T8kitease Samba Member
Joined: March 17, 2006 Posts: 163 Location: Long Island, N.Y.
Posted: Sun Feb 06, 2011 8:10 pm Post subject: 70 Beetle Resto-Mod Project |
Here's my 70 I bought back in 06. Jusy started uploading pics and figured I start a page. The project had stopped for 2 years after I finished the pan due to home improvements. I just got back in the garage this winter to start again! I'm still learning things while keeping it fun. Hope i could help anyone in need of info or pictures. I'll be adding more pictures of the work thats done up to date.
Matt
_________________ Matt
70 Beetle Resto
http://www.thesamba.com/vw/forum/viewtopic.php?t=450346 |
GreeneHoosier Samba Member
Joined: August 16, 2004 Posts: 406 Location: Southern Indiana
Posted: Mon Feb 07, 2011 5:29 am Post subject: |
Looks like a nice find. Especially for an eastern car. I have a 70 that is the same Ruby Red, by the best you can afford when it comes to parts, there is a lot of crappy stuff out there for these little cars. Good luck! _________________ 1974 Super Beetle
40 Years VW enthusiast! |
redrum71 Samba Member
Joined: August 07, 2006 Posts: 494 Location: No-wheresville KS
Posted: Mon Feb 07, 2011 6:24 am Post subject: |
GreeneHoosier wrote: |
Looks like a nice find. Especially for an eastern car. I have a 70 that is the same Ruby Red, buy the best you can afford when it comes to parts, there is a lot of crappy stuff out there for these little cars. Good luck! |
New looking bug, I wish I had pop out rear windows on mine, I love those! and, Trust me, if you can't afford quality parts, don't buy them because your gonna end up replacing them down the road! Been there done that a time or two _________________ 72 FAT chick
71 baywindow -
67 Baja |
Posted: Mon Feb 07, 2011 1:03 pm Post subject: |
Thanks, it does need some surgery, pans, heaterchannels and to correct some PO hacking. Thanks for the advice! I've been buying the best i can. This site has been great for researching feedback on parts and suppliers. Heres a couple more shots.
70 Beetle Resto
Posted: Mon Feb 07, 2011 4:51 pm Post subject: |
Removed the body and stored it outside
Removed pedal cluster, trans and axle shafts
Started cutting out floor pans using sawzall, air body saw and air chisel for leftover spot welds. Spotweld drill to drill other areas out.
Removed the trailing arms.
70 Beetle Resto
Posted: Mon Feb 07, 2011 11:53 pm Post subject: |
Damn your not messin around huh? looking good! _________________ 72 FAT chick
71 baywindow -
67 Baja |
Posted: Tue Feb 08, 2011 8:31 am Post subject: |
Thanks red, I like to try to make it better than it was in 1970. Also helps to have a friend who's a welder and owes you some work time! _________________ Matt
70 Beetle Resto
Redvolk65 Samba Member
Joined: September 07, 2010 Posts: 290 Location: Los Angeles,CA
Posted: Tue Feb 08, 2011 9:31 am Post subject: |
nice work keep doing it |
Posted: Tue Feb 08, 2011 1:48 pm Post subject: |
Started drilling spot welds and cutting mainly to understand how the framehead is assembled and to cut in the right spot. Alot of drilling
New parts
Sliced off the old head! Goo Byeee!
Did some trimming and placed the new head for the first time only to find it needs more.
70 Beetle Resto
gtxbullet Samba Member
Joined: July 29, 2010 Posts: 258 Location: Pewaukee, Wisconsin, 53072, United States
jays Samba Member
Posted: Tue Feb 08, 2011 2:05 pm Post subject: |
oh wow i wish i couldve gotten this into the restoration of my bug :[ making me sad man |
Posted: Tue Feb 08, 2011 2:47 pm Post subject: |
Thanks, it is alot of work but it will be like a brand new bug n I get the experience of wrenching on it myself. I love working on it and each stage I get through the confidence level rises also. All said and done i could step back and say " I brought this bug back!" _________________ Matt
70 Beetle Resto
flierbob Samba Member
Joined: August 21, 2008 Posts: 538 Location: Silverdale WA
Posted: Tue Feb 08, 2011 3:02 pm Post subject: |
Got to love the VW wiring, make sure the fresh air drain is hooked up so the water won't ruin the trunk.
Wow is right, that looks like you are going after it!!!
Bob |
Posted: Tue Feb 08, 2011 4:03 pm Post subject: |
Cut 2 access holes in side of tunnel to weld clutch tube bracket and run new fuel line.
Degreased the inside of the tunnel and it took of all the paint also!
Then discovered broken clutch tube bracket at the cluster hole
All welded up
70 Beetle Resto
DaniG Samba Member
Joined: January 06, 2011 Posts: 82 Location: Colorado
Posted: Wed Feb 09, 2011 12:58 pm Post subject: |
Not only did you bring it back, you'll be able to keep her running darn-near forever! Very impressive. I have a weakness for red VW Beetles anyway. |
Posted: Wed Feb 09, 2011 2:35 pm Post subject: |
Thanks DaniG! The OG paint is nice but its under about 4 other colors!!
Uploaded some more shots. I wanted to keep the german brake hose brackets.
Considerable difference in thickness
Started running the 3/8 SS fuel line through the tunnel
Welded on SS 6AN fittings on each end
PO took a air chisel and opened up the tunnel to the side of the inspection cover to run a rubber fuel line out of. Started straightenig out the metal
70 Beetle Resto
Posted: Thu Feb 10, 2011 5:17 pm Post subject: |
Welded in some extra steel for support. Silver paint is Weld-thru II weldable primer. crap for tig welding.
Framehead welded up
Framehead support modified and blasted
First fit for floorpans. Needed a trim here and there but worked out real good.
Cleaned them up and punched holes with air flange/punch tool
Removed th seat tracks in order to install custom seat brackets
70 Beetle Resto
Posted: Thu Feb 10, 2011 5:50 pm Post subject: |
Great work, that looks like the hard way to install new gas line unless you are fixing every thing else also. nice welding also.
Bob |
