NONYA Banned
Posted: Thu Jan 27, 2011 7:16 pm Post subject: headers installed,now what.. |
DO I do for with the down tubes that used to go to the heater boxs?Leave the flex tubes off?run them down through the tin?Thanx |
gt1953 Samba Member
adams77 Samba Member
Joined: September 12, 2008 Posts: 221 Location: Statham, GA
Posted: Thu Jan 27, 2011 7:37 pm Post subject: |
some guys plug the holes, some don't, some even plug the holes with plugs that have holes. Try a search and you will find lots of info. The hard part is deciding what to do once you have all the info. _________________ If Stupidity got us into this mess, then why can't it get us out? ....Will Rogers |
NONYA Banned
Posted: Thu Jan 27, 2011 7:43 pm Post subject: |
Do you have a pic of them installed?If they are plugged do you risk overheating? |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Fri Jan 28, 2011 1:15 am Post subject: |
NONYA wrote: |
gt1953, I think you might need to start A tread/how-to..
I got the parts for mine, waiting to git some time to crawl under and start _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1590 Location: Seattle, WA
Posted: Fri Jan 28, 2011 1:41 am Post subject: |
Original poster, what's the engine and what type of header? Heaterbox delete tubes are often called "J-tubes" - even when on a competition style header.
If you're leaving off the heaterboxes, you want to block the holes in the tin, you can buy '2" knock-out seals' for electrical work that do the job quite well...as well as installing 1-7/8" freeze plugs in the shroud itself - this is where some people prefer to have holes drilled.
Here is a heaterbox riser I made to fit the customized header on my Baywindow...
Posted: Fri Jan 28, 2011 1:47 am Post subject: |
Chris Vellat wrote: |
damn Chris, yours look good to!! _________________ 1302s sunroof..
NONYA Banned
Posted: Fri Jan 28, 2011 6:56 pm Post subject: |
Here we go,problem solved!
Posted: Sat Jan 29, 2011 3:11 am Post subject: |
NONYA wrote: |
LMFAO love it!!
don't think your going to git A lot of heat tho... _________________ 1302s sunroof..
NONYA Banned
Posted: Sat Jan 29, 2011 3:32 pm Post subject: |
heaters are a thing of the past on this buggy,does anyone have a diagram showing the airflow of the aircooled vw motor? |
