azbob Samba Member
Joined: April 04, 2010 Posts: 717 Location: Phoenix, AZ
Posted: Mon Feb 07, 2011 10:55 am Post subject: Barrel Shim question |
I've done a few searches on getting the right compression ratio based off my deck height and head volume. I'm not finding a calculator to figure out what size my barrel shims are. I have a head volume of 4600cc, 94mm cylinders(machined to a 1915cc), deck height on one side is .025 and the other side .038. How do I calculate the size of shims I will need off of that to get the proper deck height for compression? And, what would be the proper compression? I'm still new to this engine stuff. _________________ Bus Builder |
mharney Samba Member
Posted: Mon Feb 07, 2011 11:16 am Post subject: |
We'll assume that you mean 46cc head volume.
Your camshaft defines reasonable compression.
With your deck height reading 0.015" different between sides, you should at the very least double check all 4, to see if this is true front to back. If it is not, your case needs machine work. If it does, then you will need base shims that are 0.015" thicker on the side that reads a smaller deck to make them the same.
Then you can plug it into a deck height calculator tool online to arrive at the deck you need, and then calculate the spacers. |
Ball10 Samba Member
Posted: Mon Feb 07, 2011 11:20 am Post subject: |
You need the same deck on both sides, 0,038 is a bit tight but should work.
So 0,038-0,025=0,013 an put that on the 0,025 side.
The deck is there so the pistoins don't hits the heads, and is not for setting CR. You do that with fly cutting the heads. Need more info on cam, heads, carbs etc in order to give advice on CR.
There is a spread sheet in tech section so you can calculate CR- _________________ My bad judgement has brought me much joy. |
azbob Samba Member
Posted: Mon Feb 07, 2011 11:52 am Post subject: |
I've got a pretty nasty cold right now so forgive me if I am asking some real stupid questions or miss making sense, the making sense part is normal
So left and right side of the engine, both need to be the same? I thought this was only when front and back(single side) were different? I measured each and they were the same.
As for the volume, I put in a spark plug and filled a single head with water using a 100cc syringe 46 times up to the flat(where the barrel sleeves would meet the head, not over). So maybe I'm confused here.
The heads were machined and there's no way in hell I'll take them in again based off deck height after what I paid CE to do it. My but still hurts from that bill...
Thanks you two! _________________ Bus Builder |
bartman Samba Member
Joined: February 22, 2004 Posts: 767 Location: palatka, fl
Posted: Mon Feb 07, 2011 1:22 pm Post subject: |
That was probably a 100 unit syringe or 1 cc. About as big around as a pencil? 100ccs is almost 4 ounces. The 50 or 60cc syringe that comes with the cc kits is about an inch in diameter by about 4 inches long
eta: btw, you should get a kit for this. The discs eliminate the fluid's meniscus for better accuracy |
azbob Samba Member
Posted: Mon Feb 07, 2011 1:39 pm Post subject: |
bartman, yep, you're right. It was that big. Where do you get these CC kits? I checked CVS, O'Riely's, autozone... and nada. It was super annoying filling and dumping 46 times. Having to do it all over again sounds like a blast. _________________ Bus Builder |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1328 Location: Beautiful New Zealand
Posted: Mon Feb 07, 2011 1:59 pm Post subject: |
| azbob wrote: |
| bartman, yep, you're right. It was that big. Where do you get these CC kits? I checked CVS, O'Riely's, autozone... and nada. It was super annoying filling and dumping 46 times. Having to do it all over again sounds like a blast. |
For a 60ml syringe, go talk to your local pharmacist, or vet... Problem with doing it the way you describe is the error you'll introduce every time. A syringe like that isn't very accurate at the best of times and you've multiplied that error by a factor of 46. Wouldn't surprise me if you were a ml or more out in your measurement.
The usual VW parts houses, CB Performance or the like, have the CCing kits. _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Posted: Mon Feb 07, 2011 2:15 pm Post subject: |
| The proper syringe helps but you really gotta have the discs to eliminate any inconsistency in the apparent liquid volume |
azbob Samba Member
Posted: Mon Feb 07, 2011 2:39 pm Post subject: |
Thanks for the direction guys. I'll get back to doing this. I wonder why the hell they didn't tell just me wtf they cc'd the heads to when they gave them back... _________________ Bus Builder |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11136 Location: Black Forest, CO
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20895 Location: Just a tiny bit west of Yosemite Valley
azbob Samba Member
Posted: Mon Feb 07, 2011 10:16 pm Post subject: |
| Max Welton wrote: |
Maybe they didn't measure them. And you didn't ask them to, right? Where did you get the heads done at?
You shouldn't have to ask, of course. When I have heads done at V.W. Performance, Steve marks the chamber volume right on the fin.
Max |
I got them done at Competition Engineering. No clue, I mentioned it was my first go at an engine rebuild. Figured they'd throw out some pointers/info when they handed me back all my parts and explain the point of it all. Guess a novice should automatically know about this stuff. Meh... So be it. Guess I gotta learn some how.
Dale, thanks for the links, much appreciated. _________________ Bus Builder |
azbob Samba Member
Posted: Tue Feb 15, 2011 11:06 pm Post subject: |
Had to step away from the engine for a bit and finally now I'm getting back to this. My CCs were way off and of course, I was doing it wrong. Thanks for steering me in the right direction.
I got some shims that match what I need. three of them are cut the same, the fourth one however is cut different. Is this normal? A defect? I'm not going to write anything off w/o questioning.
Pic - one on the top is the one I'm questioning:
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Wed Feb 16, 2011 12:00 am Post subject: |
Bad Shim. Does it measure the right thickness and fit the cylinder AND fit between the studs without being held up on the inserts?
If so, use it.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
azbob Samba Member
Posted: Wed Feb 16, 2011 4:32 pm Post subject: |
@ RockCrusher I'll check the clearance tonight. It's pretty tight fit as is since its a 94mm bore. I'm pretty sure the thickness is correct, I'll check again tonight. These shims are a set of .060 BugPack.
@ Max I may be hitting you up for some info for me to contact him if it is messed up.
azbob Samba Member
Posted: Thu Feb 17, 2011 6:08 pm Post subject: |
Turns out the flat side, upon further non-beer induced inspection, was cut to the point that it is not usable. I took it back in to CEVW and Dan gave me a new one. So now I'm sitting pretty.
I'm glad I've got the samba to turn to for questions otherwise I'm pretty sure I'd be throwing money out the window. Thanks again! _________________ Bus Builder |
