Q: What's a UN1 Gearbox?
boulderdrop
boulderdrop is offline
PostPosted: Sun Feb 06, 2011 1:57 pm    Post subject: Q: What's a UN1 Gearbox? Reply with quote
I've heard this mentioned a few times, but I don't know what a UN1 gearbox is.
== My Rides ==
1984 Westy, Bostig, 3rd:1.14, Locker-LSD, Newly Painted
1980 24' J-Boat
1979 Sears Freespirit Moped
1996 Chev S10 4x4 ZR2
2012 Toyota Camry Hybrid (Wife's)
== How I Pay the Bills ==
Windows FTP Server at http://www.bpftpserver.com (PM for a FREE one)
D Clymer
D Clymer is offline
PostPosted: Sun Feb 06, 2011 2:47 pm    Post subject: Reply with quote
Alika can tell you a lot more about this transmission than I can, but it is a Renault transaxle designed for longitudinal mounted powertrains. It had a convertible ring and pinion assembly so it could be used for rear engine or front engine/front drive cars. It was used on something as exotic as the Lotus Espirit, something as unusual and cool as the Renault Alpine and the Delorean, and something as pedestrian as the Eagle Medallian. It has a bolt on bellhousing so there are many engine adaptations possible.
Apparently a good component. The only downside to using one in a Vanagon is its length.
David
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Feb 06, 2011 10:14 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=449503 LAST WEEK Rolling Eyes
VisPacem
VisPacem is offline
PostPosted: Mon Feb 07, 2011 7:54 am    Post subject: Reply with quote
David
Just as an historical detail, said UN1 (IRS) transmission was used on Alpines, however,and at least to me , Alpine automatically means Alpine A110, 1.1l, 1.3l or 1.6l.
Yes indeed Alpine, thereafter aka Renault-Alpine continued on with the 310, I believe 310 or 610 GTA with said UN1 IRS transmission as, THE famous Alpine, the A110 never had an IRS transmission making do (very well) with a swing axle, which was common to the Renault R8 Gordini 1.1l and 1.3l, not taking into account the racing version factory works.
The reason for the post is that I was at first puzzled on how a Vanagon would behave with a swing axle, my real knowledge of Alpine cars being limited to the 106, 108 and 110.
I am sure Monsieur Alika can give us all the "dirty" details Laughing
LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons)
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Feb 07, 2011 10:03 am    Post subject: Reply with quote
Alpine GTA
Model Part No.
Renault 21 Turbo UN1-013 25
R21 GTX UN 1-03
R25V6 UN 1-04
R25 Armored UN 1-06
R25V6 Turbo UN1-08
Alpine GTA * UN1-05
Alpine Turbo UN1-07
Alpine A310V6 369-02
R30TX 369-01/06/017
R30TS 369-01/06/014
Renault Espace (earlier models) UN1
Renault Master van:UN 5 (you can't flip the ring,its diameter is too big)
DeLorean 369
Lotus Esprit UN1-25/26/27 (stronger cases and pinion/shaft assemby maybe?)
Venturi ??
Gear ratios of various UN1/369 variants
Model Part No. 1st 2nd 3rd 4th 5th Rev Diff
R5 Turbo 1 369-04(+)/09 3.36 2.06 1.38 1.06 0.87 3.18 3.89 =(couple9x35)
R5 Turbo 2 369-15 3.36 2.06 1.38 1.06 0.87 3.18 3.89=(R&P 9x35)
R20 369.00 3.36 2.06 1.38 1.06 0.82 3.55 4.11 =(9x37)
369.05 3.36 2.06 1.38 1.06 0.82 3.55 4.11 =(9x37)
R20TX 369 3.36 2.06 1.38 1.06 0.87 3.55 3.778
R20LS/TS 369 3.82 2.18 1.41 1.03 0.86 3.55 3.778
R21Turbo UN1-013 3.36 2.05 1.38 1.03 0.82 3.54 3.44 =(couple9x31=
R25GTX UN 1-03 3.36 2.05 1.38 1.04 0.82 3.55 3.89
R25V6 UN 1-04 3.36 2.05 1.38 0.96 0.76 3.55 3.89
Alpine GTA * UN1-05 3.36 2.05 1.38 1.04 0.82 3.55 3.44 =(couple9x31)
R&P 9x35 ( 3.89)
special pinions for rally (strait cut) TDC? (I don't what it means)
1st 39x12 3.25
2nd 38x17 2.24
3rd 34x21 1.62
4th 30x24 1.25
5th 29x28 1.04
boulderdrop
PostPosted: Mon Feb 07, 2011 10:32 am    Post subject: Reply with quote
Interesting! The specs are pretty detailed. I don't get how they are used in the Vanagon platform.
ALIKA T3 wrote:
How is your's mounted? Do you have any pics? Just not sure how it works.
