What TDI do I need for my Syncro Westy
Page: 1, 2, 3, 4  Next
JeffDenson
JeffDenson is offline
PostPosted: Thu Feb 17, 2011 9:32 pm    Post subject: What TDI do I need for my Syncro Westy Reply with quote
I am looking at all the different options. Just wanted to know if I wanted 150 hp and 280 of torque. What engine would you guys go with? I want to be able to haul a few ATV's. Sorry if this is a dumb question but I am still learning!
syncrogreg
syncrogreg is offline
PostPosted: Thu Feb 17, 2011 9:36 pm    Post subject: Reply with quote
Do you want a Subaru diesel ?
GSB
conversions: www.boxeer.com Common rail TDI and NOW PDK transmissions!!
travel pictures:
http://instagram.com/crepeattack/
- the Pastis build: http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Thu Feb 17, 2011 9:43 pm    Post subject: Reply with quote
Just about any VW tdi can be coaxed into producing those figures with some massaging. What's your budget?
Casey--
'01 Weekender --> full camper
y u rune klassik?
JeffDenson
PostPosted: Thu Feb 17, 2011 9:44 pm    Post subject: Reply with quote
That would be sweet but probably out of the price range? Although I have been looking at the Pd that has the 150 hp for 10G.
JeffDenson
PostPosted: Thu Feb 17, 2011 9:49 pm    Post subject: Reply with quote
My thought was to spend around 3-5k for a motor but its the rest that is going to cost so much. They do not have any of the higher output TDI engines in the US?
Zeitgeist 13
PostPosted: Thu Feb 17, 2011 10:33 pm    Post subject: Reply with quote
All the VW tdis can easily be modified to produce ungodly amounts of hp and torque, if you've got the budget for the enhancements, so you just need to settle on the best platform from which to base your conversion and go from there.
Casey--
y u rune klassik?
dobryan
dobryan is offline
PostPosted: Thu Feb 17, 2011 10:40 pm    Post subject: Reply with quote
Talk to Karl Mullendore at Westy Ventures. He does Tdi conversions and can tell you all you want to know.
http://www.westyventures.com/
Dave O
The Western Syncro build
wolfsburg4x4
wolfsburg4x4 is offline
PostPosted: Thu Feb 17, 2011 10:53 pm    Post subject: Reply with quote
Karl is the M-TDI specialist but you might also check out www.transporterwerks.com , I believe they do pump duse tdis and are in your neck of the woods
cmvan
cmvan is offline
PostPosted: Fri Feb 18, 2011 9:09 am    Post subject: Reply with quote
Grease Works is another good resource. Check out his shop blog he just finished building a 150 hp engine. www.greaseworks.org and greaseworks.blogspot.com/ Justin is a super nice guy and has always answered all of my questions.
81 westy
88 westy ahu e-tdi
11 tdi jsw
Alaric.H
Alaric.H is offline
PostPosted: Fri Feb 18, 2011 9:25 am    Post subject: Reply with quote
You can ask this guy seems to be knowledgeable.
[email protected]
syncrodoka
syncrodoka is offline
PostPosted: Fri Feb 18, 2011 10:08 am    Post subject: Reply with quote
Karl Mullendore- Yes, he does seem to know a thing or 2 about diesels.
Alaric.H
Alaric.H is offline
PostPosted: Fri Feb 18, 2011 11:11 am    Post subject: Reply with quote
I did not send westyventures email as he may be book into the afterlife.
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Feb 18, 2011 11:16 am    Post subject: Reply with quote
I don't get it. Can you restate the above into simple English please?
jackbombay
jackbombay is offline
PostPosted: Fri Feb 18, 2011 11:19 am    Post subject: Reply with quote
The ALH TDIs (99.5-2003) have the largest aftermarket and are the easiest to get big power out of, but they take a fair bit more work to install than the older AHU TDIs.
If you plan on towing 2 atv's at highway speed you will need to spend some money to keep the TDI happy. Good intercooling, and additional oil cooling are needed for such an application IMO. I'd install a EGT (Exhaust Gas Temperature) gauge as well.
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
BlackDogVan
BlackDogVan is offline
PostPosted: Fri Feb 18, 2011 11:27 am    Post subject: Reply with quote
Yes please do! What could be taken from that statement is not something that should be worded in a confusing way.
Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka...
dobryan
dobryan is offline
PostPosted: Fri Feb 18, 2011 11:35 am    Post subject: Reply with quote
I think Alaric is trying to say that Karl is booked up until forever (book into the afterlife). I gave Karl as a reference since the OP could talk to Karl and get a knowledgable opinion/answer to his questions. Not expecting Karl to be able to work on the conversion anytime soon even if the OP wanted him to. Very Happy
Dave O
dhesq
dhesq is offline
PostPosted: Fri Feb 18, 2011 11:38 am    Post subject: Reply with quote
What about the 1Z motors? Are they a big pain in the booootocks because of the computer control? I have heard that a lot of people use the AAZ diesel. I'm still trying to think of a way to stick a 3-71 van. Talk about torque and noise and smoke!!! Sweet.
Yep. Totally sweet.
Scott H wrote:
sb001 wrote:
I have owned my bug since new and you have not, which gives me more right to ownership than you.
What does this even mean?
More right to ownership ... wtf? Confused
BlackDogVan
PostPosted: Fri Feb 18, 2011 12:12 pm    Post subject: Reply with quote
2 stroke DD's only do one thing well, turn diesel fuel into noise!!
Now find a way to use a series 60 & well be onto something!
Indirect injection (IDI) AAZ will not easily get you to your power goal. 1Z/AHU are eTDI & can mount using stock vanagon diesel 50 degree mounting bits or overland conversion parts for 15 degree install. etdi ALH is indeed a stouter motor & can go 50deg with some work but is easier at 15. All vw tdi's can accept mtdi pumps, Libbybapa has a 12mm cummins 4bt bolt on pump for sale right now for a fantastic price, highly recommended.
The 15 degree overland kits sold by many are pretty complete & use hydro mounts which is gooder than the stock VW diesel setup IMHO. 50 degree has better ground clearance than the WBX tho.
dhesq
dhesq is offline
PostPosted: Fri Feb 18, 2011 12:18 pm    Post subject: Reply with quote
I wish that one could squeeze a Series 60 in there! Jesu Christo!! Is that a DDEC IV correct? Imagine..... There was a 3-54T also. That might be a little easier to put in although I have the 3-71 already up at the farm.
SyncroGhia
SyncroGhia is offline
PostPosted: Fri Feb 18, 2011 1:01 pm    Post subject: Reply with quote
I think the question is whether you want it to be reliable (i.e. last more than 25K miles) long term with that much power and torque.
I'm one of the few putting this through my Syncro daily and it's hard on the gearbox.
If I wanted to do this kind of conversion again, I'd want to start off with the latest V6 3.0 TDi from VW/Audi, or the equivalent from other manufacturers. That way you start with that much (or more) power and torque without having to tune it and in the process, lose some of the ecomony, reliability and refinement which the manufacturers have spent tens of thousands on getting as good as possible.
I've tuned Limey up but only because 115bhp and 200ftlbs wasn't enough to drive around daily in a 4850 lbs Syncro. In the process I've lost some of the ecomony. I'm looking at ways now to get that back
I can't see a 1Z of AFN living to very long with 150bhp and 280ftlbs. The PD's do seem better but they wear injector cams on the higher hp engines. There is a fix for this which I would do if I was going to run one. The 150bhp PD TDi only produces 235ftlbs so you'd need to tweak it to get more.
MG
T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Page 1 of 4
