61 ragtop strap connection
roadkingdoc
roadkingdoc is offline
PostPosted: Sun Feb 06, 2011 5:55 pm    Post subject: 61 ragtop strap connection Reply with quote
Anyone know where the end of this strap connects to? thanks
[img]
[/img]
GB2S
GB2S is offline
PostPosted: Sun Feb 06, 2011 6:10 pm    Post subject: Reply with quote
I thinks is loops around the rod in front, then stitches to itself.
Geoff
1963 Ragtop
roadkingdoc
PostPosted: Sun Feb 06, 2011 6:30 pm    Post subject: Reply with quote
is this the area of the rod it attaches to? thanks
[img]
[/img]
GB2S
GB2S is offline
PostPosted: Sun Feb 06, 2011 6:42 pm    Post subject: Reply with quote
Yes, As I understand, that webbing is there to help keep the rods aligned as you close the top. I guess the pull / tension would be on the webbing. Alot of ragtops no longer have this material, and this original webbing material is no longer available.
Would you please measure the length so I can make some out of nylon material.
I think the straps from a kids backpack would work. Going to search the Goodwill to fins a color I like.
Geoff
1963 Ragtop
GB2S
GB2S is offline
PostPosted: Sun Feb 06, 2011 6:46 pm    Post subject: Reply with quote
Looking at your pics again I bet the end of the strap screws or is riveted to the piece in front. A loop would cause a bump in the top.
Geoff
1963 Ragtop
roadkingdoc
PostPosted: Sun Feb 06, 2011 6:48 pm    Post subject: Reply with quote
good idea. i will measure it. i only have the one section. i dont know if it is complete? will look tommorow. this exploded view doesnt seem to help alot.
[img]
[/img]
roadkingdoc
PostPosted: Thu Feb 10, 2011 5:48 pm    Post subject: Reply with quote
GB2S i bought two new of these cotton braided straps. i will picture them and measure them when they are in my hands. i am also being sent some instructions which i hope will show where they go.
GB2S
GB2S is offline
PostPosted: Thu Feb 10, 2011 6:30 pm    Post subject: Reply with quote
RKD, where did you find them? How much? Thanks for the info.
Geoff
1963 Ragtop
bill may
bill may is offline
PostPosted: Thu Feb 10, 2011 6:40 pm    Post subject: Reply with quote
[img]
[/img]
cut to 12"
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
zozo
zozo is offline
I'm also in need of some, and will sure appreciate your sharing the information. Thank you.
my59
my59 is offline
PostPosted: Thu Feb 10, 2011 7:44 pm    Post subject: Reply with quote
The originals were riveted on.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
roadkingdoc
PostPosted: Fri Feb 11, 2011 2:46 pm    Post subject: Reply with quote
the remaining strap(as pictured in the first post) was pinched between the roller mechanism and the plate on top of it held by two screws where it connects to the middle roller bar. i dont know if the po did this or it is factory as the sunroof mech has been recovered. i would like to make sure the parts i ordered are what i am looking for before i comment on where they came from. they should be here next week and i will post when they are in my hands. thanks
smitty24
smitty24 is offline
PostPosted: Fri Feb 11, 2011 4:46 pm    Post subject: Reply with quote
I made my own by going to the hardware store and getting a couple feet of strapping material that is over by the rope and cable or camping supplies. much cheaper and you fold the ends over once and use rivets to secure to the bar.
roadkingdoc
PostPosted: Fri Feb 11, 2011 4:59 pm    Post subject: Reply with quote
good idea. i thought about some nylon from a light tie down strap. probably last longer than the og cotton strap. i would like to stay og if possible. we will see.
roadkingdoc
PostPosted: Sun Feb 20, 2011 2:20 pm    Post subject: Reply with quote
here are the nos ragtop straps i ordered. (chucks convertibles $12/pair)
[img]
i am told they go here
[img]
[/img]
GB2S
GB2S is offline
PostPosted: Sun Feb 20, 2011 4:44 pm    Post subject: Reply with quote
One on each side?
Geoff
1963 Ragtop
bill may
bill may is offline
PostPosted: Sun Feb 20, 2011 4:47 pm    Post subject: Reply with quote
GB2S wrote:
One on each side?
Geoff
Yes. and i see they are 12" long.
www.sv2s.com
SBS #100
DerekR
DerekR is offline
PostPosted: Sun Feb 20, 2011 11:13 pm    Post subject: Reply with quote
Bad cell phone picture but when installed correctly the strap takes the strain instead of the canvas when closing.
63 Ruby Red Double Cab
60 SO 23 Westfalia SWR/BG Camper
59 Dove Blue Standard Kombi
roadkingdoc
PostPosted: Mon Feb 21, 2011 10:03 am    Post subject: Reply with quote
thanks for the picture. what kind of rivets or screws are used toward the front of the strap? thanks
DerekR
DerekR is offline
PostPosted: Mon Feb 21, 2011 10:54 pm    Post subject: Reply with quote
Here are some better pictures. The front is riveted to the strap. I used a washer on each side for the rivet to hold onto.
