Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Mon Feb 07, 2011 1:22 pm Post subject: Odd '66 Squareback... |
Check this out, my friend just picked up a '66 Baltic Blue Square, VIN 366311284, which is a May production. (I believe, if I looked up the VIN correctly)
Here's the kicker. It's all 12v. The whole car. Is this typical? I've never seen an '66 as a 12v. It wasn't converted either, it looks 100% factory.
He pulled the motor this morning, and even the trans is 12v. All it needed was a pressure plate. Sweet score. Hopefully I can get some pics of it. _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Feb 07, 2011 2:07 pm Post subject: Re: Odd '66 Squareback... |
Notched wrote: |
He pulled the motor this morning, and even the trans is 12v. All it needed was a pressure plate. Sweet score. Hopefully I can get some pics of it. |
12v became optional on all VWs beginning in 1963, IIRC. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Feb 07, 2011 2:19 pm Post subject: |
Interesting! So it was an option then. Hmmmm, I didn't think of that. That's cool!!
Anyone else have a pre-67 factory 12v Type 3?? _________________ Phillip Bradfield
Posted: Mon Feb 07, 2011 2:41 pm Post subject: |
Notched wrote: |
Anyone else have a pre-67 factory 12v Type 3?? |
I've actually seen 12v push button units for the early cars also.
12v "M" codes were 630 and 633. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2105 Location: Imperial Beach CA
Posted: Mon Feb 07, 2011 2:48 pm Post subject: |
Tram wrote: |
Notched wrote: |
12v "M" codes were 630 and 633. |
_________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
Notch Samba Member
Posted: Mon Feb 07, 2011 3:08 pm Post subject: |
I have an NOS pushbutton unit that is 12V I was told it was for ambulance use. _________________ '64 Notchback
'67 Bug
(sunroofs both)
1964 Lavey Craft, Flatbottom V-Drive, 406 Ford |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Feb 07, 2011 5:49 pm Post subject: |
Or police. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Mon Feb 07, 2011 9:07 pm Post subject: |
Is there a 12V lightning sticker on the front door jamb? |
Posted: Mon Feb 07, 2011 9:35 pm Post subject: |
Nope. That was the first thing I checked! It's definitely all factory though. _________________ Phillip Bradfield
rowanfry Samba Member
Joined: January 03, 2009 Posts: 134 Location: Christchurch, New Zealand
Posted: Mon Feb 07, 2011 11:58 pm Post subject: |
My 66 square is all 12v with the lightning sticker in the pillar, Nz new, possibly built in australia, undergoing alot of work...hasn't seen the road in over 12 years
rustyfastback Samba Member
Posted: Tue Feb 08, 2011 3:43 pm Post subject: |
Check to see if the generator is the smaller diameter 12 volt unit. If so I would say your '66 was factory ordered with the 12 volt option. I remember someone having an early wiper switch in the classifieds that was 12 volt, kinda rare also. Also take a look at the voltage regulator if it has the 3/8" spade slide on connectors it is not original. The '66 & earlier 12 volt type 3's had a unique regulator. I remember one for sale years ago. |
