dana Samba Member
Joined: April 28, 2003 Posts: 95 Location: edmonton, alberta, canada
Posted: Fri May 16, 2003 10:57 pm Post subject: What Am i Missing |
I have a 74 westy, i just put the engine back in and hooked everything back up, i installed fuel lines to pump but am not getting any fuel to carbs. I am not getting any fuel out of the tank and i know there is gas in there. do they airlock or have to be bled or something. thanks for the help. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sat May 17, 2003 9:34 am Post subject: What Am i Missing |
since no one else has posted yet, I'd say have you swithced the lines around to make sure they are not reversed?
Pour a little fuel down each carb to start the engine? see if it takes off and starts pumping?
do you have a clear universal type fuel filter, I usually run one right under the tank and one in line to the carb(s), this way you can wsee what the fuel is doing... |
wgargan Samba Member
Joined: September 21, 2002 Posts: 871 Location: Dreaming of the Rockies
Posted: Sat May 17, 2003 11:08 am Post subject: What Am i Missing |
If the fuel pump is the same as a '73, yes they do air lock, there is a little nut on the pump, that you have to loosen a little and gass will leak out, when the gass leakes out tighten it and you should be ready to go. remember this applies to a '73 fuel pump i am not sure what the '74 has. good luck
lc |
dana Samba Member
Posted: Sat May 17, 2003 3:28 pm Post subject: What Am i Missing |
Got it figured out. i had the lines crossed and appaprently it was too late in the night and i was too tired to figure it out for myself. thanks. |
