70 Beetle Resto-Mod Project
Page: 1, 2, 3, 4, 5  Next
T8kitease
T8kitease is offline
PostPosted: Sun Feb 06, 2011 8:10 pm    Post subject: 70 Beetle Resto-Mod Project Reply with quote
Here's my 70 I bought back in 06. Jusy started uploading pics and figured I start a page. The project had stopped for 2 years after I finished the pan due to home improvements. I just got back in the garage this winter to start again! I'm still learning things while keeping it fun. Hope i could help anyone in need of info or pictures. I'll be adding more pictures of the work thats done up to date.
Matt
Matt
70 Beetle Resto
http://www.thesamba.com/vw/forum/viewtopic.php?t=450346
GreeneHoosier
GreeneHoosier is offline
PostPosted: Mon Feb 07, 2011 5:29 am    Post subject: Reply with quote
Looks like a nice find. Especially for an eastern car. I have a 70 that is the same Ruby Red, by the best you can afford when it comes to parts, there is a lot of crappy stuff out there for these little cars. Good luck!
1974 Super Beetle
40 Years VW enthusiast!
redrum71
redrum71 is offline
PostPosted: Mon Feb 07, 2011 6:24 am    Post subject: Reply with quote
GreeneHoosier wrote:
Looks like a nice find. Especially for an eastern car. I have a 70 that is the same Ruby Red, buy the best you can afford when it comes to parts, there is a lot of crappy stuff out there for these little cars. Good luck!
New looking bug, I wish I had pop out rear windows on mine, I love those! and, Trust me, if you can't afford quality parts, don't buy them because your gonna end up replacing them down the road! Been there done that a time or two Embarassed
VW Logo 72 FAT chick Blue Bug
VW Logo 71 baywindow Red Bay Bus -
VW Logo 67 Baja Green Bug
T8kitease
PostPosted: Mon Feb 07, 2011 1:03 pm    Post subject: Reply with quote
Thanks, it does need some surgery, pans, heaterchannels and to correct some PO hacking. Thanks for the advice! I've been buying the best i can. This site has been great for researching feedback on parts and suppliers. Heres a couple more shots.
Matt
70 Beetle Resto
T8kitease
PostPosted: Mon Feb 07, 2011 1:18 pm    Post subject: Reply with quote
Drained oil
Pulled engine
Removed wheels, fenders, interior, doors, electrical etc.
Welded braces in for heaterchannel removal
Matt
70 Beetle Resto
T8kitease
PostPosted: Mon Feb 07, 2011 4:51 pm    Post subject: Reply with quote
Removed the body and stored it outside
Removed pedal cluster, trans and axle shafts
Started cutting out floor pans using sawzall, air body saw and air chisel for leftover spot welds. Spotweld drill to drill other areas out.
Removed the trailing arms.
Matt
70 Beetle Resto
T8kitease
PostPosted: Mon Feb 07, 2011 6:14 pm    Post subject: Reply with quote
Removed the front beam
Started to fab and weld a jig to replace the framehead
Finish product-worked great!
Matt
70 Beetle Resto
redrum71
redrum71 is offline
PostPosted: Mon Feb 07, 2011 11:53 pm    Post subject: Reply with quote
Damn Shocked your not messin around huh? looking good!
T8kitease
PostPosted: Tue Feb 08, 2011 8:31 am    Post subject: Reply with quote
Thanks red, I like to try to make it better than it was in 1970. Also helps to have a friend who's a welder and owes you some work time! Wink
Matt
70 Beetle Resto
Redvolk65
Redvolk65 is offline
PostPosted: Tue Feb 08, 2011 9:31 am    Post subject: Reply with quote
nice work keep doing it
T8kitease
PostPosted: Tue Feb 08, 2011 1:48 pm    Post subject: Reply with quote
Started drilling spot welds and cutting mainly to understand how the framehead is assembled and to cut in the right spot. Alot of drilling
New parts
Sliced off the old head! Goo Byeee!
Did some trimming and placed the new head for the first time only to find it needs more.
Matt
70 Beetle Resto
gtxbullet
gtxbullet is offline
PostPosted: Tue Feb 08, 2011 1:57 pm    Post subject: Reply with quote
WOOOOOW!!!!
that's a lot of work you're putting into it. nice job!
Technician / Mechanic / Specialist
https://www.youtube.com/@itsastevething./videos
https://www.instagram.com/itsastevething/
https://www.facebook.com/ItsASteveThing/
Current Vehicles:
1988 Fiero 2.5L 5-speed
1985 Vanagon Multivan Subaru EZ30D with Subarugears 4.86 LSD 5-speed
1985 Vanagon Westfalia Weekender
jays
jays is offline
PostPosted: Tue Feb 08, 2011 2:05 pm    Post subject: Reply with quote
oh wow i wish i couldve gotten this into the restoration of my bug :[ making me sad man
T8kitease
PostPosted: Tue Feb 08, 2011 2:47 pm    Post subject: Reply with quote
Thanks, it is alot of work but it will be like a brand new bug n I get the experience of wrenching on it myself. I love working on it and each stage I get through the confidence level rises also. All said and done i could step back and say " I brought this bug back!"
Matt
70 Beetle Resto
flierbob
flierbob is offline
PostPosted: Tue Feb 08, 2011 3:02 pm    Post subject: Reply with quote
Got to love the VW wiring, make sure the fresh air drain is hooked up so the water won't ruin the trunk.
Wow is right, that looks like you are going after it!!!
Very Happy Very Happy Very Happy
Bob
T8kitease
PostPosted: Tue Feb 08, 2011 4:03 pm    Post subject: Reply with quote
Cut 2 access holes in side of tunnel to weld clutch tube bracket and run new fuel line.
Degreased the inside of the tunnel and it took of all the paint also!
Then discovered broken clutch tube bracket at the cluster hole
All welded up
Matt
70 Beetle Resto
DaniG
DaniG is offline
PostPosted: Wed Feb 09, 2011 12:58 pm    Post subject: Reply with quote
Not only did you bring it back, you'll be able to keep her running darn-near forever! Very impressive. I have a weakness for red VW Beetles anyway. Laughing
T8kitease
PostPosted: Wed Feb 09, 2011 2:35 pm    Post subject: Reply with quote
Thanks DaniG! The OG paint is nice but its under about 4 other colors!!
Uploaded some more shots. I wanted to keep the german brake hose brackets.
Considerable difference in thickness
Started running the 3/8 SS fuel line through the tunnel
Welded on SS 6AN fittings on each end
PO took a air chisel and opened up the tunnel to the side of the inspection cover to run a rubber fuel line out of. Started straightenig out the metal
Matt
70 Beetle Resto
T8kitease
PostPosted: Thu Feb 10, 2011 5:17 pm    Post subject: Reply with quote
Welded in some extra steel for support. Silver paint is Weld-thru II weldable primer. crap for tig welding.
Framehead welded up
Framehead support modified and blasted
First fit for floorpans. Needed a trim here and there but worked out real good.
Cleaned them up and punched holes with air flange/punch tool
Removed th seat tracks in order to install custom seat brackets
Matt
70 Beetle Resto
flierbob
flierbob is offline
PostPosted: Thu Feb 10, 2011 5:50 pm    Post subject: Reply with quote
Great work, that looks like the hard way to install new gas line unless you are fixing every thing else also. nice welding also. Shocked Shocked
Bob
Page 1 of 5
