HankScorpio Samba Member
Joined: August 30, 2010 Posts: 375 Location: Connecticut
Posted: Tue Feb 01, 2011 10:38 am Post subject: "stock look" performance engine? |
I was wondering what would be the the best modification too improve power without looking like a "hot rod" engine.
I have a stock 1972 standard Beetle.
Basically I'd like non-VW car guys to assume it's stock at first glace.
For example I'd like to keep the oil bath filter, but I wouldn't be apposed to a different carb. The exhaust isn't too visible from under the hood so as long as the tail pipes use the stock holes I'd be happy. That sort of thing
Also keeping within a sane budget would be nice too. I'm not on a shoe string budget but the sky isn't the limit either
Let me know if you have any thoughts. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80382 Location: Sneaking up behind you
Posted: Tue Feb 01, 2011 10:47 am Post subject: Re: "stock look" performance engine? |
| HankScorpio wrote: |
| Basically I'd like non-VW car guys to assume it's stock at first glace. |
non-VW guys think the engine should be in the front. They have no idea what stock looks like. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2163 Location: Salt Lake City
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Tue Feb 01, 2011 10:59 am Post subject: |
put a lawn mower enging in the front also.
keep the stock small carb & intake & air kleener,but add a set of 44 idf webbers,mild cam,rockers,hide away header,plentt of port work,84 mm stroker crank 5.5 rods,94mm p&j.stage 1 pressure plate.fullflow& filter&cooler. and build some black louvered boxes to cover the webbers&intakes.use a stock single port intake and run it into the boxes. use good and quiet mufflerthat has a 2"outlet so the camarow&mustang& the few honda's have a place to drip out after you have eaten them. no go have funn. |
Almost Alive Samba Member
Posted: Tue Feb 01, 2011 11:12 am Post subject: |
On thesamba from your cell phone again Mark?
There is a guy overseas making 2180's with a stock carb and exhaust. I don't have the link but its been posted more than a few times here. The engines look 100% bone stock from the outside. I'd imagine they are stump pullers for sure... 2180 with a stock solex... intense.
That being said the sky is nearly the limit.
Personally I would go 69x94. Keep your engine width stock all while making (if properly set up) around 100-120hp.
Be careful with heater boxes though. Anything about a 1776 should have performance heater boxes on it or your likely to fry your heads. |
Posted: Tue Feb 01, 2011 11:15 am Post subject: |
| ZI try to speel feneticly so the not so bright can read it easy.just doing my part for the american edjukaytion system. |
Posted: Tue Feb 01, 2011 11:20 am Post subject: |
| mark tucker wrote: |
It took me just as long to read that as it did to type my reply earlier.
Long live reeturds on the internut. |
seanboy69 Samba Member
Joined: October 22, 2008 Posts: 1107 Location: Templeton PA
Posted: Tue Feb 01, 2011 2:22 pm Post subject: "stock look" performance engine? |
Build a bulletproof stroker an hide a NOS system under the oil bath air cleaner. Would be cool...  _________________ In a sea of american muscle there is alittle bug hiding in the corner...
Oh, and I am 39 years old.....I am supposed to know better......ha!!!
1956 oval ragtop
1962 baha
2276 in progress |
slalombuggy Samba Member
Posted: Tue Feb 01, 2011 2:40 pm Post subject: |
Fuel injection with stockish manifolds and single throttle body under your air cleaner. Weld a bracket to hold your peashooters out hte back and a big hideaway system under the fender. Big Blue bottle in the behind the backseat with a speaker cover over it. Killer gerbox with M&H DOT tires.
Stealth
Or you could do like the guy did about 15 years ago relocate the firewall for a totally hideaway turbo injected, NO2, 300hp stroker bone stock EVERYTHING as far as body, wheels and tires. It was even that hideous baby blue colour.....
SLEEPER
brad |
SamT Samba Member
Joined: April 17, 2009 Posts: 1767 Location: Rule, Tx
Posted: Tue Feb 01, 2011 3:01 pm Post subject: |
seems that just being a VW gives enough of the Sleeper factor.
I used to have no trouble getting a guy with a V8 longtravel rail to lay down a $100 for a sand drag. Mind you the buggy I drove then was a 70's 87 wheelbase frame, with a swingaxle, used aluminum parts that were tarnished to say the least, and some chewed up dick cepek 14.50 paddles. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Feb 01, 2011 4:11 pm Post subject: |
There is someone on here that has the ultimate sleeper engine
it's a 2L+ turbo but too look at looks like a bog stock 1600 twinport.
Turbo is hidden under the apron and ducted into the carb through what looks like the preheat hose and stock oilbath air cleaner
someone will have pics of it _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Tue Feb 01, 2011 4:13 pm Post subject: |
| I kinda go for that looks wicked but it's a vw look. |
Glenn  Mr. 010
Posted: Tue Feb 01, 2011 4:45 pm Post subject: |
| Joel wrote: |
someone will have pics of it |
2332 EFI, crankfire turbo mated to a Berg 5 speed tranny.
Member #1009
#BlueSquare
Joel Samba Member
Posted: Tue Feb 01, 2011 4:54 pm Post subject: |
Nah that's not the one but it was on a red late bug with tombstone tail lights
This one was carbed, had a 34pict3 carb and the aircleaner acted as the carb hat and the up pipe was inside the preheater hose.
To look at even most knowledgeable vw people would dismiss it as a stock early 70s carbed 1600.
Be fucked if i can find the thread it was in. _________________ Quick little bug, you got a Porsche motor in that?
Joel Samba Member
Posted: Tue Feb 01, 2011 5:00 pm Post subject: |
ha, found it
2110 turbo
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Wed Feb 02, 2011 2:41 pm Post subject: |
| Glenn wrote: |
| Joel wrote: |
I had to look twice , thought the ex was on the ground.that aint gonna work around hear lol. but I do like the intake,that is what should be used with the center mount idf stuff. |
Posted: Wed Feb 02, 2011 7:41 pm Post subject: |
Thanks for all the suggestions. I have to admit I wasn't thinking as extreeme as most of you. I guess I just need a little more nitros in my blood
I think the guy that built this one is my new hero
| Joel wrote: |
ha, found it
2110 turbo
