64 Rear Drums installation
Page: Previous  1, 2
angus_hanger
angus_hanger is offline
PostPosted: Wed Feb 23, 2011 10:56 pm    Post subject: Reply with quote
hsosa1 wrote:
yes its binding on the shoes. I whacked the drum a few times more and it got closer . Which way Do I turn the star adjuster clock wise or counter ? yes its rear left wheel. Thanks
From where you're at, it shouldn't be too hard to get a spare star adjuster with a spline ... I have one in my toolbox ... helps me to remember which way to turn the adjuster whilst I look at it ...
His - 'Rosie' - '64 Westy
Hers - '66 Beetle
SST '04 -'06
"Why yes sir, Sheriff, I do like Fat Chicks."
View user's profile Send private message AIM Address Facebook Gallery Classifieds Feedback
angus_hanger
PostPosted: Wed Feb 23, 2011 10:57 pm    Post subject: Reply with quote
Emeritusx wrote:
Cleanliness is next to stopliness Smile
Oh, stop it ... that's bus brake porn ...
Hers - '66 Beetle
SST '04 -'06
Emeritusx
Emeritusx is offline
PostPosted: Thu Feb 24, 2011 11:37 am    Post subject: Reply with quote
Clockwise is how I look at it: if you are looking at where the slotted bolt goes into the star Clockwise on the star always extends your brakes
I cleaned that solely with spray brake cleaner, and just a little scraping.. I like putting things back together clean. It makes the job so much easier and is worth the small amount of time to make it so.
hsosa1
hsosa1 is offline
PostPosted: Tue Mar 01, 2011 8:22 pm    Post subject: Reply with quote
Ok Im back still working on this . I was on vacation in Hawaii for a few days. Ok so I got the drum off with a drum puller. . I will take a pic of the brakes and post soon. . The brakes are turned all the way in the issue is the Stub axle. The splines are pretty beat. the drum doesnt just slip onto the shaft . I cleaned and greased the splines but the drum still doesnt go on easily. has to be pressed in with c-clamps A. Im thinking of removing the right side brake drum and seeing if my new drum that I have fits on the right side(undamaged stub axle). and then switching over the right drum to the left side and see if it fits the beat up stub axle. B. replace the beat up stub axle. OR do both a and b .Ive never replaced a stub axle before . and where can I get a replacement stub axle. Pics to post tommorrow. Thanks fellas
Just Cruzin Sur Califas VW Car Club est♤1998
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
turkis-deluxe
Samba Security
turkis-deluxe is offline
PostPosted: Tue Mar 01, 2011 8:31 pm    Post subject: Reply with quote
I've had to file the stub axles before on the rare occasion a drum was stuck. If you've been pressing that drum on it's likely you've caused more damage than was previously there.
Switching drums from the other side or a spare is a good idea to see where the problem lies but if you've damaged it beyond repair you may be switching axles out.
Good luck.
j.pickens
j.pickens is offline
PostPosted: Tue Mar 01, 2011 8:51 pm    Post subject: Reply with quote
How do you know the drums are German?
They sound like the Brazilian drums I've helped install lately.
(and by install, I mean trying to fit them, then taking them off and throwing them away.)
Personally, after making sure you have the right drum ('64 was a transition year, several versions of rear ends were used), if it still fits like crap, I'd fix the problem.
Either new short axle, or different drum.
Pounding or clamping it on is not good, and should not be necessary.
BeaterBarndoor wrote:
Red Fau Veh wrote:
bill may
bill may is offline
PostPosted: Wed Mar 02, 2011 5:28 am    Post subject: Reply with quote
Baddogracings Greg U. broke a brazilian drum on shasta snow trip. Barry Lynn had one break out in center of the drum. Frum drum in Greg's case.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
hsosa1
hsosa1 is offline
PostPosted: Wed Mar 02, 2011 5:00 pm    Post subject: Reply with quote
I posted a pic of the drum and the part number . ITs a german drum. Where do I find a new or used Stub axle. I might have to go this route if my plan A doesnt work out. Pics to post soon. Thanks
hsosa1
hsosa1 is offline
PostPosted: Wed Mar 02, 2011 7:36 pm    Post subject: Reply with quote
Heres the pic of the brakes and stub axle . I know I will get some brake cleaner spray and clean up it up. Tommorrow I will do the drum swap and update u guys. Thanks
hsosa1
hsosa1 is offline
PostPosted: Sat Mar 05, 2011 3:04 pm    Post subject: Reply with quote
Here s an update. I switched the drums and it worked! Now Im adjusting the drums and torquing that axle nut down with a 6 foot breaker bar.
ToolBox
ToolBox is offline
PostPosted: Mon Mar 07, 2011 10:03 am    Post subject: Reply with quote
If you go hog wild with the cheater bar you will have some reduction box rebuilds in your future.
Borrow a torque wrench and do it correctly.
hsosa1
hsosa1 is offline
PostPosted: Fri Mar 11, 2011 6:31 pm    Post subject: Reply with quote
Im going to see if my autoparts rents torque wrench out. I tightened up the axel nut to the brake drum and now the brake drum drags with the brakes shoes adjusted all the way in. if i loosen the axel nut its fine. axel nut on too tight ? Yeah I need a torque wrench. I figuare i can go one hole back on the axle nut. i did adjust the stars to lock on the drum and back off the stars 3 times but the drum still drags . or #2 Figuare Ill start all over and tear it down tommorrow. fit the drum on without the brake shoes. tighter axel nut see if the wheel drags or not. and install brakes shoes back. any suggestions or pointers thanks
ToolBox
ToolBox is offline
PostPosted: Fri Mar 11, 2011 6:54 pm    Post subject: Reply with quote
Step on the pedal a few times to center the shoes and then see if it drags.
Page: Previous  1, 2
Page 2 of 2