== My Rides ==
1980 24' J-Boat
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Feb 07, 2011 4:00 pm    Post subject: Reply with quote
You have the choice to back up your engine or cut the crossmember and make another one.
I use the vanagon shifter,I attached the VW ball selector to it and shortened the linkage.I did a replica of the vw shifter,shorter with same bushings and location basically.
Many options have been done,but I like mine,easy.
The bellhousing mates with an adapter plate that needs to be 15 or 20mm I don't remember,I did mine not thick enough for the Subaru,it should have been 15mm,I did 3/8 so I removed material from the input shaft where the coupling is attached.
The splines are the sames as VW,so that's butter.
That's the easiest cheapest swap you can dream about,specially since I found out Delorean flanges can be used along with Eurovan 33 splines cv joints on the VW axle shaft.
You can look at pics on the link in my signature,they are spread over the period,but they are accurate pics Wink
Bye!
syncrodoka
syncrodoka is offline
PostPosted: Mon Feb 07, 2011 10:17 pm    Post subject: Reply with quote
http://ultimate-engineering.co.uk/renaultun1.html
IdahoDoug
IdahoDoug is offline
PostPosted: Mon Feb 07, 2011 10:38 pm    Post subject: Reply with quote
Random thread hijack. I got to drive a new Alpine GT somethingerather 310 on the streets of Lansing, Michigan in 1984. I had it for a week and was impressed by French automotive engineering (wait - that's an oxymoron). It was a beefed model with big front air dam, fender flares and the yellow headlights got me some further unwanted attention. A serious motorcycle accident happened right in front of me and I used the Alpine to block traffic until the ambulance arrived (rider was down in the street). An overzealous officer noticed the headlamps, flipped out on me about the car and started telling me to follow him to the station until another officer who was aware I had played a minor role in helping them talked him out of it. Wild car. Forgot all about it until this random thread.
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
syncrogreg
syncrogreg is offline
PostPosted: Tue Feb 08, 2011 7:09 am    Post subject: Reply with quote
Just a cad but I'm sure it's a great product.
http://shop.busprojekte.de/un1-getriebeumbau/umbauteile-t3/subaru-getriebeglocke.html
GSB
conversions: www.boxeer.com Common rail TDI and NOW PDK transmissions!!
travel pictures:
http://instagram.com/crepeattack/
- the Pastis build: http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel
boulderdrop
PostPosted: Tue Feb 08, 2011 9:57 am    Post subject: Reply with quote
Nice link, Thanks man! That helps a lot to understand too.
== My Rides ==
1980 24' J-Boat
keithwwalker
keithwwalker is offline
PostPosted: Sun Feb 26, 2012 2:48 am    Post subject: Reply with quote
Thread info = golden, thanks!
Team WorldTour
Team WorldTour is offline
PostPosted: Sun Feb 26, 2012 3:10 am    Post subject: Reply with quote
If you have a Subi conversion, forget the UN1. There is now a better option: www.SubaruGears.com
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Feb 26, 2012 10:57 am    Post subject: Reply with quote
It depends on many factors:where you live and how much money you got in your wallet.
You can find a good UN1 in Europe for 150 euros.....,adapter plate is easy to make,shifter is easy to connect,but chassis crossmember has to be cut,which is a big thing.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jun 20, 2012 8:46 pm    Post subject: Reply with quote
presslab
presslab is offline
PostPosted: Wed Jun 20, 2012 10:29 pm    Post subject: Reply with quote
Alika, what ratios/R&P does the UN1 in your van have?
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jun 20, 2012 10:53 pm    Post subject: Reply with quote
Hi Presslab,
I have the UN 1-03 model
1st 3.36
2nd 2.05
3rd 1.38
4th 1.04
5th 0.82
Reverse 3.55
Ring and pinion 3.89 (9x35)
I almost never use the 5th gear,it's already really good with 4 gears,I can push the 4th at 100 Mph
Gotta do a video starting from zero Mph,it's freaking amazing how "long" it pulls Razz
Cheers
presslab
presslab is offline
PostPosted: Thu Jun 21, 2012 9:00 am    Post subject: Reply with quote
Thanks Alika! Smile
You have EJ22 engine, yes? So how would you say the power is in 5th gear? Can it hold 65 MPH on the flats? Are your tires stock size?
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Thu Jun 21, 2012 9:05 am    Post subject: Reply with quote
Does anyone know if this is the only source for pre-made parts for this swap?
Casey--
'01 Weekender --> full camper
y u rune klassik?
purplepeopleeater
purplepeopleeater is offline
PostPosted: Thu Jun 21, 2012 9:11 am    Post subject: Reply with quote
Holy crap, is that speedo in mph?
I'd leave a brown trail in my seat if I got my van to a 100.
