucket wrote: |
I gave my oval a nasty look. Money hungry bitch.... |
(Delilah) http://www.thesamba.com/vw/forum/viewtopic.php?t=319235
1954 Parts Book (CD PDF) PM TO INQUIRE
splitjunkie Samba Member
Posted: Tue Dec 22, 2009 5:48 am Post subject: |
valentinesr wrote: |
1958 and later Hood Bonnet
1957 and earlier Hood Bonnet (Notice the changes again in the lower corner)
1957 and early Hood Bonnet (Notice Difference)
You had your descriptions wrong. I have corrected them. _________________ Chris
Posted: Tue Dec 22, 2009 6:07 am Post subject: |
Thanks for the replies. So does this mean that the only difference between a 57 - 61 and a 61 - 63 bonnet is that the later has a 3 pin VW badge instead of the earlier 4 slot one? |
Suboval Samba Member
Posted: Tue Dec 22, 2009 9:01 am Post subject: |
sneal1956 wrote: |
58-60: 4 tab VW emblem and the single wide pressing for the hinges.
61- early 63: 3 pin badge and the single wide pressing for the hinges.
late 63 - 66: 3 pin VW emblem on a plinth (raised circle) and the single wide pressing for the hinges.
67 and later: I dunno _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
FRK Samba Member
Joined: December 09, 2002 Posts: 2652 Location: Orange county, CA
Posted: Tue Dec 22, 2009 9:15 am Post subject: |
sneal1956 wrote: |
Yes!
This is 58-60.
56-57 Hood with only 4 bolts.
This is 55 hood only (7 months between January-July). Its just like 56-57 hood but with 5 bolts and no triangle.
Late 53 to the end of 54 Hood is just like the 55 but with the triangle.
Mid 53 and split Hood is just like the 54 hood but with 7 bolts.
_________________ 64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club |
Posted: Tue Dec 22, 2009 11:28 am Post subject: |
Fantastic. cheers.
So from this I have worked out that the bonnet I was thinking of buying isnt correct as its a 55 bonnet with the 4 tab and 5 bolt holes.
I need to find a 4 tab and 4 bolt for a 1956 Oval. (although doesnt the picture above labelled 56 - 57 4 bolts also show 5 bolts? er confused)
and that the bonnet currently on my car is definately a 61 - 63.
My search continues then....
(oh and I never knew about the triangle for the earlies!) |
FRK Samba Member
Posted: Tue Dec 22, 2009 12:36 pm Post subject: |
sneal1956 wrote: |
Well, that's why I typed 4 bolts. '56-'57 is definally 4 bolts. _________________ 64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club |
kidvintage Samba Member
Joined: February 09, 2004 Posts: 191 Location: Orange County, CA.
Posted: Tue Dec 22, 2009 6:41 pm Post subject: |
Not to confuse an already confusing issue.......but 61's came with four tab hoods as well. Are they the same as the 58-60 configuration?? |
Posted: Tue Dec 22, 2009 7:31 pm Post subject: |
FRK wrote: |
sneal1956 wrote: |
Well, that's why I typed 4 bolts. '56-'57 is definally 4 bolts. |
Frank,
I think he was talking about the hood that I have. You listed it as 56-57 4 Bolt, but theres 5 Bolts..
*Which I will be selling, cause I need a correct hood. _________________ Valentine, Ray J Sr.
Ontario, California
thebucket wrote: |
1954 Parts Book (CD PDF) PM TO INQUIRE |
Posted: Wed Dec 23, 2009 1:47 am Post subject: |
Ah thanks for all your help in clarifying (its good to know I wasnt going mad...) |
FRK Samba Member
Posted: Wed Dec 23, 2009 6:58 am Post subject: |
FRK wrote: |
sneal1956 wrote: |
Frank,
*Which I will be selling, cause I need a correct hood. |
yeah, I know! That's why I make sure I type 4 bolts for '56-'57.
When are you coming back to LA? _________________ 64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club |
ericktheelectrician Samba Member
Posted: Tue Jan 11, 2011 9:08 am Post subject: |
kidvintage wrote: |
61 had a 3 tab raised emblem as well as late 60 mid 1960 is when they discontinued using the 4 tab hood _________________ 53 3 fold rag O.G (sold)
54 vert restomod
56 vert O.G
63 Karmann Ghia
60 double door deluxe
49 standard |
OvalinAz Samba Mini Tech
Posted: Tue Jan 11, 2011 3:17 pm Post subject: |
ericktheelectrician wrote: |
kidvintage wrote: |
61 had a 3 tab raised emblem as well as late 60 mid 1960 is when they discontinued using the 4 tab hood |
nope. in 61 or late 60(i think) there was a 3 tab non-raised emblem, i got one on my oval. _________________ Dad's 4/55 Oval
8/56 Oval
5/64 French Notchback
12/62 French 11 Window Bus
Wedge VW
Pandraggers C.C.
Posted: Tue Jan 11, 2011 3:55 pm Post subject: |
OvalinAz wrote: |
kidvintage wrote: |
nope. in 61 or late 60(i think) there was a 3 tab non-raised emblem, i got one on my oval. |
either way 4 tabs stopped in early 60 also splits had 3 tab ,7 bolt , hood crest bonnets not to be confused with the later 3 tab hoods with only 4 bolts and no hood crest slits _________________ 53 3 fold rag O.G (sold)
54 vert restomod
56 vert O.G
63 Karmann Ghia
49 standard |
ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Thu Jan 13, 2011 10:34 am Post subject: |
ConcreteAce wrote: |
either way 4 tabs stopped in early 60 also splits had 3 tab ,7 bolt , hood crest bonnets not to be confused with the later 3 tab hoods with only 4 bolts and no hood crest slits |
No they did not stop in early 60. my 61 has the original hood and it is a 4 tab hood.
FYI
check this thread out it gives the chassis number that they stopped the 4 tab hood.
http://www.thesamba.com/vw/forum/viewtopic.php?t=250199&postdays=0&postorder=asc&start=0 |
I stand corrected the first 3 months of the 61 production year (end of 1960) did use the 4 tab hood I was confusing the change in the front apron early 60's were a 4 finger front apron and mid 60 started the use of the 3 finger front apron _________________ 53 3 fold rag O.G (sold)
54 vert restomod
56 vert O.G
63 Karmann Ghia
49 standard |
Birdman69 Samba Member
Joined: January 20, 2011 Posts: 14 Location: Sydney Australia
Posted: Wed Nov 23, 2011 5:05 am Post subject: |
I have a 4 tab which has been dented in the top corner.
A friend has told me these bonnents have a shallower pressing than later bonnets???
I only need to replace the top corner of the skin (not the braces where the hinges mount) but i dont want to source and destroy another 4 tab if I dont need to??? |
