traviswx1 Samba Member
Posted: Mon Feb 14, 2011 4:21 pm Post subject: Who has ever broken an axle?? |
I am about to buy some used sway a way axles, the guy has two pairs, I only need one pair, and was thinking about getting extras. Do I really need them? Or should I go with just one pair. The axles are being sold on this site too. I am only running a stock 1600... I doubt I will break one... Any input helps.. _________________ 69 Baja, 091, 2x3, cage, 1600dp, bj front, and a sh!t load of labor! |
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
jsturtlebuggy Samba Member
Posted: Mon Feb 14, 2011 6:04 pm Post subject: |
Yes I broke and IRS axle in off road race car.
Have seen many over the years break in off road racing.
In a play car not that much of a chance unless they get nicks in them and are not taken care of.
Remember they made of torsion material and should be installed so they rotate the way they were installed new.
They twist and if installed backwards they will break. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
STOICH Samba Member
Joined: November 26, 2004 Posts: 1100 Location: Fallbrook
Posted: Mon Feb 14, 2011 6:30 pm Post subject: |
I guess if you break them in racing you own both halves and they would sell you a new one.
Found it was always best to replace in pairs.
This was before having my own magnaflux setup. _________________ Joseph
Elrod Motorsports
Posted: Mon Feb 14, 2011 8:02 pm Post subject: |
Thanks guys, just what I was loking for. _________________ 69 Baja, 091, 2x3, cage, 1600dp, bj front, and a sh!t load of labor! |
cmiller95 Samba Member
Joined: August 04, 2010 Posts: 1232 Location: Illinois
surewriting Samba Member
Joined: September 17, 2009 Posts: 138 Location: Buford, Ga
Posted: Mon Feb 14, 2011 9:03 pm Post subject: |
Ive broken a swing-axle shaft before, with a 1600dp. Of course, I had 31X10.50s and I dropped the clutch (like an idiot) on asphalt, and POW! presto-magico, a snapped axle. When I jacked the car up to see what was wrong I was able to pull the whole wheel and drum still attached to the broken shaft.
So, yes, its possible, but pretty unlikely, as Im just one of those kind of folks who can break an anvil. |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Tue Feb 15, 2011 8:47 am Post subject: |
has the seller marked the direction of rotaion of prior use?
you might break an axle if you reverse the direction.. _________________ foam cowboy hats aren't good helmets. |
joescoolcustoms Samba Member
Posted: Tue Feb 15, 2011 1:10 pm Post subject: |
I have twisted a few spades off on stock axles and shattered CV's, but never broke a IRS stock axle.
I run SAW axles in my drag rail, hit it at 8000 rpm launch and carry the front wheels about 70 feet, but never broke a SAW axle. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
quadrazer Samba Member
Joined: April 11, 2010 Posts: 295 Location: Castalia, Ohio
Posted: Tue Feb 15, 2011 2:38 pm Post subject: |
I've never broke an axle, and I'm running custom length axles in mine. I did however grenade a CV joint (or 2 or 3), and I should have took the entire axle/CV assembly out before I got towed off the dunes. Because when I got back to the pits and disassembled it, I found that the grenaded parts had tumbled around inside the boot while I was being towed in and had boogered up a few splines on the axle. Took a while to get the splines straightened out. I need to get another set....just for backups. Live and learn I guess. _________________ I DID wash my hands....the rest is 'built-in' dirt!
My build: http://www.thesamba.com/vw/forum/viewtopic.php?t=409845 |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Tue Feb 15, 2011 4:47 pm Post subject: |
With a 1600 the direction of the axle wont even matter. I have thrown no telling how many axles on sandrails and never had any trouble, even some that ran slicks on the drag strip occasionally with a less than 120HP engine.
I occasionally break a VW axle with my 200HP VW and 16.50 comp cut paddles, maybe 1 every 2 years. Never had any trouble with a 150 HP engine. |
